      Santa Clara, CA
      Convert Console to Powerglide configuration with T56?
      Has anyone converted their 67 Camaro Console over to a Powerglide configuration when installing a Magnum T56? The shifter handle pokes up right in the middle of the trans tunnel, and although it looks like Hurst and American Powertrain make offset shifters that put the handle back over to the left where the console opening is, I noticed that the Powerglide trim pieces appear to be perfectly centered over the tunnel opening. This would be considerably less expensive than a $350+ new shifter. I agree that it might look silly with the cutout for the gear selector (although I think just painting the backing plate flat black and installing it there might work), I'm just curious if anyone else has taken this approach? I haven't measured my shifter to see what the left-to-right displacement is and whether that would work with the slim PG trim opening.
      It looks like Tremec also lists two offset kits that would appear to work with the stock Tremec shifter that I already have (TUPC9643 & TUPC9443), but it doesn't appear that one can actually BUY those parts anywhere--or at least within the landscape that Google can survey.... Thanks.
      Steve
      Santa Clara, CA
      Looks like the stock Tremec shifter is lining up better than I gave it credit for, so I went ahead and built up the console with the stock 4-speed trim; hoping that it will look decent enough.... Will need to figure out how to fill the rest of the gaping hole in the tunnel but that can happen down the road; can't imagine how much road noise, debris and water will splash up from there :-( Need to add it to the growing list of things that I'll need a shop to look after for me once the vehicle is actually functional....
      Steve
