    Results 1 to 20 of 37
      Santa Clara, CA
      Identifying connections on Magnum T56
      The shop that put the drivetrain into my car never sent me any of the original paperwork that came with any of the new parts they installed, including the T56. The guys at American Powertrain were nice enough to e-mail me the Installation Instructions, and while those were helpful, they didn't answer all of my questions, therefore, here I am with hat in hand hoping that the shared wisdom of Pro-Touring.com can help me out
      So, I learned from the instructions that if you're planning on using the electronic speedometer connector on the trans, you should replace the rubber shipping plug for the mechanical speedo with a specific part, so I'm working on procuring that. But I'm also trying to figure out what all of the electrical connections are that are on the unit and where they are all located....
      I'm thinking there is the VSS connector, the reverse lights and the reverse lock-out solenoid? Anything else electronic on the trans?
      Does my car (67 Camaro with an original 4-speed) expect to have any kind of input provided to it, other than the reverse lights? 4-speed car wouldn't need neutral safety switch input, correct? What about a clutch engagement signal?
      Sorry for the crappy pic but here's some of the specifics that I'm confused about. Thanks.
      Steve
