      Annapolis, MD
      Trans slip yoke question
      How far should the trans slip yoke stick out of the transmission before you get to the part that holds the u-joint to the drive shaft? Also, what torque should I tighten the rear u-joint u-bolts/nuts to? Thanks in advance.
      -George
      Jun 2002
      Benicia, CA
      Also how far in should the trans yoke go at the minimum?
      Along the same lines, I have seen longer yokes somewhere, not sure where though. Anybody have any idea what the minimum insertion should be on a trans yoke?
      Jeff
      1971 RS Camaro: PAINKILLER
