      Mar 2011
      Pageland SC
      Tremec T-56 Magnum Shifter
      Any recommendations for the best short throw shifter for a Tremec T-56 Magnum, or is the factory shifter good as any?
      DK
      Jun 2010
      Deployed
      I would give the folks at American Power Train a ring, I honestly feel unless you need a special off-set, the newer magnum shifter is a good one.
      1970 Camaro/DSE build
      San Diego, CA
      Save your money and just use the Tremec shifter that comes with it. I've been using it now for a few months with a short straight Hurst stick and I'm very happy with it. Others(BlackJack, White Lightning) seem to have leak issues, no matter how many iterations they go through. Install a trans tunnel cover panel so you can access the shifter easily in the future. That way, if you decide down the road that you want to try swapping out the shifter for something different, or servicing it or changing the position, it'll be much easier.
      Chris Robinson
      1969 Camaro SS/RS G-machine/resto-mod
      Project site: http://www.69camaroproject.com/
      My most recent completed car with the base Magnum shifter rattles. Very annoying. I've tried several fixes, none of which is effective. The White Lightning (from American Powertrain) shifter doesn't rattle, but the first 4 I tried leaked badly.
      I have the fifth "new design" WL sitting here, and I'll install it next time time the customer is back.
      ​John Parsons
      Mar 2011
      Pageland SC
      Thanks for the replies, I have the shifter cover already fabricated. Guess I'll start with the factory unit, and go from there.
      Dale
