Results 1 to 10 of 10
Thread: Engine Combo Questions
Thanks for the input guys !!!
carguykeith - I actually had the 1.52 rockers before I picked out the cam I have now. I didn't see much point in buying new rockers which are 1.6 rather than 1.52 for a street engine since I'm not looking for that last bit of horsepower. If they ever need replaced, then I'll get the 1.6.
Ron Sutton - I appreciate the reply. I've read a bunch of your posts.
I know this won't be the most economical motor ever built, I'm just tryin to maximize what I have. I know if you drop an engine too far down in the rpm band it's just as bad as too many rpm as far as best mileage is concerned. Is 1600 - 1800 too low or is 2000 - 2400 rpm too high *for this combo* is basically what I'm wondering about. Once I get the rpm range nailed down, then I can determine my rear tire size and gear ratio to hit that desired rpm range.
Doug Gulley
66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
