    Results 1 to 17 of 17
      Feb 2007
      cooling fan controller?
      What would the best cooling controller to buy?
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Beach Park IL
      Donny
      Indiana
      I have this on my Elky and Chevelle... http://www.spal-usa.com/fans/automat...es/fanpwm.html and it's water resistant so you can mount it anywhere.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Feb 2009
      muggy midwest
      What fan or fans are you planning on using? That makes a big difference....
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Newbury Park, CA
      The Spal units have been discontinued.
      Jul 2009
      New Jersey
      I'm running this:
      http://www.flex-a-lite.com/accessori...re-sensor.html
      I had the controller crap out on me, but they sent a new one ASAP free. No problems since. I like that its variable, and will run one or two fans when needed. It also has start up protection which basically means it will not come on for 6 seconds so all power goes to starter. Relays are all there with no added stuff to buy. Yes, you can make your own, but this is easy. Has a probe for radiator, or a screw in type sensor. I've had the big block out in 95 degree heat and the controller performed flawlessly. FWIW, I am running 2 Spal 10" fans in a Speedway aluminum shroud. Lots of people have trouble with 1st Gens and electric fans, but mine never has any issues.
      I also like the Dakota digital one, but the Flex a lite is basically plug and play and that was my deciding factor on the 67.
      RJ Cilurso
      67 Camaro with a few things bolted to it
      12 Camaro with a few things bolted to it
      50 Chevy 5 window p/u with a few things unbolted
      USAF
      I love this unit. The programming can be set up to run off of the gauge sender eliminating one more wire to the engine. Lots of options. I have it set to run 30 seconds after shut down
      Indiana
      That's a bummer! The ones I have work great. Now I have to go a different route on my truck.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Jul 2001
      Calgary, AB
      I just bought the DD one for our SuperBee project - seems to be a nice piece with lots of adjustability. It's a bit of a pain on a "done" car since it has to be installed inside the cabin but the fact that it can share the autometer gauge sender is a huge plus - especially on a dodge with few options for sensors.
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
      Sep 2007
      York, Pa
      Quote Originally Posted by James OLC View Post
      Is the Dakota Digital piece progressive or is it just like an adjustable on/off switch?
      Justin Snow
      Houston, TX
      Quote Originally Posted by GNon18s View Post
      It's an adjustable on/off switch. For pwm fan controller, Painless makes one but it's expensive.
      Tu Ho
      Firebird V2-LS swap
      Illinois
      I Have been Very Pleased with my DC Controls Fan Controller - http://dccontrol.com/constant_temper...ontrollers.htm
      I have been running this setup since 2006 and it works like a charm even with HIGH Amp draw fans ! This is used on my 11:1 450HP Pontiac 455 CI and have never had issues.
      The DC Controls Fan controller works flawless. Its great the controller starts up the fan @ 50% so no real high amp draw, and it regulates the speed of the fan as needed to keep the temp steady. A real nice feature about this controller is the maintained engine temp, rather than unsteady temps caused by cheap on / off relay temp swiches. The cheap units kick on when the engine gets hot , then kick off when the engine gets cool, kicks back on when hot, back off when cool...........lots of heat cycles, rather that maintaing a temp.
      No more WWHHHOOOSSSSCCCHHHHH...... sound from the flex fan.
      Beebe
      A link to some pictures of my Firebirds and other toys
      http://community.webshots.com/user/ponchoman69
      Feb 2007
      Thanks for all the input guys I will take a look at them all
      Brandon Slater
      1979 Z28
      1972 Nova
      Texas
      Quote Originally Posted by BEEBE View Post
      I Have been Very Pleased with my DC Controls Fan Controller - http://dccontrol.com/constant_temper...ontrollers.htmBeebe
      I've always been a little unsure which of those two one needs to use - and the instructions don't say anything about dual fans but I assume they can be used.
      -Bob (66 Nova)
      Sep 2007
      York, Pa
      Quote Originally Posted by BBPanel View Post
      Sounds like the DCcontrol stuff would work good but their website isn't very clear on anything. I think you would need to call them to clarify what the hell you would need.
      Justin Snow
      Sep 2007
      York, Pa
      I just ordered the Painless unit (#30140) from 4wheelparts for $229 shipped. ...wish me luck
      Justin Snow
      Texas
      .... I think you would need to call them to clarify what the hell you would need.
      Hmmmmmmmmmmmm, I can tell you've never tried to call them
      -Bob (66 Nova)
