    Results 1 to 20 of 38
      Feb 2011
      mass
      ? on manual brakes
      doing a 68 camaro ls6/4l60 car has aftermarket power disk front brakes , just got all c5 brakes with kore3 brackets was thinking of going to manual brakes to clean up fire wall. does any one use manual brakes on street car that will be a driver? and opinions if i should or should not do it? thanks kevin
      Oct 2007
      Atlanta
      Lots of guys run manual brakes, including me. It's a matter of taste like most things.
      san diego
      I love my manual brakes.
      Aug 2011
      Colorado
      Hydro-boost may also be another option.
      California
      I have manual brakes on my 69 Nova. They stop extremely well, but it's still only an interim thing. Eventually I'll have a hydraboost setup.
      Matt
      Greenwood, SC
      Nothing wrong with manual brakes, just have to use more muscles to operate them. If you size your master cylinder correctly, you can get the exact same clamping force as a power setup.....
      JC Scott
      I run a 15/16" bore MC with C6 ZO6 brakes and they work very well, even with my tank of a car.
      Jul 2009
      ma.
      I went to a manual wilwood on my camaro because my solid lifters make 0 vacc I tryed a electric pump and canister but could not keep up with braking so went manual.
      its ok but sucks compared to having a power brake.
      if I were to keep it I would install a hydraboost.
      san diego
      I have a 15/16" bore manual MC, with wilwood dynalite calipers and drums in the back with my proportioner almost all the way open. I love the way my brakes feel. I autocrossed my car for the first time yesterday.
      Quote Originally Posted by Bryce View Post
      My prop valve is also almost all the way open, but I have tiny C4 rear calipers.
      Greenwood, SC
      Bet my tank is bigger lol.... 7/8 bore MC with 340mm front and 330mm rear C6 Z51 stuff. My pedal ratio is about 6.5:1 though, so that helps alot
      JC Scott
      Jan 2011
      Boston, MA
      I run a Wilwood manual brake setup on my '67, and would say the only problem is then jumping into my wife's car with power brakes and eating the steering wheel at stop lights. Power brakes are much "touchier" after driving a manual setup.
      Jan 2010
      Northport NY
      I am running a Front only Wilwood set up for the same reason. (clean firewall/motor compartment). My brakes work great. Make sure you size the master correctly and be sure to get the right length rod. Had to disassemble my set up after install and bench bleed to replace the rod. Enjoy
      would a 15/16 master work on a 69 maro with manual c6 front, oem drum rear set up.....?
      Nor Cal
      Love my manual brakes too. I don't like the squishy feel of the power boosted brakes I've driven.
      Have Wilwood Superlite fronts and Dynalite rear with the prop valve wide open as well.
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Feb 2012
      Nazareth PA
      What 15/16" manual MC are you guys using? I have Wilwood dynalites on the front of my Chevelle with stock drums in the rear. I tried the 7/8" bore Wilwood MC and the pedal travel was too much and always felt mushy. I went to a 1" OEM/GM/Napa style MC and now it takes too much effort to stop and has a very hard pedal.
      The car used to have power brakes, but I removed the booster because of poor vacuum (large cam).
      Jim
      My 70 Chevelle
      The 454
      Keisler RS 5-speed
      Quote Originally Posted by JIM1 View Post
      1977 Malibu 6 cylinder with manual brakes.
      Henderson,NV
      I agree that a 15/16 could be the sweet spot for all around manual brakes. The 7/8 is a little squishy and the 1" is great on the race track with the correct compounds. However, it's not what you're used to on the street. Most factory brakes require you to lay your pinky toe on the brake pedal. I think that's good for ABS and quick reaction. I prefer manual brakes for the track.
      Todd
      Feb 2012
      Nazareth PA
      Is that a plastic unit with the front/rear fittings reversed? I saw an ad from CPP and think they have a 15/16". May try on of those possibly. I am just sick of changing MCs and bleeding.
      Jim
      My 70 Chevelle
      The 454
      Keisler RS 5-speed
      Oregon
      It is a cast iron disc/drum unit.
      Tobin
      KORE3
      It's what I does.
