    Results 1 to 15 of 15
      Mar 2013
      Built to drive 74 Chevelle
      The car: 1974 Chevelle Malibu Classic.
      Current Engine: 1974 - 350 SBC for a pickup.
      Edelbrock 600 CFM carb
      Weiand 7530 intake
      Generic Headers
      Flowmaster Exhaust
      Current Trans: 350 from the same truck.
      Driveshaft cut, shortened and put back together to fit in the long shaft tranny.
      Rearend: Original 8.5 inch 10 bolt. I think it is like a 2.88 gear or something similar. The car was originally a 250 ci. straight six car.
      Suspension: Stock
      Interior: Original Black cloth with full bench in front.
      The top was cut out with the intent for adding t-tops before I received the car. The car was actually purchased from a junkyard to ran in the demolition derby car. Luckily I saved it.
      So, here are a few updates for ya.
      Here are a few shots of the dents after I was hit back in July. I had to total the car out and now have a rebuilt title. :(
      I missed the photo with the dent in the exhaust tip.
      Enlarge this image Click to see fullsize
      Pulling it out little by little.
      Fixed the dent in the exhaust! Then got bondo on it. I think I even hit it with the grinder once. 30$ and a new tip will probably come soon.
      Filling the whole and dent. Hope it holds!
      Somernites Cruise!
      New front spoiler. Trying to decide how to make it fit a little bit better. Any ideas?
      Can't wait to see all the new suspension on there and check out the stance. All I need is time.
      Oh, and notice the whole that is missing behind the drivers door glass! There was a golf ball sized whole there a couple weeks ago. Filled it too!
      Let me know what you think!
      Mar 2013
      No, nice job, keep up the good work, no nothin... Well, Good job Chris! Keep up the good work!
      Aug 2013
      Shelton WA
      Love that body style.
      Mission Viejo, CA
      Glad to see another '73-'77 getting some attention. What are some of your ideas for the car? Do you have any parts set aside yet?
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      Mar 2013
      Thanks for the replies. I love all g3 A body cars.
      Just got a set of 1 inch lowering Belltech springs for the rear. Installed those with the Gabriel Ultra shock yesterday. 1 inch is definitely enough with my current tires in the back. I hope that when I do the front that it is not to low. I got the 2 inch drop spindles for the front with HD laguna springs and Gabriel Ultra shocks for it as well. I did not want a low rider, just wanted it to handle a bit better. Oh and look mean!
      I have all new parts for the front as well. Just waiting for time and help installing them. Can't wait!
      Jun 2012
      South Lyon, MI
      I really like this body style. It has been so overlooked.
      Keep up the good work.
      Sep 2013
      so... this thread is just to show you threw some bondo over rust and in your wheel well? you know that will only make it worse over time right?
      Mar 2013
      Just until spring. Then hopefully new quarters and actual rust repair. Just learning to do some of this, but thanks for making me feel like what I have done was worthless.
      No welder, as of right now and just wanted to at least attempt at keeping from slinging more mud and water into my trunk.
      Nov 2011
      San Diego
      I like this body style too. Keep the images coming.
      Jun 2013
      San Diego
      What part of the country are you in?
      That two tone paint really works well on that body style.
      what types of projects you got planned? I think once you figure out that suspension and the stance of that car it will look sick. I'd throw some different rims on it.
      Out here in socal, a bondo job like that will last you 5-10 + years....that's exactly why I'm doing the same thing on my ride. Sure I could do the rotisserie thing and replace every single panel, but that's not in everyone's stack of cards. I can spread some bondo, spray a little paint and enjoy it on the road for many many miles before I could finish a full on rotisserie restoration.
      I vote keep up the good work!
      Mar 2013
      Thanks. I drew up a rendition of what I am thinking of going with as far as the look of the car. I should have it online by tomorrow. Finished it about 1:30 this morning. I like the look!
      Mar 2013
      What do you think. Starting at the bottom to the top bottom being the closest to the current style and a few different looks to choose from.
      Mar 2013
      No comments on the designs. Well anyway, I got the front suspension done.
      I bought the control arm bushings but did not change them as I do not have a press and we were pressed for time Plus they looked really good except one which wasn't really bad. Here is what we did change.
      Sway bar bushings and end links.
      Inner/Outer tie rod ends and adjusters.
      Centerlink
      Idler arm
      2 inch drop spindle
      Shocks
      Springs
      I think that was is, but it seemed like a lot more. I hope it comes down some in the front. I just can't believe it is sitting as high as it is with a 2 inch drop spindle. My uncle thinks they gave me BB springs. I have no idea!
      Please drop a little more in the front car!!!
      good work so far!! I like design 1, 2 and 3!
      Mar 2013
      Thanks!
