    Results 1 to 5 of 5
      Feb 2007
      pull handle parking brake recommendations
      I would like to know what you guys have used for a pull handle style parking brake handle, what handle and cables did you use and where did you get you parts from? Pics are welcome
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Sep 2010
      Beach Park IL
      We have always used Lokar stuff and it works great on drum brakes and some internal drum discs but the problem we have had is that there just isn't enough leverage in the handle and the ratchet is too coarse. in other words you pull with one hand as much as you can and its just not enough so you use two hands and PULL and then it works....sorta.
      If you got room I recommend this http://store.controlcables.com/servlet/Detail?no=1582 it's easy to mount and the operation is awesome. Push to set it and push once more and it releases. At $65 it's not junkyard cheap but way cheaper than most aftermarket stuff. They also have a pull handles and can custom make cables for anything based on your measurment and requirements.
      Just curious, what kind of car and where is the stock handle?
      Feb 2007
      I'm thinking of doing this in my 79z28, It has the foot pedal as of now but was thinking of changing it.
      Brandon Slater
      1979 Z28
      1972 Nova
      Oct 2006
      Morristown, NJ
      I used a pull handle, lines, and brakes from an 98 Camaro. I also used the console from a 94 Camaro.
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      Austin, TX
      I used one I found at Pick N Pull from a Honda (Civic I think) for $10. The black vinyl matches my interior good and it works well for me.
