Results 1 to 11 of 11
Thread: No Power at Key When Hot!
07-07-2013 #1
- Aug 2007
- 271
Here's the run down: 68 Camaro SS, built sbc, 4 spd. Bought the car late last year and only now had the chance to put some miles on it.
Car starts and runs great but after it runs for several miles and you shut off the engine, it will not fire. Nothing at the key: not even clicking and yet I have lights, horn, radio, etc. I might also add the battery is new with newer cables and running a mini starter. It's done this several times now. Once, I replaced the battery and thought it solved my problem, nope! When it happened again a few days ago I installed a new ignition switch and thought that had it, well apparently not. Came home from a cruise last night, shut it off in the driveway and when I hit the key a few minutes later to go into the garage...nothing. I tried to jump it, nothing. Push started it and it fired up. First thing this morning she fired right up like new again.
This is very frustrating, all electrical connections are tight and not touching any heat source, any suggestions?
Tom Koontz
