    Results 1 to 6 of 6
    Thread: Muggy Weld ??
      Melbourne, FL
      Muggy Weld ??
      Anyone ever use this stuff?? I was considering using it to weld brackets onto my aluminum radiator.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Melbourne, FL
      Well this idea is out. Just learned that the Griffin Radiator I have has epoxied tanks. Not a good idea to heat up a radiator with epoxied tanks. Will need to look at other options. Maybe JB Weld the brackets on or use a slide in style. Then figure how to mount my dual LT1 fan setup... Projects are SO much fun
      Sep 2010
      Beach Park IL
      I have welded on Griffin radiators before. Just watch your heat and use water soaked rags as a heat dam.
      I have not used the muggy weld but have never heard anything good about it either. Get someone to tig weld the brackets on for you, any racecar, hotrod, or fab shop should be able to do it.
      Donny
      California
      If the area isnt close to the epoxied area a good welder may be able to pull it off for you. Some epoxies are capable of with standing intense aounts of heat. Id look into it and call the MFR
      san diego
      FWIW, the tanks are still welded to the tubes, the epoxy is there to help with vibration.
      Melbourne, FL
      Quote Originally Posted by Bryce View Post
      Thanks Bryce
