    Results 61 to 75 of 75
      May 2013
      Moody,Al
      [QUOTE=GEARBOXGARAGE;1085015]Here's our C10's engine bay and when it was on display at the Holley booth on Power Tour for the Knoxville, TN stop.
      Hey Mike, are you using the Terminator setup? If so, could you please give me your impression of it and the specs of your motor? I'm thinking of this for a BBC. Truck looks great by the way!
      Guy
      Jun 2013
      Colon, Michigan
      Guy,
      Sorry for the delay in responding. Yes, we are running the Terminator set-up and really like it. It's on a 355 with about 10:1 comp., GM Performance Hot Cam, Edelbrock E-Tec heads and Performer RPM intake. Quite the little screamer! Keep in mind that most of these bolt-on EFI kits are designed to get you running out of the box, but do require fine tuning as you put more time on them. The Terminator is set up with several fuel maps to choose from: Stock, Mild Street, Street/Strip, and "I Don't Know". Yes, that is an actual fuel map you can choose, LOL. Most likely for those that have a motor that they are unsure about what is inside for specs. Initially, we went with the Mild Street and used this map on the majority of the Power Tour, and played around with some of the other maps, but came back to the Mild Street and worked on the tuning. I did notice a few lean spots on the Tour, but Luke Embry from Holley helped me out on some tuning to clean it up some, and I've been fine tuning it here and there. The more I drive it, the better it gets! I've heard of some people putting various throttle body kits on and not liking them, but like I mentioned, they are designed to get you going out of the box, just like a carb, but every engine is different and they need to be fine tuned for each application. The tuning can all be done with the handheld unit that comes with, and if you're real tech-savvy, you can plug in a laptop and dig into it further. I have probably over 4,000 mile on it now with no issues. The biggest thing to remember when you start to fine tune it, is to change only one thing at a time, drive it, see if it is better or worse, and tune some more. The seat of you pants will tell you for sure. Hope this info helps answer your questions.
      Thanks for the compliment, by the way!
      Later-
      -Mike
      Orangevale, Ca
      Bret Ervin
      Jun 2014
      Something I'm slowly getting together.
      Jul 2013
      St Louis
      Im pulling my engine to do a few things and have been trying to decide if I want to paint my engine body color and leave the rest of the bay black or do my engine in black and do my fender wells in body color leaving the firewall black. Any thoughts?
      Pontiac Powered 72 GTO
      summerville,sc
      97 s10 with l31 vortec
      Mar 2015
      Here's my baby...225 slant six in a '77 Dodge D100. The turbo is non-functioning as of now, but it will be. It's just a sort of "mock-up" picture to see exactly how much room I have for a custom turbo header and such...which ends up to being PLENTY! I just don't know if I want to stick with a turbocharged slant six for the "WOW" factor and be completely different than the usual 318/360/400/440 guys, or if I want to do a 5.2/5.9 Magnum swap...I have a long while to figure it out.
      Jun 2013
      Colon, Michigan
      Here's our engine bay on the cover of the Motorstate Distributing Engine Builder Catalog on the lower right.
      -Mike
      Aug 2011
      North Platte,NE
      Engine bay
      Feb 2013
      Airdire, Alberta
      331 with t76.Name:  P1020962 (Copy).JPG
      Oct 2015
      Binghamton, NY
      02 Silverado
      Name:  AMn4wKnYJdQ_87_WvqGQOSr8HGvUXrUK8kC23Tz_Yhi8YjLZ93ByHyC5vjo16BNB6Do6_sQNPuT005a5c_sgCnbsOdXWd4BX.jpg
Size:  18.6 KBName:  ec381f1a-4e73-4cc2-a977-babf02a7b774_zpsdc2xqjrb.jpg
      Jun 2014
      braintree essex england
      Country Flag: UK
      my 79 trans am
