    Results 1 to 8 of 8
      Dec 2008
      west springfield, ma
      electrical temp gauge issue
      So i have the sending unit wire going from the trans line where i put the T fitting in, up to the gauge and wired to "sending unit" stud
      I wired the ground to an existing good ground.
      Now all i thought was i had to wire the positive into an existing power wire to another gauge or right into the fuse panel because i have room to put one in there.
      Once i have it all connected and turn the car on, the gauge jumps all the way up to hottest number on the gauge. (I know for certain the tranny is not that hot)
      I tried disconnecting the sending unit wire and left the ground and positive on and it does the same thing.
      Any ideas? Thanks
      Mar 2004
      Mid-Michigan
      The sending unit is probably not getting a good ground. How do you have that installed?
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Dec 2009
      Pretty sure Astro is right. It's a ground somewhere. Just went through this same problem last weekend.
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Jun 2005
      Sender grounded?
      Anthony
      http://www.cardomain.com/ride/674663
      '71 Datsun 510, 2jz-gte (Supra TT) engine
      http://instagram.com/supra510
      Dec 2008
      The sending unit wire came with a little fish eye that is crimped on and tightened down with the nut that's shown in the pic. That wire just goes up to the back of the gauge and connected to the sending unit post. Then the ground post is wired to the firewall with a previous good ground. And the positive is wired in sync with the volt meter positive post.
      Apr 2012
      Woodstock, IL
      The sending unit itself needs to be grounded. That means a wire from the npt threads on the sender to a good ground.
      -Dale
      SchwartzPerformance
      Dec 2008
      Just tried that, still jumps all the way up.
      Nov 2011
      Virginia
      These work by varying resistance to ground. In the gauge pegs then you have an open circuit or a short to ground (depending on which way the gauge is designed). Time to check the wiring. Disconnect the sending unit entirely and power the gauge to see how it behaves then. With KOEO ground the sending unit wire to a chassis ground and check gauge behavior. Could be a bad sending unit.
