    Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 61 to 80 of 121
    1. #61
      Apr 2012
      Guys, I just installed my TKO 600 from American power train. Please take a look at this video. Is the engine suppose to lean back this much? I know they do lean back a little but not sure if this transmission mount needs to be higher.
    2. #62
      marina ca
      Quote Originally Posted by jtwoods4 View Post
      Ok guys I need some. I am trying to wire the new starter to the original harness. Please watch the video and chime in if you know what I need to do.
      Purple is the gm color for the starter. The others should you the the bat post
    3. #63
      Apr 2012
      Thanks hessdawg
    4. #64
      Apr 2012
      Well today I measured the pinion angle and started running the fuel lines. Turns out the TKO-600 is around 3 degrees negative angle (towards the ground) which is normal, we want a negative angle at the transmission tail shaft. My pinion angle at the differential was -2.6 degrees towards the ground. This is with the pro touring f-body competition leaf springs. I have done extensive research on pinion angles and most people say you want a -3 degree angle at the transmission and a +3 degree angle at the pinion. Equal but opposite angles. This is the old school way to do it and this is how most passenger cars are setup.
      After reading a book by Tony Huntimer called "How to Build and Modify GM Pro-Touring Street Machines" I deicide that a -3 degree angle at the trans and -2.6 degree angle at the rear pinion was optimal for a pro touring car that will be driven hard on road courses. Under the hard acceleration the pinion on a leaf spring car will climb, having a slight negative angle is the perfect setup for this , that is, if the PTFB competition leaf springs allow some spring wrap and aren't to stiff.
      Here is the book where I read about pinion angle. I took a screen shot of the page discussing pinion angle for a "pro-touring" setup
      http://books.google.com/books?id=Ump...page&q&f=false
      Anyway, here are the videos for the fuel line install.
    5. #65
      Apr 2012
      Fuel Line Complete
    6. #66
      Apr 2012
      This weekend I finished installing most of the engine accessories. Still need to throw in the MSD box and distributor. I also ordered a new 3 inch Chromoly Driveshaft from the drive shaft shop, should be here in the next couple weeks. I decided to go with the Chromoly shaft because it allowed me to use a smaller 3 inch diameter instead of the 3.5 inch alluminum shaft. This frees up some space in the trans tunnel. I have had cars in the past with 3.5 inch driveshafts that would knock the trans tunnel on a hard bump with passengers in the car.
      Haven't decided on a Radiator yet. I would like to use the original style shroud with the mechanical fan and clutch. Any aluminum radiator recommendations that fit well in the stock shroud?
      Anyway, Enjoy the video
    7. #67
      Apr 2012
      Now on to the distributor...
      The MSD Pro Billet distributor comes with several different colored bushings. The default bushing installed is blue and stops total advance at 21 degrees. It also has a black bushing that can be installed that limits the advance to 18 degrees, a silver bushing for 25 or a red bushing for 28. Uggggg, which one should I use????
      There are also different Springs I can install that control how quick the total timing comes in. At what RPM should the total timing come in? The default Springs bring in total timing at 5500 rpm but that seems way too high for a Pontiac. The kit includes Springs to change it from anywhere between 2000 to 5000.
    8. #68
      Apr 2012
      Well guys here it is. The first engine fire up after a year of hard work :-P
    9. #69
      The Netherlands
      Country Flag: Netherlands
      congrats, sounds great! starting a new motor is one of the best parts of a build :-)
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    10. #70
      Apr 2012
      Yeah definitely. Most exciting day of this year
    11. #71
      Aug 2006
      austin
      I would go with the default bushing. That way you can run 15 degree init timing and have 36 degrees total. Engine could prob take more, but if you're running it long and hard (road race) better to be safe than sorry.
      As for the brake lines, going from 1/4" to 3/16 should not make any dif in pedal feel. The master pushes the same volume of fluid regardless of brake line ID. The smaller ID would be more resistant to sponginess however if you're fluid wasn't 100% fresh. I guess you can make the opposite argument for resistance to boiling, but the brake fluid doesn't circulate very well. I run the motul 600 in my viper. There are more expensive fluids, but for the money it works really well. Change it every time to change your motor oil if you're tracking hard. I don't see a down side to the 3/16" lines.
      Nice build! I like your brake setup. Maybe one day I'll try those hats/rotors, but I'll use Brembo brakes off the gen 1/2 viper instead. The 13" rotor fits inside factory 17" wheels so it should work.
      Greg
      1976 Trans Am SacrilEdge
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      https://www.pro-touring.com/showthre...ect&highlight=
      https://www.pro-touring.com/showthre...ilEdge-is-free!
    12. #72
      Apr 2012
      Thank you Greg! I will be sure to use some of the high temp brake fluid like you do in your viper. Speaking of that....
      Brake line on drivers side is very close to header so I wrapped it with a 500 degree heat resistant wrap. Not sure if this is going to work so I will have to keep an eye on it.
    13. #73
      Jan 2007
      Beautiful car, one of my favorites. Nice work so far, the undercarriage brought back some memories, removing all of that undercoating is quite a job! Love the wheels too.
      WWW.SPEEDINC.COM 1957 Eldorado Brougham.......in progress
    14. #74
      Apr 2012
      Well I worked out the drivers side brake line issue. Bent the line down about an inch and got about a 1/2 inch clearance from header. Then I double wrapped the line in 500 degree constant heat resistant wrap. The double wrap should really do the job. Today I finished the alignment and the Pro Touring F-Body Pro G-Brace install. They are tricky to install with 3.75 inch tall valve covers but I called Dave over at PTFB and he gave me some great suggestions that worked. Here is the video for today.
      In the video I mention camber settings and I meant to say -.5 on drivers side.
    15. #75
      Nov 2010
      The red one goes to the battery terminal on the starter, the purple one goes to the solenoid terminal (the smaller terminal on the starter), and just discard the yellow one, its just used for the old contact type ignition and its not used with the newer types of ignition systems (MSDs and the likes).
    16. #76
      Apr 2012
      Quote Originally Posted by kamaro View Post
      Thank you Kamaro. I was wondering about that loose wire.
    17. #77
      Apr 2012
      New Magnaflow exhaust installed. Kit 15899
    18. #78
      Apr 2012
      Well after 2 days of driving, totaling about 50 miles. I started "feeling" a grinding in my clutch pedal. So I pulled in the driveway and dropped the transmission. The input shaft bearing retainer, you know the piece the throwout bearing rides on, was sheared right off! Then I looked down through the clutch and saw the pilot bearing also fell out.... what the hell.
      My only thought of what could cause the bearing retainer to shear off after 50 miles is that the clutch linkage geometry was wrong and the bearing was pressing incredibly hard against the bearing retainer sleeve. When I assembled it everything felt great.
      I have the stock original 1970 GM Clutch fork, z-bar (bell crank),pushrod, and pedal.
      I have the QuickTime bell housing
      TKO 600 transmission
      Check out the video
    19. #79
      Texas
      Really digging this build. And thanks for the vids and the education on things I was wondering about....such as pinion angle. I am not comfortable enough with pinion angles, so I'm having to have my 4 link installed by a shop.
      Great work so far!
    20. #80
      Apr 2012
      Quote Originally Posted by novajess1972 View Post
      Great work so far!
      and make sure you align your bell housing if you're installing a TKO or you will bust something like I did in the video above. luckily I am close to american powertrain so I just drove over there and Lonni swapped out the busted bearing retainer.
