      Sep 2013
      Rosamond CA
      disk brakes for 8.8?
      Looking for disk brakes for a shortened 8.8 axle with big ford 9" bearing ends that seems to work on this housing, what has been used, how was the installation completed?
      Thank you
      Any kit for a 9inch housing end will work. Wilwood has a few options.
      Beach Park IL
      There are two Big Bearing Ford patterns. The late style or Torino style will have a 2 1/2" offset from housing end to axle flange and will use 3/8" bolts. The early Big Bearing Ford will use 1/2" bolts and could use a different offset. The bolt patterns are different between the two.
      http://www.wilwood.com/BrakeKits/Bra...xleFlange.aspx
      I highly recommend a floating caliper with an 8.8 rear end.
      Donny
      Oct 2010
      Sacramento, CA
      Can't you just use an explorer disc set up?
      Rick - 1969 Camaro - LS1 driven daily
