    Thread: Parting 1981Z28
      Aug 2005
      Hamilton, NJ
      Parting 1981Z28
      I'm parting out a 1981 Z28 350/TH350 car. Pics of most available. (NO) = NO SHIPPING
      $125 Air Induction hood - hood, complete scoop, gas pedal w/switch (NO) 1 2 3 4
      $100 Air cleaner for air induction, nice, with new filter, & good gasket 1
      $10 Hood striker 1
      $25 hood latch parts 1
      $40 Hood Hinges 1
      $100 Rad Support - needs 1 mount pad replaced (NO) 1 2
      $200 Nose, very good (NO) 1 2 3
      $50 Front bumper support w/perfect impact strip 1 2
      $10 Nose assembly braces - pair 1
      $20 UPPER SC grille 1 2
      $10 pair Headlight buckets 1
      $5 Headlight hold down ring
      $100 RF Fender, like new, antenna hole (NO)
      $50 LF Fender, OE, looks decent (NO) LF 1 LF 2 LF 3
      $40 RF fender extension - light rust 1 2
      $25 RF inner fender (NO)
      $25 LF inner fender (2 available) (NO)
      $20 pair Frame to inner fender brackets
      $20 fender braces 1
      $125 rear bumper, very nice (NO)
      $20 rear bumper impact strip (NO)
      $10 rear bumper fillers - need work, one is probably bad
      $25 Taillights, needs lenses
      $1 each Taillight wingnuts
      $25 Gas door
      $100 Rear 3-pc spoiler, 4 outer studs missing on center section 1 2 3 4
      $20 pair Side marker lights & bezels ML 1
      $5+ misc underhood/undercar brackets, etc
      $25 wiper motor w/washer pump 1
      $10 washer tank w/bracket (no pump style) 1
      $25 Wiper arms, one damaged 1
      $10 Cowl Screen 1
      $250 Shell - great trunk pan, frame rails, tail pan, dash, floor braces, f&r w/s; solid rear window frame, filler panel (NO)
      $50 LF floor/toe board patch panel
      $40 RF floor/toe board section (NO) 1
      $5 floor plugs 1
      $40 door hinges - tight
      $2 each Misc door parts 1
      $20 pair Door vents - one has small crack at screw hole 1
      $40 door glass, each (NO)
      $75 sport mirror set - incl brackets, gaskets, hdw
      $5 gas tank strap bolts
      $5 gas tank strap (1, maybe 2 available)
      tbd all sorts of bolts, etc
      $75 Hooker 2451 uncoated Headers - nice shape (black) 1 2 3
      $20 Flex fan, like new, w/spacer & bolts 1
      $40 Radiator, great shape, aluminum/plastic tanks (NO) 1 2
      $5 stock replacement fuel pump, looks new 1
      $175 Summit Racing Carburetor SUM-M08600VS includes feed line 1 2
      $20 OE throttle cable 1
      $5 each Misc: carb, trans, AC brackets; T-Stat housing 1
      $20 OE TH350 shifter cable 1
      $25 TH350 crossmember
      $20 Misc TH350 related parts
      $20 Alternator, worked when it came out, no guarantee 1
      $15 Alternator brackets 1 2
      $35 Under dash harness (no CCC harness), fusebox, etc. generally good shape
      $20 Underhood harnesses - mostly together but not perfect. Maybe good for repair parts
      $25 Rear harness complete/uncut 1
      $5 Rear Defrost Timer Relay 1 2
      $5 Horn 1
      $125 driver quality Fischer t-tops Tops 1 Tops 2 Tops 3 Tops 4
      $30 misc t-top parts 1
      $40 T-Top trim (4 parts, also have b-pillars) 1
      $100 Black rope steering wheel w/horn cap, very nice 1
      $40 non-tilt column, with one key
      $40 Seats - all 4 - really need to be recovered (NO)
      $125 seat tracks 1
      $25 brown seat belts - rough, need cleaning 1
      $10 each Seatbelt retractor covers 1
      $25 pair A-Pillar trim 1
      $5 Misc interior panels - brown, very poorly painted black
      $40 Dash, some cracks, painted black (NO)
      $25 Door panel window crank hole covers, no emblems 1 2
      $20 Brake pedal 1
      $10 Under pedal carpet protector 1
      $40 Black 81 only auto console, small corner cut off at drivers feet; PW switch hole (NO) 1 2
      $150 Power window parts - all door parts, door jam boots, switch, harness from windows to fuse box, uncut 1 2 3
      $25 e-brake pedal assembly 1
      $5 misc under dash HVAC parts - box, vents, etc
      $5 blower resistor
      $25 AC Evaporator 1 2
      $50 lower dash, HVAC control & ashtray 1 2 3
      $10 Glove box door, painted, light scratch 1
      $50 81 only dash bezel w/HL, defrost & wiper switches Bezel 1 Bezel 2
      $5+ Misc interior brackets, etc 1
      $50 spindles
      $10 Brake booster 1
      $10 OE prop valve
      $5 each E-Brake cable frame brackets 1
      $40 front LCA bumpers w/aluminum blocks 1
      $25 stock upper control arms 1
      $25 stock steering box & pitman arm
      $25 Steering shaft. Needs rag 1
      $40 leaf perches
      $40 rear shock plates 1
      $10 3" rear shock extensions 1
      $5 Pinion Snubber 1
      $50 Front sway bar w/mounts (no end links) 1
      $50 Rear sway bar & mounts - bar has slight bend to it, nothing severe 1
      POPULAR/LARGER ITEMS SOLD/NOT AVAILABLE:
      Transmission, engine, Doors, trunk lid, Gauges
      front chin spoiler & flares, Fender Vents, Rear Fender Flares
      posi rear, headlight bezels, Z28 grilles, front turn signals, master cyl.
      SFCs, Body Mounts, shifter bezel, rear bump stops, t-top bags, grill emblem plate
      lower s/c grille, old headers, wheels 8/31/13
      Last edited by BonzoHansen; 08-22-2013 at 05:19 PM. Reason: updated list, add pics
      Scott from NJ.
      Vent Windows Forever! ...
      Aug 2005
      Hamilton, NJ
      list updated...
      Scott from NJ.
      Apr 2011
      Hanceville, AL
      pm sent on the nose assembly braces and front bumper impact strip.
      Aug 2005
      Hamilton, NJ
      list updated
      Scott from NJ.
      Aug 2005
      Hamilton, NJ
      list updated
      Scott from NJ.
