    Results 1 to 7 of 7
      Mar 2004
      Mid-Michigan
      Astro hydro-boost units. Which one?
      I am pulling all of the stuff together for the van's steering system.
      I just picked up an '86 Chevy 1 ton hydroboost power steering pump and it is hanging on the front of the mock up block.
      Tuff Stuff brackets. Bolted right up. I just need to get a pulley and a pressure fitting.
      I have two Astro van boost units. One from a '95.
      You can see it sticks straight out from the fire wall.
      And one from a '98 which angles down at quite a steep pitch.
      Is either one better then the other? I don't care either way as far as looks or fitment goes, they are both off Astro's so I know they fit, just wondering if, operationally, one is better than the other.
      Paul, What do you think?
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Austin, TX
      I used the straight version on my Camaro and am happy with the results.
      Sep 2009
      I would like to know too, I have one from a 98, that has the steep pitch as well. Also, what MC are you running? Do they use the same GM MC mount as the 70-81 style MC's?
      Austin, TX
      I'm not sure of what the mc is off of but I can say it's a little too touchy so I need to change they bore size. I have the factory astro mc and will most likely try it with my C5/LS1 brakes. I modified the mounting bracket slightly by trimming some excess and flipping the booster over. I also had to adjust the length of the rod to the pedal.
      Attachment 59751
      Attachment 59752
      Sep 2009
      Was it determined that they were different?
      Hackettstown, NJ
      I dont recall the exact reason, but I recall that 94-96 units were best suited for 2nd gens. I used a 95 unit. w/ 1.125" bore it is touchy at low speeds. Just something to get accustomed to with the feel. haven't done a panic stop but its a huge difference w/ C5/6 brakes over the stock 2nd setup. More importantly is the pump flow.
      Mar 2004
      Mid-Michigan
      I decided to go with the '95 unit as well. Reason being I have the inside brake bracket from the same vehicle so there will be no issue with fitment or function. The straight unit keeps the M/C up out of the radiator area also. I degreased the '95 the other day with some spray degreaser and simple green. Plugged all of the open ports and hit it with the pressure washer after a few minutes of scrubbing with a small wire brush. Cleaned up nicely and I know it was working fine before the trans went out on the donor van.
      Mark:
