    Results 1 to 20 of 20
      Mar 2013
      Oakdale, Ca.
      Is Adding Weight Cheating?
      I've been working on a slide weight system for the back of the truck.....make a turn and weight moves to the opposite corner of the truck (vise versa). So, is this cheating or just a engineering edge? Your Thoughts?
      George Dias
      1973 Camaro
      2002 SVT Lightning
      2003 Z06 Corvette
      2015 Truckin Throwdown Champion http://www.trucktrend.com/events/tru...by-ebc-brakes/
      Dec 2010
      Fredericksburg, VA.
      I would call that transferring weight not adding weight. Whether or not it is cheating I guess would depend on the rules of the event.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Colorado Springs
      The rules in the events I have been involved with would call that cheating. They have all specificlly forbidden it. However, this was in sanctioned oval track racing, not any pro touring, free for all, limited rules type thing like Goodguys event. Other organizations that are highly organized and very competitive because of the diversity of classes, like SCCA and Nasa, probably forbid it too.
      TonyC@HP2
      Indiana
      No one will care until you're fast.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      ^^^ and SCCA rules say that if it is not in the rules that you can do it, means that it is not allowed. it also states not to over think the rules.
      I think its a cool Idea! but I think you F-ed up by asking, you should just done it and made is inconspicuous.
      Dec 2011
      Sep 2007
      How on earth is it helping you to shift weight towards the outside of your vehicle during a turn?
      Is it a fore-aft shift that makes the difference?
      Im with the post above, don't you want the weight on the inside of the turn?
      Beach Park IL
      It's not cheating, in fact, your competitors will be glad you did it.
      Donny
      Aug 2011
      Sevierville, TN
      Quote Originally Posted by alocker View Post
      No it offsets the weight to keep grip on both rear tires instead of all the weight being on the outside causing it to lean even more.
      Matt Kenner
      68 C10 stepside
      If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower. - Mark Donohue
      Morehead City, NC
      There was a device in the sixties called an Auto Safety Stabilizer that did exactly what you are considering. NC Highway patrol had them in the big Mopars they were using. It was a box that was maybe 6 x 6 x 30" long. Very heavy for it's size. Mounted in the truck directly above the axle. I had one in my 66 Chevelle that I acquired from a friend that worked in the HP body shop. It did work. As you entered a corner the body would start to lean ,then there was a fairly sudden correction. Rumor was that King Richard got caught with one by NASCAR. They were more commonly called gyros. As to your original question, weight is your enemy. Lighter is faster.
      Mar 2013
      Oakdale, Ca.
      Quote Originally Posted by Mike Holleman View Post
      My first post was a little confusing but yes, this is what I'm toying with.
      George Dias
      1973 Camaro
      2002 SVT Lightning
      2003 Z06 Corvette
      Mar 2013
      Oakdale, Ca.
      First post was confusing....my bad. Yes, weight will slide to the inside corner to help with traction.
      George Dias
      1973 Camaro
      2002 SVT Lightning
      2003 Z06 Corvette
      Jul 2012
      Traverse City, MI
      Funny this question was asked. I just a long square tube on craigslist that came out of a Cadillac. The guy called it an anti-sway device and said it was filled with mercury and weighed in at almost 66 pounds.
      So this has been done before. But I dont know how it could benefit.
      Project thread - https://www.pro-touring.com/threads/...ouring-Project
      IG - @tc_chevelle
      Jul 2008
      Southern Indiana
      Your good to go at Goodguys, will be interesting to see it work.
      Central CA USA
      SCCA does not allow moving weights.
      Aug 2006
      San Francisco, CA
      I think you only want to add left/right ballast if you need to achieve a class minimum weight.
      And, the translating weight should be below the roll center of the car. Otherwise, no matter how far to the inside it translates, it will still add load to the outside tire(s) and it will just hurt your cornering ability more.
      Also, think about the acceleration/deceleration of the ballast as it moves across the vehicle...it could really mess with the vehicle transitions.
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Mar 2013
      Oakdale, Ca.
      Quote Originally Posted by ohsolow View Post
      Quote Originally Posted by David Pozzi View Post
      Thanks for the info.
      George Dias
      1973 Camaro
      2002 SVT Lightning
      2003 Z06 Corvette
      Dec 2010
      Although I've always loved a pickup truck's ride qualities with a couple hundred pounds of concrete or firewood added, the cornering prowess of said vehicle did not seem to improve with the high-mounted (bad) additional weight. One would think that a decent airbag system would however be able to monitor shifting loads effectively, but then again, air doesn't (seem to be able to) move quickly enough for an autocross corner transfer sequence...
      As has been said above, it seems that removing stuff is usually better than adding (see quotes by Colin Chapman/Mr. Lotus). As an example, rather than getting taller lowering blocks, I recently subtracted a leaf from each of my (super high-tech/modern rear leaf) springs. The ride has been softened a bit, but will hopefully be compensated for with shock adjustments (and quality)...
      It was cool seeing your pickup truck out at Marina a few weeks back--it's a great wave in the sea of Corvettes, Camaros, and that revoltingly quick turbo Porsche!
      Sep 2007
      I know Petty was stacking all the ballast weight to the left (inside) side of his car in about 1967. But I don't think he ever used a method of shifting it on-the-fly like that. He also manually lowered the front end height on his car with a socket once he got onto the racetrack, but that was a different thing.
      But there was no rule against these kinds of things at the time, so it didn't qualify as cheating when NASCAR found out what he was up to. NASCAR just outlawed it from then on. That sort of gray-area stuff was standard practice for NASCAR racers at the time. Still is.
