    Results 1 to 10 of 10
      Santa Clara, CA
      3 Water Temperature Senders?
      I'm faced with the possibility of my LS engine needing 3 water temperature senders: 1 for the ECU, 1 for the aftermarket water temp gauge and one for the aftermarket pwm fan controller. I know that 2 can be easily accommodated (1 in each head) but is there a 3rd location that could be pressed in to service? I'll contact the PWM controller manufacturer to see if they might be able to share the same sender as the aftermarket gauge, but I'm pretty uncertain about that. Thanks.
      Steve
      Apr 2012
      Woodstock, IL
      You can drill and tap a hole into the water pump near the thermostat. Not really any other simple way.. I'm sure there's a hose splice with a bung welded in available somewhere though if that was sanitary enough for your build!
      -Dale
      SchwartzPerformance
      May 2010
      Livermore CA
      I added a bung to my radiator near the outlet to control my fans. Stock sender in the intake and gauge in the thermostat housing. It was on my ford, but the same idea.
      Sep 2008
      Jacksonville, Florida
      Their are two types of coolant temp senders, PTC (positive temperature coefficient) and NTC (negative temperature coefficient). Resistance will either increase or decrease with temp. You can put all the senders in ice water and measuring the resistance, then put them in boiling water and measure the resistance. If they are the same, you can use just one sender for all, or you might get lucky and be able to put two on the same sender.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Santa Clara, CA
      The gauge vendor suggested putting the probe for the pwm controller into the radiator, which I think is a decent idea (he nixed using 1 sender for multiple functions). Sadly, I just discovered the other day that the radiator drain opening, which is 1/4" NPT, is also super super close to the driver's side frame rail--and that the lower radiator hose nipple is super super close to the passenger side frame rail.... More creative thinking required! :-(
      Steve
      Country Flag: China
      You should talk to one of the LS wiring conversion companies like Speartech, PSI or Painless just to name a few as you should be able to use an output from the LS ECM to turn the fans on and hence make use of temperature sender also being used by the ECM for other things. Good luck and let us know what you find out.
      Also, if you are using Dakota Digital VHX gauges you can use their OBD interface so you don't need duplicated sending units for the gauges . . .
      You can check put the picture of my PRC radiator that has the extra bung for the fan controller near the drain valve near in my recent classified ad.
      Santa Clara, CA
      I decided to stop trying to fit a square peg into a round hole, so to speak. I bought a 3/8" NPT aluminum weld bung and I'm going to take my radiator to a local guy and have it added, in a spot that hopefully clears the framerails. Then I purchased the Painless F5 kit with the 3/8" sender, and that will go to the radiator. My ECM does control a fan, but I believe it is "on/off," plus I think it might have been difficult to integrate the A/C. But mainly I wanted the pwm control for my dual fans.
      Steve
      Jacksonville, FL
      Can't you use a trinary switch to control the fans during AC operation? What type of AC and engine harness are you using?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jacksonville, FL
      Steve, have you read this- http://www.lateral-g.net/forums/showthread.php4?t=40215
      As soon as I get some time on my car, I think I might go this route.
      Chris
      Santa Clara, CA
      Great thread; thanks for the link! I know that JP has contributed to other threads here on pwm controllers and ECM control but now I know where he learned it from.
      Steve
