    Results 1 to 20 of 20
      Chico, California Nor-Cal
      60 to zero braking distance
      Anyone got the data? I used my g-tech Pro RR, my b-body 12" front discs with Wilwood GMiii calipers and t/a rear disc 71 camaro stops in 165-170' with Hawk HP plus pads. Not all that steller. If pushed harder I may get the stops shorter. I use a dual diaphram booster and 1 1/8" master with adjustable prop valve. The G-tech is consistant. I can creat graphs and overlay runs. They have been near identical. With sticky Kuhmo tires I can't lock the wheels. So what are your numbers?
