    Results 1 to 6 of 6
      All Brakes Are Dragging, 4 Wheel Disc Brake 67 442
      I'm having trouble w/ all my brakes dragging! I'm running a Late 60s Corvette master cylinder, Factory power brake booster, 4 wheel disc brake porportion valve w/ a wilwood adjustable valve for the rear brakes, Ford Explorer Rear Disc setup on my 9in rear and B-body spindles w/ 12in rotors and wilwood calipers!! That was a mouthful!! The brake pedal is very touchy!! Could it be that everything was new? It was kinda tight to install all calipers loaded w/ pads!
      Suggestions? Did I use something wrong?
      k3
      1967 Oldsmobile 442 W-30 w/ Fuel Injected E Block n C head 400ci, 2004r, Global West Everything, 3:70 Ford 9in, B-body spindle w 12in rotors w/ Wilwood calipers and11in Ford Explorer Disc setup in rear!! Alot of work!!
