    Results 1 to 20 of 28
      Kiler wisconson
      CHECK OUT MY CAR UNDER THE VBGARAGE UNDER PROJECT JUST-N-SANE!
      You will never get 575 hp out of a 350 without being very expensive and very radical.. unless you use a blower.. then you are talking about $8000 to put it all together!
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
