    Results 1 to 3 of 3
    Thread: Need some help
      May 2013
      Need some help
      My very first post! Unfortunately there isn't a whole lot of action in the Wheels and Tires forum, so I thought I'd ask here.
      Recently began work on a 1971 Cutlass, and have my eyes on a particular set of wheels. Problem is... I KNOW it is gonna be tight. Here are the wheel specs:
      FRONT: 19x9.5 +20 offset (I believe that would be 6" backspacing)
      REAR 19x11 +25 offset (7" backspacing?)
      I am not opposed to using a small spacer of some sort if necessary, as I have not personally ever had a bad experience with them... but would still prefer not to.
      So... can these fit, or am I just TOO far off?
      Thanks!
      Welcome to the forum. Fitment will depend on the tires that you choose. The front looks fine. The rears might need a small spacer. My comments are based on the assumption that a 71 Cutlass has similar space as my 70 GTO.
      I am moving this to the wheel and tire forum.
      May 2013
      Thanks Andrew! I have admired your car many times when planning mine. Do you have any tire size recommendations?
