      New Taxes York
      Proper power circuits for ECM?
      Hi all,
      Tried firing up the '06 LS2 (E40 ECM) last night without success.
      While I troubleshoot, I want to cover all the bases. One in particular I'm not sure on... I have IGN1, IGN3 and BATT+ fused circuits to the ECM powered. Does an ECM require the ACC power circuit as well?
      It'll crank fine, but not start. I had the ECM and TCM re-flashed by PCM of NC to turn off VATS and emissions. I don't see any codes relating to VATS come up when I scan it. Just one about TCM communications and an emissions code.
      I haven't had the chance to fully troubleshoot yet so that's all I know right now.
      I removed the Park\Neutral Safety switch from the 4L65 trans gear selector shaft because my '69 Camaro uses the one on the shifter. The harness connector to the switch isn't jumpered or bypassed. Is that required, or can I let it dangle for now?
      Thanks! Itching to cruise!
      Joe
      New Taxes York
      Jun 2010
      Deployed
      Have you checked to see if you have spark? Is the ECM getting power while you are cranking? If you have it tied to a circuit that gets cut during cranking, it won't start.
      1970 Camaro/DSE build
      Metamora, Illinois
      In addition are you getting fuel? Prime the fuel pump and check the pressure at the fuel rail. Also check your grounds and your fuses.
      New Taxes York
      Hey guys.... thanks.
      No spark, but that's because the coils aren't firing, due to the fact they're not being fed 12v. I didn't know that at first. All fuses are good and I have plenty of grounds everywhere.
      It took me a while to find the circuit(s) on the schematics. Now I'm wondering WHY they don't have power to them. There aren't any connectors or bulkheads that aren't accounted for. I don't know where the 12v IGN feed to the coils came from in the donor car.
      But that's neither here nor there I guess... gotta feed those coils!
      I'm putting the coil packs and the injectors on separate relays to share the load. That should be the ticket.
      Joe
      New Taxes York
      Delving deeper into the donor car diagrams, one or two of which I didn't have, the inline disconnect for the rails and coils is hanging loose on the same branch as the MAF sensor connector. I mistook it for the Inlet Air Temp connector.
      It connected to a body harness way up front by the left headlight. No wonder I ignored it.
      I should be good to go now.
