    Results 1 to 6 of 6
      Dec 2010
      Fredericksburg, VA.
      Tire balancing bead
      I have been using Dynabeads in my pickup tires for years and I have never had an issue with tire balance in 100's of thousands of miles. Once installed in a tire, that tire never needs to be rebalanced periodocly like with conventional weights through out the entire tread life. The added advantage is that you never have to worry about a weight being thrown off. I ordered a set of wheels/tires for "Dust Off" that came balanced with tape weight. I see no reason the the balancing beads will not also work in my Forgelines.
      http://www.innovativebalancing.com/index.php
      Here is a video that demonstrates how these beads dynamically balance a rotating mass.
      http://www.youtube.com/watch?v=eq263AYgyYg
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Dec 2009
      This theory has been around for a long time. I'd love to see wheel/tire combo tested on a high speed balancer...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Jul 2010
      Sacramento, CA
      Quote Originally Posted by Ron.in.SoCal View Post
      Id love to see it on a road force analyzing balancer. The heat generated inside the tire would have to be a bad thing for a performance tire I would thing?
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Dec 2009
      Quote Originally Posted by SLO_Z28 View Post
      I recall this similar theory being used on the crank of Harley engines using a mercury filled tube as a balancer. Harleys are notorious for vibration due to v-twin cylinder angle and crank design. Most of the builders that tried it thought it was worthless marketing. I realize a motor is alot different than a wheel, but still...?
      All respect Steve to you, your car and your ideas. I think this discussion is worthwhile if it can be shown to work. BTW, I put taped weights on my Wc3s...
      Ron in SoCal
      Oct 2006
      Pittsburgh Pa.
      delete
      Feb 2011
      dallas, tx
      Ill continue to use sticky weights at my tire shop lol
