      Jun 2012
      L92 swap into 69 camaro
      Have l92 truck motor complete with wire harness computer and gas pedal what other parts I'm going to need and can I use stock ECM
      Apr 2012
      Woodstock, IL
      You can use the stock one. Are you doing a manual or auto?
      Which other parts are you referring to? We could go on and tell you that a high pressure fuel pump is needed, different oil pan, mounts, headers, etc...
      -Dale
      SchwartzPerformance
      Jun 2012
      I'm going to go with a manual
      Jun 2012
      Keep vvt or junk it? What intake also where to get harness modified ?
      Dec 2008
      Detroit
      Quote Originally Posted by 69bluecoupe View Post
      Your options are only limited by your budget. There is nothing wrong with the truck intake as long as it fits under your hood. Im not sure if it will in a Camaro? If you can't use the truck, get an LS3 intake, they are fairly easy to find on eBay and LS1tech.
      VVT is also just a matter of preference. If you're thinking in terms of cam, plenty of companies make VVT cams now so you should be good there. I would give Texas Speed a call. The have the VVT conversion kits too if you decide to go that route.
      Harness is also a matter of how much you want to spend. I would say google and read reviews the different vendors that offer rewire service. You can pay a little or a lot to have one modified. Sometimes its easier to sell yours and buy one. I think they go for @150-200 complete used. You could sell and buy one already done with fuse panel for $550. Most places are going to charge at least $300 to modify yours.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Jan 2011
      Boston, MA
      Quote Originally Posted by csouth View Post
      Agreed. I sold my old harness for around $150 on eBay and bought a brand new one for around $500 from PSI conversions.
      Dec 2008
      Detroit
      Quote Originally Posted by 67rally View Post
      Exactly what I was thinking. I ended up having mine modified by Todd at S&S Performance since I was missing a plug.
      Chris--
