    Results 1 to 8 of 8
      Sep 2010
      Where the wind blows
      1955 Chevy Convertible Pro Touring - Rat Rod. Help! What wheels!?
      Guys, I really need some help. What do I put on this car to make it look "right!"
      Suggestions are MUCH appreciated.
      Here's original thread posted here.
      https://www.pro-touring.com/showthre...ect&highlight=
      I'm sort of a 5 spoke billet kind of guy. would also consider gray center. But I also have a creative mind. Looking for pop, unique and timeless classic.
      I'm lookin at 275/40ZR20's for the back (on 20x9 with 4.5 BS)
      245/45ZR18's for the front (18x8 w 4.5 BS)
      BF Goodrich Comp 2 tires seem to be the front runner so far. But I'm open to suggestions.
      Ride tech 4 link installed in back. Getting ready to install shockwaves.
      Rockytopper did this rendition on photoshop. I need to purchase ASAP.
      I am also concerned about buying w the wrong backspacing and being stuck w the wheels.
      1955 Chevy Convertible-LS2 Project
      1955 Chevy Convertible LSx Rat Rod Project
      Feb 2007
      Forgeline Concave wheels!
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Apr 2010
      Jersey Shore
      What disc brake kit do you have and how much does it push the track width out? Like I said in the other thread you made I dont think you will be able to fit an 18x8 up front if you want it to sit like it does in the photoshop and retain some turning radius
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      @autoworksnj for corvette and shop car pics
      https://www.pro-touring.com/showthre...e-Build-Thread
      Sep 2010
      Quote Originally Posted by vette427-sbc View Post
      They are Wilwood 6 pistons on front and back. Dynapro kit 12.15" front and back w the 6 piston upgrade.
      Rear is a 9" narrowed to 57-1/4" (outside to outside)
      Sep 2010
      Apr 2010
      Jersey Shore
      We run an 18x7 (225/50/18) with 4.5 backspace on a negative offset brake kit. That seems to be the widest you can go when you are tucking rim into the fender at ride height. You will need more backspacing since your brake kit most likely pushes the track width out a bit. If you are going to be at close to stock height when you drive the car and only air it down when you are parked then you should be able to fit the 245 tire on an 8" rim
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      Mar 2012
      South florida
      Can't go wrong with coys c5
      Hawaii-Las Vegas
      Both cars look awesome! I like the color combo on the orange one!
      1963 Nova SS
    Tags for this Thread
