      Granger , IN
      BLEEDING BRAKES - help
      OK , i know this is a simple process but i cant find the problem so any thoughts would be appreciated
      Im working on a 1967 Camaro - POWER DRUM BRAKE SYSTEM. ( all 4 corners )
      I have EVERYTHING new except the distribution block and the booster. everything else is new.
      for some reason , I cant get the back brakes to bleed up. after a hour of back n fourth , i get bubbles/air and a little fluid but still wont bleed up ...
      the resivoir goes down a little but not what you would think to fill the rear lines ,
      I get NO movement out of the rear wheel cylinders...
      i looked at the booser and inside the car at the booser area and THERE ARE NO LEAKS ANYWHERE...
      SO WHY WONT THIS THING BLEED UP ???
      its basic brakes so i must be having a bad brain day cause IM STUCK.
      thanks in advance , Back to the dam pole barn.
      Jeff
      The Voices in my head tell me i need more cars
      Midwest
      This works for us...
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      CA
      my guess is you need to bench bleed the master cyl again.
      1967 Camaro Rally Sport
      -under Construction-
      Mar 2012
      Texarkana, TX
      I've always had good luck with injecting fluid from the bleeders and pushing it towards the master cylinder. I'm too cheap to buy a good bleeder so, I just use a large syringe.
      63 Biscayne
      Schwartz Performance Chassis
      My build thread: https://www.pro-touring.com/showthre...ht=#post916553
      Oct 2010
      Sacramento, CA
      I made a pressure bleeder from a bug sprayer like the motive ones
      Rick - 1969 Camaro - LS1 driven daily
      Granger , IN
      I think its the master cyl... thanks for the ideas..
      the front would bleed up but not the rear.
      my guess is that the pedal got pushed to hard and possibly inverted the seal so i just ordered a new master... Go figure , you cant just get parts off the shelf for these older cars anymore ...
      i went to advanced and auto zone ...NEITHER ONE HAD R45 plugs ...or a master cyl or wheel cyl...- takes a day.LOL
      THANKS AGAIN.
