      Feb 2012
      Headliner tack strip
      Planning on installing my own headliner, or at least gathering up all the parts. Do I need the tack strip? All the vids I've seen dont show it. Found this and wondering if I need to buy it.
      Attachment 79447
      Tacoma, Wa
      To pull the headliner material taught behind the b pillar they are required. I had to source mine from a yard. As far as I am aware they are not available repro.
      Brian
      68lovebuzz
      68 Camaro, LS6, TKO 600, Moser 12 bolt 3.73 W/Eaton LSD, hotchkis/bilstein, KORE3 C5 brakes, RUSHFORTHs and a few other tweaks ; )
      Templeton, CA
      Just went through this with my 68. Buy it!! I only found one place that sold the front tack strip ($100 used gm). The rear everyone has! You need the front for the headliner molding to attach to.
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
