    Results 1 to 16 of 16
      Dec 2012
      C5 Disc Brake upgrade
      Hi guys
      So below is my current setup, GM 11" I believe, and would like to upgrade to the C5 13"s. I need to keep the offsets the same and obviously ride height as well.
      My question is, given what I currently have what is my best option for the conversion
      buy a full kit like this one ... (I always prefer 'kits' for the purposes of a hassle free install) also, are the taller spindles an advantage given my current setup ?
      http://www.ebay.com/itm/380461774641...84.m1423.l2649
      Or Piece it together with the brackets from speedtech, and a set of calipers like this ...
      http://www.ebay.com/itm/190444135709...id=p3984.m1423.
      Pics:
      Cincinnati, OH
      Looks like a decent kit for $649.
      Jim S.
      67 RS
      "driver "
      Dec 2012
      Ya, my thoughts as well, just want to make sure its a fairly simple swap.
      Steve
      Houston, TX
      Might want to check out Kore3.com as well. Tobin can put together a C5 kit for you, and his customer service is top notch.
      Tu Ho
      Firebird V2-LS swap
      corona,ca.
      ^^ tobins great if you need info on that set up im running it on my chevelle.
      72 chevelle.
      Lawrenceburg, TN
      Dec 2012
      I'm running 18's
      Jan 2009
      Hermosa Beach, CA
      You will be stoked on the C5 swap, those 11 inch brakes are garbage.
      This may help:
      https://www.pro-touring.com/threads/...aro?highlight=
      Pete
      1968 Camaro
      2009 Porsche 911 Carrera S
      http://www.cardomain.com/ride/2543199
      Dec 2012
      Thanks guys
      Install was perfect ...
      And fit for new wheels perfect as well ...
      Jan 2013
      Las Vegas, NV
      Looks great!! I'm assuming you went with the CPP kit? If so, did you do the custom lettering on the calipers yourself? Any tips on how you did it? Thanks, Scott
      Sep 2013
      Quote Originally Posted by Scott Atk View Post
      im interested in this as well, what did you end up going with?
      Scott
      '66 Chevelle
      Jun 2013
      Middletown NJ
      I just installed a front disc brake kit on my 72 nova. Got it from fisher bros speed shop. Kit bolted right up to my drum brake spindles. Looks great and cost $550. The offset was not changed besides the difference in hat thickness from the drum to the 13 inch corvette rotor.
      If its too loud your too old
      Sep 2013
      Quote Originally Posted by scott_fx View Post
      ping!
      any more info on your swap?
      Scott
      '66 Chevelle
      Dec 2012
      Hey Scott, yes I did go with the CPP kit, painted the spindles and the rotors (center's) black to prevent rust and the kit was a VERY simple swap in. I have not touched the front end since as I am waiting for the car to go to the body/paint shop next week. Rod, fronts are 18's and 19's rear.
      Steve
      Mar 2012
      Westcoast of Norway
      Country Flag: Norway
      Has anyone put some miles down on the CPP kit? Have been reading up on older posts on this topic, and there seem to be alot of people arguing against the CPP kit. But I have yet not found anyone that suffer from failure. I am into byuing a new suspension and brake setup on my 69 Camaro and look into different paths. Got manual drums today, and that is no good around where I live.
      Jun 2010
      Deployed
      Kore3 in my build thread, last page
      1970 Camaro/DSE build
