      2nd gen removing subframe or not?
      Well, I want to remove the subframe, stripit, paint it, new bushings etc. BUT I do not want to remove fenders, etc. can it be done?
      the reason I don't want to remove fenders and such is that I have a fixed idea that it will be hard to get everything back together nice again. but maybe I have to since the car was restored a few years back and is built around the old rubber subframebushings that look to be 1000years old!!
      what do you think I should do?
      and how do I do it? where to put the jackstands, what to think about, etc.
      Thanks guys!
      May 2002
      Northern California
      It can be done, i usually make bracing bars and stands.Support the body by the pinch welds at 6 points and radiator support at 4 points. Jack up the car high enough to roll the subframe out. Shutting your hood and leaving it shut is also a good idea.
      Make sure you mark your locations so it goes back in the same place. Also make sure the bodies in a spot where it won't have to be moved.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mar 2003
      Boringville
      it can be done, but most likely you will end up taking the other stuff off anyway.
      Ok, well I guess I will take the whole front off, and do it properly. I hate shortcuts accually. better to do the job right the first time.
      Mar 2003
      Boringville
      just keep track off all the shims and bolts that went in each location, also pictures of all the details will help you put it back correctly. When putting it back, have a friend or two with you, use tape on all the edges but make sure that there is enough paint on the edges that the tape won't peel it off when you take it off.
      You will ultimately be happier by doing the job the best way possible, the first time. I'd recommend taking some chassis dimensions of the car before you pull it apart, such as the wheelbase, cross-side wheel distances, etc. When you go to put the subframe back on, you will be amazed at how much slop there is in the attachement points from the factory, trust me. Try to take some reference points to parts on the body that won't move, like the pinch welds, etc. We just pulled the clip off of our 70 project car last week, and mapped everything out dimensionally, it was really surprising how poorly the stuff was made and how far off some of the dimensions were (for instance, the rear most body mounts on the subframe were off over .25" relative to each other).
      Mark
      ok, I have marked up EVERY bolt and shim. unfortunatly the previous owner of the car did a piss poor job restoring it. Many bolts that hold for example the inner fenders to the outer fenders are metric bolts AND a nut on the other side! not a clip or likewise, for shims he has used ordinary washers, even lockwashers in some places. I think I will have to re do the shiming of the car completely. He did remove the subframe and painted it and so on, but the used the old 1973 bushings!!!! the look like crap now, and I would guess they looked the same 1997 too!
      oh well now I can do it MY way, the RIGHT way :D
      Dayton, Ohio
      Quote Originally Posted by Camaro_Dan
      You might want to replace those bolts with a correct bolt kit from a camaro dealer or maybe a stainless bolt kit from Totally Stainless. My guess if he cut corners on the bolt then the rest of the restoration might surprise you.
