    Page 1 of 6 1 2 3 4 5 6 LastLast
    Results 1 to 20 of 109
      Jan 2009
      Let's talk anti-roll bars
      I've been testing and tuning my '69 Camaro with DSE underpinnings this year to get it to drive they way I want. I've played around with springs, sway bars and tires to try and get the car as neutral handling as possible. I try to only make one change at a time, but occasionally I will have to make two, i.e. if I'm replacing tires, sometimes I will change brands and throw on different springs as well.
      Now, to what I wanted to discuss, is there a point where stiffening the rear of a car will decrease grip at the front, and/or increase grip at the rear?
      Of the changes I've made, increasing rear sway bar stiffness seemed to increase the amount of understeer into transitional oversteer that I experienced. Additionally, I recently made a change to the front of the car. I increased spring rate and deccreased roll bar stiffness to try to get the car to have less brake dive with similar steady state cornering, but ended up with a car that seemed to put power down exceptionally well but exhibited more understeer, especially applying power with slight steering input. I'm curious, can limiting the amount of roll on the back of the car keep the outside front from loading up with weight, and "biting?"
      Matt
      Nov 2012
      Sacramento, CA
      Hey Matt,
      so we all can have a better feel of what you're doing ... can you share all the details of your suspension ... tire brand & sizes, spring rates, anti-roll bar types & diameters, type of shocks, type of rear suspension (assuming it is a double A-arm front suspension) ... and front end geometry if you have it?
      Plus ...
      How heavy is the car?
      Power output, trans & gear ratio?
      What type of driving are you doing ... AutoX, road courses?
      That will help get us all out of the dark to be able to engage in somewhat educated conversation.
      Lawrenceburg, TN
      yea!!! Matt tell me all about your spring rates, anti-roll bar types & diameters, type of shocks, type of rear suspension.......really I noticed the same thing I increased the rear bar on the car and stiffened the shocks and ended up with more traction
      Nov 2012
      Sacramento, CA
      You're funny Rod.
      I think I can tell you what's happening ... and why ... but I want to be sure of the set up ... so I don't stick my foot in my mouth. I wouldn't want to make assumptions & jump to the wrong conclusion.
      You know what happens when you make assumptions ... right? You make an ass out the umptions. (Hmmm ... that didn't sound right).
      Jan 2009
      Hey Ron, funny you should ask for details. I'd originally typed out a ton of details and then deleted them because I thought it might be better to talk from a broader conceptual level at first. I was hoping it might draw more people in, especially if they had personal experiences and questions of their own.
      Here are the details:
      1969 Camaro with 454 LS7 (gen IV), T56 Magnum, 3.73 gears, 18x9 and 18x11.5 wheels with 275/35 F, 315/30 R tires. DSE subframe and quadralink. 3500lbs with a full tank, sans driver. 51/49 F/R weight distribution. cross weights are pretty close. I think the biggest short coming of the car, which I am currently addressing is the narrower front than rear track width.
      Anyway, I started the year with 450lb front springs and a .250" wall front bar with 250lb rear springs and DSE's 1-1/8" rear bar on the softest setting (of two settings). The car had pretty good bite and turn in, but it was wearing the outside tires badly and it was the tire was being overloaded because it would skip, or hop once before taking a set. The easiest adjustment I could make at the time was to adjust the rear bar and stiffen it up since pretty much any tuning guide says to soften the front or stiffen the rear to reduce understeer. Seeing as the front felt too soft I stiffened the rear, only to notice that I now had decent initial turn in with terrible mid corner push turning into transitional oversteer, making the car really loose putting power down.
      Eventually I arrived at a set up I was reasonably happy with. 575lb springs/.250" bar front and 300lb/1-1/8" bar on the stiffest setting. I ended up changing though because the rear shocks I had were shot, so I put in working shocks (JRI) and replaced the springs with 275 to test. and I also wanted to give Falken tires a try. These changes gave me understeer that was most noticeable on turn in, but the functioning rear shocks greatly fixed traction issues as I used to start losing traction on auto crosses mid way through a straight since the rear springs wasn't being controlled.
      In an effort to smooth turn in transitions I changed the front to a stiffer 700lb spring and softened the anti roll bar to .120" wall thickness with the hope being that it might solve the lack of turn in under braking. The car has always felt it never wanted to respond to trail braking, with the best turn in happening when the car was slowed and without your foot on the brake or gas.
      I know there is probably no such thing as too much information, but there are a lot of different little things going on, and as I'm sure you know, fixing one thing always changes something else.
      Matt
      Nov 2012
      Sacramento, CA
      That is great information that helps me to have a little clearer picture. I still need a "few" more details.
      When you talk about your front sway bar, you mention wall thickness but not diameter. Please post the diameter ... and effective bar rate ... if you know it.
      In the rear, you mention having the 1-1/8" sway bar on the stiffest setting. Please post the effective bar rate for it too ... if you know it.
      Are you on a coil-over setup or separate shocks & springs ?
      Did you put JRI shocks on all 4 corners ... or just the rear?
      Lastly, are your results coming from driving in Autox or big road courses?
      Thanks, Ron Sutton
      Lawrenceburg, TN
      Matty, I think were both using the hyperco springs I ended up with 200 lb rears and 700 fronts, but hell you know that works I could change next week, I think that some of the lack of trail braking is also tire offsets, I noticed that scenario at Del Mar with the 10" rim on all for corners I had 0(zero) trail brake I switched to the smaller 8" inch 255 front wheel set up front and the turn in was quicker mid way in the turn allowing the rear to come around, instead of pushing through the corners
      Jan 2009
      Rod, we are both using Hyperco springs, although I have a stray set of AFCO ones that Cris let me borrow to test (300lb) and a few sets of DSE branded ones on the shelf.
      Ron, here is a chart from Speedway showing the bar rates. You will want to look at the 1-1/4" OD listings. Forgive me though, because I don't know what the length of the arm is. I think it is either 10" or 12."
      The rear rates are:
      Front Hole: 344 lb/in. Rear Hole: 402 lb/in.
      Matt
      Nov 2012
      Sacramento, CA
      Matt,
      Nov 2012
      Sacramento, CA
      Matt,
      Nov 2012
      Sacramento, CA
      For clarity sake, Matt … please read this and make sure I am interpreting your writings correctly. If not, copy, paste & edit into the next post.
      Your car is a 1969 Camaro with 454 LS7 (gen IV), T56 Magnum, 3.73 gears, 18x9 and 18x11.5 wheels with 275/35 F, 315/30 R tires. DSE subframe and quadralink. 3500lbs with a full tank, sans driver. 51/49 F/R weight distribution, with “close” cross weights” & narrower front than rear track width.
      You have had basic 5 suspension set-ups:
      Front Springs: 450#
      Front Sway Bar: 447#
      Rear Springs: 250#
      Rear Sway Bar: 344#
      Notes: The car had pretty good bite and turn in, but it was wearing the outside tires badly and it was the tire was being overloaded because it would skip, or hop once before taking a set.
      #2
      Front Springs: 450#
      Rear Springs: 250#
      Rear Sway Bar: 402#
      Notes: I stiffened the rear, only to notice that I now had decent initial turn in with terrible mid corner push turning into transitional oversteer, making the car really loose putting power down.
      #3
      Front Springs: 575#
      Rear Springs: 250#
      Rear Sway Bar: 402#
      Notes: I arrived at a set up I was reasonably happy with.
      #4
      Front Springs: 575#
      Rear Springs: 275#
      Rear Sway Bar: 402#
      Additional Changes: Put JRI Shocks on the rear & Falken Tires all the way around
      Notes: These changes gave me understeer that was most noticeable on turn in, but the functioning rear shocks greatly fixed traction issues as I used to start losing traction on auto crosses mid way through a straight since the rear springs wasn't being controlled.
      #5
      Front Springs: 700#
      Front Sway Bar: 295#
      Rear Springs: 275#
      Rear Sway Bar: 402#
      Notes: These changes seemed to increase the amount of understeer into transitional oversteer that I experienced & ended up with a car that seemed to put power down exceptionally well but exhibited more understeer, especially applying power with slight steering input.
      Do I have this correct ?
      Ron Sutton
      Lawrenceburg, TN
      I'm liking this!! now were talking real, fun, stuff,
      Quote Originally Posted by Ron Sutton View Post
      Front Springs: 450#
      Rear Springs: 250#
      Rear Sway Bar: 344#
      #2
      Front Springs: 450#
      Rear Springs: 250#
      Rear Sway Bar: 402#
      #3
      Front Springs: 575#
      Rear Springs: 250#
      Rear Sway Bar: 402#
      #4
      Front Springs: 575#
      Rear Springs: 275#
      Rear Sway Bar: 402#
      #5
      Front Springs: 700#
      Rear Springs: 275#
      Rear Sway Bar: 402#
      Ron Sutton
      Jan 2009
      Front Springs: 450#
      Rear Springs: 250#
      Rear Sway Bar: 344#
      #2
      Front Springs: 450#
      Rear Springs: 250#
      Rear Sway Bar: 402#
      #3
      Front Springs: 575#
      Rear Springs: 250#
      Rear Sway Bar: 402#
      #4
      Front Springs: 575#
      Rear Springs: 275#
      Rear Sway Bar: 402#
      #5
      Front Springs: 700#
      Rear Springs: 275#
      Rear Sway Bar: 402#
      Ron Sutton
      Ron, that is 99 percent correct
      On setup #4 I changed rear springs from 300lb to 275lb. JJ at JRI and I discussed between the 250-325lb rates I had on the shelf and put the 275lb springs on as a starting point since I was also swapping in rear shocks that had nitrogen, and well... functioned.
      Oh, and before I forget, I do have JRI shocks on all four corners. They have low speed rebound adjustment, and a high speed damping adjuster. I can also add or drop pressure.
      Thanks for your interest in sorting things out
      Matt
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by 69MSA View Post
      Matt
      In which stages (1-5) did you have the 300# rear springs on ?
      All JRI shocks come with a dyno sheet. Can you scan & post them please? We won't start with shock tuning, but we will finish there, as that is what shocks allow you to do ... fine tune & dial in a good spring & Anti-Roll Bar package.
      Lawrenceburg, TN
      thread HI-JACK! hey Ron that logo is familiar, I meet you at Pleasanton didn't I? you should have went for a ride along, OK back to your regularly scheduled program
      Nov 2012
      Sacramento, CA
      Yes, Rod. I stopped by & looked at your baby while I was at the last Pleasanton GG event. Checking to see if you were running same size tires on all 4 corners.
      Sorry I didn't introduce myself. I was visiting Brianne & Mike Maier most of the day.
      Mar 2012
      Escondido CA
      Matt, your suspension sounds like its working to eliminate too much roll, which is backwards. You want to ENCOURAGE roll, I included pics to show how it SHOULD look:
      See how the front wheels appear to be pointed AWAY from the Apex, thats a great sign things are going well.
      In this one we see the benefits of a 230(+) pound "driver"... Im getting the most grip possible from the outside edge of the left side tires.
      1973 Corvette Factory Primer Car
      1969 Barracuda Convertible
      1967 Plymouth Valiant
      Mar 2012
      Escondido CA
      No comment needed, however, note the front left wheel / rear bumper angle. Almost perfect!
      Apr 2007
      Quote Originally Posted by Tomswheels View Post
      I've been mulling this over two different nights, and decided to "call" the poster and his friend on this:
      It the above sarcasm? Obviously you want the left front wheel not to look anything like it does. You want it to have the same relation to vertical as the left rear wheel does in that photo. The only excuse to have your left front wheel looking like that is it is a compromise when you desperately need the outer (right front) to do something that can't be achieved with your hardware any other way.
      Lets talk this out.
      Jan 2009
      Tom, I saw your Barracuda tearing up the Good Guys peanut course, and when I went for a ride I was afraid of capsizing. Perhaps that fear caused me to overcompensate by limiting weight transfer too much on my car.
      Matt
