      Feb 2012
      Pro Touring 1980 TA
      Hey guys im working on my 1980 trans am used to be my fathers car a while ago and he gave it to me when i was 13 so now 10 years later I'm ready to build this car the way i think a trans am should be. The car has DSE mini tub kit and tubular a-arms 2" lowering springs and solid body bushings. The engine is a 461 Stroker Pontiac making 550Hp 600Lb ft of torque backed by a Tremec t56 Magnum trans with a mechanical clutch bellhousing from quick time. The rear is a fab9 narrowed with true trac and 3:89 gears the wheels are 18x9 and 18x12 Year One billet snowflake wheels and the whole thing is going to stop with C6 zo6 brake kit from kore3 and a hydroboost set up by hydratech im having a roll bar welded up inside and Corbeau A4 seats and im going to fit autometer gauges in the engine turned dash bezel
      This is how the car started
      Then it went into paint jail
      Then the mini tubs were installed
Size:  223.0 KBName:  IMG_0181.jpg
      Mean while i worked on restoring the subframe I had it sandblasted and i painted it with POR15 and added new stainless fuel and brake lines
      Had the firewall smoothed
Size:  117.3 KBName:  IMG_2225.jpg
Size:  86.0 KBName:  IMG_3088.JPG
      Then the body was mounted on the subframe
      Then Finally the fenders
      Bolted up the rear suspension
      And finally the car sits on the ground again
      California City Ca.
      Nice love those 2nd gen ta's
      Dale Hayes
      87 turbo t
      Dec 2009
      Alright! Lets go for another second gen bird, loveum
      Mar 2010
      Valencia, CA
      Good work on your T/A- thanks for keeping it Pontiac Powered. What size rubber do you have on your original snowflakes? It doesn't look too bulgy for 15's and I need new rubber for my 76 TA.
      Geno
      Apr 2010
      Portland, OR
      Looks great!!! Lots of trick parts in there! Can't wait to see more!
      1973 Firebird 466 Pontiac, T56, C5 Brakes, PTFB and Hotchkis suspension
      2011 Camaro SS Supercharged, ZL1 body and brakes, Z28 suspension.
