    Results 1 to 5 of 5
      Fort Worth, Texas
      M/T Sportsman S/R? Ever used it?
      Has anybody ever run this tire for their mini-tub modifications?
      Looks to work? What are the thoughts on the size? 28X12.00R18LT....or would you need something wider? to get the look and performance of a 335 or 325?
      http://www.mickeythompsontires.com/s...em=SportsmanSR
      28X12.00R18LT
      Aug 2006
      austin
      That's almost as wide as a 335, but the aspect ratio is bit tall. A 335-30-18 tire is about 26" tall. These tires will not handle like michelin pilot or Kumho or Toyo, however, so you may want to reconsider if you plan an any hard driving. This is more of a street oriented tire.
      Greg
      1976 Trans Am SacrilEdge
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      https://www.pro-touring.com/showthre...ect&highlight=
      https://www.pro-touring.com/showthre...ilEdge-is-free!
      Dec 2009
      knoxville, tn
      no where near a 335. they are the same width as a 295 at 11.6" section width. notice that they are measured on a 10" wide rim also?
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      "attack life....it's going to kill you anyway."
      Oct 2005
      New Washington, IN
      Good for looks and cruising, not a corner burning PT tire.
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Oct 2006
      Corona, CA
      Its a good street radial, and should be mounted on a 10" rim. Sure, we've built wheels for mini tub'd cars that are 18x10s and run 295-305 wide tires to help save guys some $$ on widening a two piece wheel to 11s or 12s, so the important thing is ask yourself what kind of driving you are going to be doing, and how much do you want to spend on wheels and tires, and plan accordingly.
