      Oct 2007
      What to Do... c6 calipers hit Spokes Help..
      by maybe 1/4 inch... any issue running a spacer or it better to have the wheels cut? Cutting the wheels is something i would rater not do..
      But if spacers are dangerous? thinking 1/4 inch maybe 5/16 needed..
      67 Camaro In progress
      Feb 2011
      dallas, tx
      spacers arent the best but as long as you have good wheel studs you should be fine. We are only talking a 1/4" Get longer APR studs and get the min spacer to fit. All you are doing is making the rim hat thicker. What about fender clearance though running a 1/4" spacer? Do you have enough clearance?
      I do not like the spacers that bolt onto the hubs i like a full spacer that in a way acts as a washer. Can someone weld a spacer onto your existing rims? Make sure you install the rotors and everything so you know the exact space that you need
      Oct 2007
      Not sure about the fender... going to order new wheel studs and some spacers.. may go 3/8 just to be safe.. if I have to clearance the fender lip.. so be it.. Did some reading on some vette forums and its pretty common... kinda wishing i went with the Bear brakes right now :-(
      Sep 2001
      Accord, NY
      If the clearance is tight you may be able to add a bit more negative camber to resolve. On my 69 with C4 brakes, I ran a 1/4" spacer for 10 years. I also used button head bolts in the top of the wheel well and 1* negative camber.
      68 camaro - SOLD
      Oct 2007
      Mod delete .. double post :-(
      Feb 2011
      dallas, tx
      sell your z06 brakes and but the correct ones then. They should sell quick
      May 2010
      kitchener,Ontario,Canada
      I'm in need of some Z06 rotor and caliper for the front.....already have rears
