    Results 1 to 9 of 9
      left coast
      Roll bar question
      Since the inside of my 66 coupe is gutted, I thought this is the best time to toss in a roll bar. I'm still considering 4 or 6 pt, but need a question answered to help me better understand Solo and NHRA guidelines. I doubt I'll hit the 11.50 ET rule for now. A base plate thats bolted in place requires a plate above and below the floor pan, bolted together using four hardened bolts, correct? If welded in, do you still need the bottom plate under the floor pan? Thanks.
      Mar 2011
      Ca
      its been a while since i've gone through the rules but if i remember correctly i don't think you need the bottom plate if you weld the base plate in. as for points, just do the 6 pt now so you don't have to go through this again, plus it'll add a bit more stability to the car over just the 4 pt.
      Nov 2012
      Sacramento, CA
      I agree with Sam on both counts.
      Only top plate is required if you're welding it in.
      Nov 2012
      Sacramento, CA
      Groho,
      If you're looking to provide yourself & passengers improved safety ... not just comply with the rules ... go read THIS.
      Nov 2012
      Sacramento, CA
      Hey Groho,
      What did you work out for your roll bar?
      Mar 2014
      Lone Star State
      Ron, I just read your other post and was very impressed with your thoroughness and not wanting to compromise. With that being said, I was looking for a cage for my 67 Fairlane and was wondering if you had any companies you could refer me to. Thanks for your time.
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by 67Fastlane View Post
      Chris Alston's Chassisworks offers the best fitting & best quality cages.
      Mar 2014
      Lone Star State
      Thanks Ron!
      If welded in you only need the top plate completely welded. Where are you located? A custom bent cage is the best.
