      Jul 2011
      A1A Beachfront Avenue
      adjustable or stock style PV
      I just finished installing a set of 6-piston (12.19 rotors) and 4-piston (12.19 rotors) dynapro brakes in my 65 Falcon. It's 80% street car (20% drag racing with a couple of auto-x events max). It has a Strange master cylinder under the car so I know I need a 2lb residual valve in the front and rear. This is the first car that I've put a large aftermarket brake setup on, so I'm in pretty unfamiliar territory. I've heard that the adjustable ones are a pain in the ass to get set correctly and that I should just go with a stock style one instead. I was looking at wilwood #260-11179. If I plan on basically keeping it set at one position, is there even an advantage to spending the time on the adjustable one?
      Thanks in advance!
      -Dan
