Results 1 to 20 of 43
Asymmetric 3link braking stability
As many of you know, I'm a strong advocate of an asymmetric rear suspension for certain applications. Such a suspension, when used with a beam axle rear wheel drive car, is capable of providing, during forward acceleration, equal rear tire loading with no squat or rise. One form of such a suspension, an asymmetric 3link, was used in the Jaguar C-Type, a Le Mans winner (with, of course, a Panhard). What is not often mentioned is that the designer of the car had second thoughts about the design, after the Le Mans win, when further testing revealed certain braking stability problems during "panic" braking. Panic braking involves complete lock-up of the wheels, a condition not encountered in the Le Mans race. It is desirable, then, to provide equal tire loading in BOTH forward and rearward acceleration modes. The normal asmmetric 3link has two symmetrically placed lower links and a third link above and offset to the passenger side (US). Braking symmetry can be achieved with the addition of a fourth link. This can restore link symmetry for equal rear tire loading during braking and yet provide equal tire loading during forward acceleration IF that additional link can only act in compression. The first Ramcharger dragrace car accomplished this with a telescoping link which "bottomed out," but a simpler design would use a front bracket shaped, when viewed from the right side of the car, as a Greek upper case gamma (mirror image of the number seven). This bracket would have two pivot points. One, located at the bottom tip of the vertical section, would attach to the front of the link. The other, at the "corner" of the gamma, would attach to the chassis. During braking, the upper surface of the horizontal portion of the gamma would press against a hard rubber pad situated between the bracket and the chassis. During forward acceleration, the bracket would "swing free," and the link would be unable to carry a tensile load. Thus, the desired situation of equal tire loading, in both braking and forward acceleration, would be achieved.
Another interesting asymmetric arrangement would consist, essentially, of a single "ladder" offset to the passenger side. Again, braking symmetry would require, for instance, a link, mounted offset to the driver side and pointed at the rear tire patch, with a bracket which, in this case, would have the appearance of the number "7" when viewed from the passenger side. This link would be unable to carry compressive loads.
For simplicity, it is assumed that the links exist in planes parallel to the XZ plane.
Tags for this Thread
