    Results 1 to 10 of 10
      North Las Vegas
      1970 Chevelle Electrical Problems
      This one stumped me, but thats not too hard to do when it comes to electrical issues. Here's the story...
      I parked my '70 Chevelle in my garage after a spirited drive where it ran perfect. It sat there for about 2 weeks un-touched. When I got back in it and tried to start it, it didn't make a noise. First instinct said it was the battery so I tried to jump it. That didn't work so I tried to charge it in the car overnight. That didn't work either so I charged it out of the car with the same results. Then I replaced it completely and still, there was no luck. There was a small bit of hope while I was jumping it when it started to turn over a little, but was too weak. Ever since then, even with the new battery, which I tested in another car to make sure that it worked, it hasn't made a noise. Next I checked the Neutral Safety Switch and that came out OK. The battery disconnect switch, the fuses, and the connections to the distributor or ok as well. I tried to work some other things with a good battery in it and heres what I came up with. The headlights, electric fans, etc... don't work, but that annoying buzzer that goes off when you open the door with the keys in the ignition still works. My next guess is that the fuse box itself needs to be replaced. What do you guys think?
      1970 Chevelle - Sold
      1969 Camaro RS Z/28
      1965 Corvette
