    Thread: new 383
      Jun 2013
      new 383
      Fresh SBC 383 stroker build one piece rear main seal/ factory roller block bored .030 over. Eagle crank, eagle sir 5140 forged I beam rods with arp bolts Mahle forged flat top pistons. AFR 210 fully cnc'd (new design) 75cc combustion chambers with adjustable guideplates that have been set up already, screw in 7/16 studs, comp ultra pro magnum 1.6 rocker arms, Manley chromoly pushrods, gm performance hi rev factory style roller lifters not tie bar style. Comp cam xr294hr camshaft. Engine pro double roller timing chain/gear set, melling hi volume oil pump with 3/4" pick up not regular 5/8" tube, champ 7qt zink coated oil pan baffled and trap doors with crank scraper. Procomp balancer and polished front timing cover- aluminum. Edlebrock 2925 single plane intake manifold with arp bolts-stainless. Msd pro billet distributor 8555. Msd digital 6al ignition box Msd blaster SS coil. Taylor thundervolt plug wires custom kit you must make them. Polished fabricated aluminum valve covers perimeter bolt style with felpro steel core rubber gaskets (the good ones) also one piece felpro oil pan gasket. hitachi high tq mini starter. Built this motor for my nova but decided to go lsx instead. This motor is brand new no reused parts or rebuilt parts everything is new exept for the block which was freshly machined before the build. Call or text nick @ 951 three17 twelve82. This motor will make 500hp 500tq on pump gas... 5k firm
      Jun 2013
      383 stroker
      Jun 2013
      new 383
      Also have a fresh turbo 400 trans with a stage 2 shift kit and hues 3k stall converter small diameter
      Mar 2011
      CA
      You have a pulley setup your trying to get rid if by chance
      Jun 2013
      new 383
      No I don't was gonna order a march set up for it but decided to go ls before I ordered them
      Jun 2013
      new 383
      Sold
