View Full Version : Project Sabre, a 1971 Cutlass Pro-Touring car for the average Joe
Pages : 1 2 3 [4]
csouth
03-27-2014, 06:04 AM
Rotors were dropped off yesterday at the shop that is going to cryo-treat them, and the spindles are at the coater's getting cleaned up and coated. Hopefully those will be ready in about 2-3 weeks, as to save $$ I'm having both done as they have a larger run (reduces the cost when done with other orders).
For the engine, looks like I was given the wrong lower mounts, which placed the engine too far back against the firewall. I have some replacements arriving that should move them to the correct spot (guessing the previous shop gave me someone else's mounts, and I think I know the guy, so will be sending those to him). Once I get that nailed down, I can finish up with the drivetrain and move forward. Baby steps, but at least its progress and I know its being done right with no more mistakes.
When you say "lower mounts" are you talking about the frame mounts? If this is what you are referring to, I think they only come "short and narrow" or "tall and wide". The Chevy and Olds mounts sit in different spots on the crossmember, so lots of ppl with leave the frame mounts connected to the motor to find the right postion before bolting it down. I had to drill holes in the crossmember to get my motor in the proper mounting position in reference to my firewall.
All in fe new pics!
SparkyRnD
03-28-2014, 01:35 PM
I'm talking about the lower half of the conversion engine mounts, the part that bolts directly to the crossmember. I also received the replacement Musclebar and will install that as well. Ordered a few other parts and am working on cleaning some others getting ready for a lot of upcoming work. I think the biggest thing I'm not looking forward to is wiring the car, but the job has to be done ;-)
tommycomfort
03-28-2014, 02:23 PM
Come on Sparky, I know you have a really nice camera! Post some pictures!
SparkyRnD
04-17-2014, 05:20 AM
Soon Tom....soon ;)
I am going to pick up the spindles from the coater's and the rotors from the cryo treatment, and will try to get those installed over the next few days, along with the Ridetech updated Musclebar. Also setting aside time to move the engine & trans and try the other mounts to see if that gives me more clearance at the firewall.
Also talked with David and in a few weeks he's going to be tackling the dash and firewall and a list of other tasks that need to be done.
GeoffP
04-17-2014, 05:50 AM
Are you coming out to the Motorama Sparky? You better...it's CHEAP! Several of us will be there. Bring food! I want to see how the spindles turned out. I need to clean mine up and get them coated with something (maybe POR15).
SparkyRnD
04-17-2014, 05:58 AM
Yep, I'll be there. Since its so close, I will probably drive down for the day and head back in the evening and repeat the next day. Where are ya'll staying? I'm looking to go to Nashville again as well.
GeoffP
04-17-2014, 06:22 PM
I'm sharing a tent with Tony and Brian Clark. I won't be at Nashville unless I win the lottery or get a huge financial endowment of some sort which is not likely to happen...
SparkyRnD
04-21-2014, 04:30 AM
Got in some good time on Sabre this weekend. I moved the engine & trans forward by installing the second set of motor mounts, so now there is more clearance between the engine and the firewall. The previous shop must not have checked for the bellhousing or transmission, as the reverse lock-out is resting against the trans tunnel (turns out they didn't have it installed during test fitting), and I don't believe the upper bellhousing bolts can be removed as they will hit the firewall before they are all the way out. But now the engine and trans are fully installed. David is going to do the repairs to the firewall in a few weeks, and after that I will finish assembling the top of the engine and the engine wiring.
I reinstalled the newly powder coated spindles, which look great. I also picked up the rotors that I had cryo-treated (both the powder coating and cryo treatment were done at Pro-Cryo in Cumming, GA). I will install the rotors just before we wrap up the brakes. I installed the wider Ridetech Musclebar up front, and reconnected everything. I still have to trim the front bolt on the back of the steering arm, as it is required to clear the musclebar heim joint, but I will tackle that later this week. The balljoints are torqued to spec and the caliper bracket has been installed. I had to put another coat of paint on the steering arms and tie rods, which I will reassemble and install one night this week.
Started working on the hydroboost unit. I got a used one from a pull-a-part, and used that as a core for a rebuilt one. It comes with the standard bracket, but I bought the aluminum one and the nut-tool from Tallon Hydraulics. Only problem is that all of the crescent wrenches I have are too small to fit over the end, so now I need to buy a larger wrench. Then I moved on to the pedals. I bought a set of replacement manual pedals last year, and swapped them out on my existing auto pedal holder. Turns out the set I got didn't use a bolt and nut up top, but rather a solid rod with a clip at the end. Issue there is that the rod is a larger diameter than the existing bolt, so I had to drill the openings out to fit. I'm missing a spacer, which is all I lack to install them. I will say it again, the Modo Innovations pedal covers are awesome looking!
Also, the Ridetech suspension is art, plain and simple. I spent a lot of time just staring at the components while working this weekend, and can't wait to start putting it through the rigors of autocrossing. Also, their customer service is amazing. I have had to call and email them multiple times, and they have been very fast & informative in their responses.
The last bit of work this weekend was finding the grand cherokee steering shaft and disassembling the throttle body, as both need a heavy cleaning and some paint. Over the next week I will also be installing the Kwik Performance front accessory bracket system as well the odds & ends listed above. Feels good to have some solid progress, even though it included a few steps backwards to fix stuff.
64G-lark
04-21-2014, 04:25 PM
Looking good Sparky. I spent the evening going through your whole post. Sorry you had so many issues getting started. The paint looks great and I am sure looks even better in person.
SparkyRnD
04-22-2014, 04:31 AM
Thanks, I'm in love with the color. Everyone that has seen it likes it, even those that hate brown :)
GeoffP
04-22-2014, 05:01 PM
Yay - any progress is good progress! Pictures, pictures, pictures!!!
SparkyRnD
04-23-2014, 06:33 AM
Steering arms and tie rods are loosely assembled, and I'm waiting on the larger wrench to arrive so I can swap the hydroboost brackets. Also going to pick up some tube to make a spacer for the pedal hanger and pedal arm so I can get that installed as well later this week / weekend.
Here are a few pics, including the requested powder coating on the spindles. The little specs are pollen that got on it while in my garage, and are not debris in the powder.
https://static1.pt-content.com/images/pt/2014/04/LQ41-1.jpg
https://static1.pt-content.com/images/pt/2014/04/LQ42-1.jpg
https://static1.pt-content.com/images/pt/2014/04/spindle1-1.jpg
https://static1.pt-content.com/images/pt/2014/04/spindle2-1.jpg
https://static1.pt-content.com/images/pt/2014/04/spindle3-1.jpg
https://static1.pt-content.com/images/pt/2014/04/spindle4-1.jpg
GeoffP
04-23-2014, 08:27 AM
Okay so this begs the question, "Why doesn't RideTech power coat the spindles from the factory?" I'm going to pull my car apart after next month and powder coat my spindles because I thought they were coated with something to keep them from rusting and of course they aren't and now mine are rusting.
Thanks for the pics - you aren't done yet??? :)
SparkyRnD
04-23-2014, 09:35 AM
Geoff, my guess is most people paint them with rattle can. I think it would be a good thing if they offered powder coating as an option for customers, unless there is a specific reason why they can't.
Yes, yes I'm done and I just finished racing around town :)
gardnerme
04-23-2014, 11:57 AM
I can verify that it looks AMAZING in person!
SparkyRnD
04-27-2014, 10:30 AM
And he hasn't even seen it in over a month. There should be some solid updates in the next 2-3 weeks.
gardnerme
04-27-2014, 03:39 PM
That is because you close the blinds in your shop windows at night.
GeoffP
04-27-2014, 06:00 PM
Great to see you as always Sparky! I sure wish you'd brought out the Toterhome and the grill! You spoiled us at CMP last year with all the great food!
SparkyRnD
04-28-2014, 05:07 AM
I will definitely bring it out again and we'll camp / eat. Hopefully the Peachstate. Will you be going? Also I will be at the ASCS nashville run in august.
Spent a little time yesterday and got an appropriate sized pipe wrench so I could swap out the hydroboost original bracket for the Tallon bracket:
https://static1.pt-content.com/images/pt/2014/04/hydro1-1.jpg
I will get it installed along with the pedals in the next day or two.
GeoffP
04-28-2014, 06:09 PM
Booster looks good! I am hoping to go go to Peach State but don't know yet. Gotta beg that one due to cost unless I can sell something to cover it. I had a couple guys ask me about going to Run to Music City. If it do, it'll just be to spectate and ride along. Money's just too tight for me this year to participate very much.
csouth
04-30-2014, 08:12 AM
I'm not sure which pedal set you're using, but will that rod end work? I had to cut mine off and fit it with a clevis that I got from Tallon when I ordered my firewall bracket. Also make sure you have a swivel adapter handy for your ratchet, a couple of those nuts are a PITA to tighten without it. :hammer:
SparkyRnD
05-13-2014, 05:10 AM
No, the standard end on the booster won't work. I will have to cut off the end and then tap it, and add on some pieces to make it connect to the pedals. I may just buy mine from Tallon as well to save some time.
David is going to pick up Sabre hopefully by the weekend and will finish repairing the firewall and finishing the painting of the dash. As soon as I get it back, I'll be installing the dash pad and then dropping off with some friends to have them handle the wiring harness, installing the Vintage Air AC system and also welding up the stainless Borla exhaust. I'll be installing the BRP Muscle Rodz conversion headers this week, as well as tightening up the steering components before putting it back on the ground for transport.
SparkyRnD
05-14-2014, 06:18 AM
All the steering components and the lower control arms / ball joints are all torqued to spec. I will finish the upper control arms today. Can't find the pitman arm, but will do a little more digging. Worst case scenario I'll buy a new one locally, then I can finish the rest of the steering from the box down. Hoping to finish the steering arm at the spindle (have to cut off the excess on the bolts) and torque to spec. I'm going to hold off on installing the rotors for a while, as I don't want them to get rusty from sitting, especially after cryo-treating them.
I also installed the MuscleRodz Hedman headers last night, and they look great!
https://static1.pt-content.com/images/pt/2014/05/Header1-1.jpg
https://static1.pt-content.com/images/pt/2014/05/Header2-1.jpg
SparkyRnD
05-19-2014, 01:25 PM
got it back on the ground for david to pick up last saturday. When I set it down, the coils were bottomed out on the adjusters, and I had around 1/8" of clearance between the pan and the ground. Adjusted it up so there was about 2.5-3" clearance, and will still go up more once the front sheetmetal is hung. Ordered more parts that I was missing, and will install those after I get it back from David, and then its on to the wiring & Vintage Air heat / ac install, and finishing up our custom fuel tank. Then, off to the exhaust shop to have the Borla stainless system installed. Here are a few pics from Saturday (yes, it started raining):
https://static1.pt-content.com/images/pt/2014/05/rolling1-1.jpg
https://static1.pt-content.com/images/pt/2014/05/rolling2-1.jpg
https://static1.pt-content.com/images/pt/2014/05/rolling3-1.jpg
https://static1.pt-content.com/images/pt/2014/05/rolling4-1.jpg
gardnerme
05-19-2014, 02:43 PM
As good as it looks in these pictures, I can attest that it looks much better in person. The color is amazing viewed first hand.
GeoffP
05-19-2014, 04:30 PM
Looks good Sparky - ready to see this thing out and about!
SparkyRnD
05-19-2014, 06:12 PM
thanks, I can't wait to drive it myself
SparkyRnD
06-17-2014, 12:02 PM
Been a while since the last update, so here goes:
1. got the engine & trans in, headers installed and the front coils adjusted to bring the oil pan off the ground.
2. during the install, had some issues with the mounts and the engine dented the firewall trying to get it all installed.
3. got the front steering components installed and torqued, and the wheels / tires reinstalled so it could roll.
4. sent the car to my painter and had him rework the firewall and paint it, as well as the dash & rear speaker deck area
5. while in there, he saw that the motor mounts were way worse than I thought. He had to cut them apart, flip them around, and generally rework them to get it all level and installed correctly. By doing so, he was able to raise the engine and trans a little giving better ground clearance. This also centered the trans in the tunnel like it should have been (was off-center before).
6. the hard brakelines along the frame have been installed
The car is now back in my possession, and will be getting the Vintage Air A/C system and the wiring harness installed. I will also be ordering the driveshaft, and once that is in, the car will go to the exhaust shop to get the Borla stainless steel exhaust system welded & installed. After that, more wiring, fuel system and dash.
srh3trinity
06-17-2014, 01:13 PM
I like the color combo and it sounds like you are making some great progress.
Carguello08
06-19-2014, 06:55 AM
Almost there !!!!!
cutlassmann
06-28-2014, 01:12 PM
i would like to know who did you paint and body work ?
protouring70
06-29-2014, 10:22 PM
Hey Sparky its been a while since I've checked up on sabre. Looks amazing! I forgot how beautiful the color was. Let me know if you have room left on the pit crew I'll be there!
SparkyRnD
07-01-2014, 04:45 AM
The bodywork / welding was redone and painted by David Sloan. He fixed all the stuff the last shop screwed up (nothing like paying twice for work) and did an amazing job.
Brent, was good to see you at Peach State this weekend, and thanks for the offer! I hope to have more done after I get some work projects & family stuff out of the way over the next few weeks.
HectorM52
07-01-2014, 12:48 PM
I keep hoping to see this thing surprise us at each event, but i guess it's better to do it all right the first time and have it take forever than rush it and have to redo something. I've been there, and not just from shops, I can shortcut all on my own! :)
SparkyRnD
07-01-2014, 06:48 PM
You and me both! We're moving closer and hopefully soon we will have the chance to hear it fire.
SRD art
07-02-2014, 06:34 AM
:yum: Looking forward to seeing that and then you driving it down the road! The wait will be worth the end result.
SparkyRnD
07-07-2014, 06:24 AM
Me too. It should be heading out for more work in the next week or so, and I'll be ordering the driveshaft and then to the exhaust shop.
'71cutlasluvr
07-07-2014, 08:45 AM
+1 Glad you're moving forward and making progress Sparky. :twothumbs
CamaroSS27
07-08-2014, 07:15 PM
Wow, beautiful car! I just went through all 40 pages! I have a 72 442 that I am just stating and this has given me soooooo many ideas! My build will be long but very fun. I can't wait to see your finished car, keep up the good work!!!
ent72olds
07-09-2014, 04:28 PM
Chris, I guess you should be flattered, LOL. The guys first post too!
Sparky, I'm glad to see you stuck with it after all the BS you had to go through. Sabre will be incredible!
'71cutlasluvr
07-10-2014, 12:58 PM
Lots of newbie enthusiasm but he probably should have thought that one out a bit more.... :hmm:
Very gracious of you Chris to let it go at that........
SparkyRnD
07-28-2014, 05:53 AM
A quick little update: the car is now at a friends shop in Tennessee. They are installing the wiring harness, PCM & engine harness, dash, installing the Vintage Air a/c system, and a good bit of other work. Depending on where we end up $$-wise, I may have them do a lot more when the items above are done. Hopefully I can check out the progress shortly and add some pictures.
'71cutlasluvr
07-28-2014, 09:30 AM
Great to hear you're still moving forward with Sabre Sparky. Progress is progress, no matter who does it. Looking forward to more updates and pics when you can.
:cheers:
CornHusker4Life
07-28-2014, 09:52 AM
You will be happy with their work. How did my car look? I am assuming you took it to a shop in Cleveland?
71oldscutlass
08-07-2014, 06:34 PM
Any new pics been following for years!!
'71cutlasluvr
08-07-2014, 07:26 PM
+1 :attn:
SparkyRnD
08-08-2014, 05:03 AM
Nothing yet, as they are working on another project of mine at the moment. They should be on the Cutlass shortly and I'll get some pics updated.
SparkyRnD
11-19-2014, 06:53 AM
They have the wiring mocked up and the a/c box installed, but I haven't heard of much else happening over the last 4-5 weeks. Hopefully I will get a reply soon with an updated status on it.
Arctic_Ragtop
11-19-2014, 01:12 PM
Just found this thread today and read through the entire thing. Awesome project, great job so far! Excited to see the rest of the build!
SparkyRnD
01-29-2015, 05:58 AM
Thanks, it's been a long time coming. With some luck, just a little longer to go and it'll be on the road.
SRD art
01-29-2015, 07:56 AM
:fingersx::headbang:
msplichal
03-31-2015, 06:38 PM
Hi I am new here, really enjoyed this read as I have a 71 cutlass. This has really inspired me for my build. Has there been any progress on your build?
SparkyRnD
05-21-2015, 07:35 AM
After a LONG delay, Project Sabre is finally moving again. We had to take the car back from the last shop as they let it sit for many months and didn't do the work they said they would. I now have a good shop working on it, and they have been able to accomplish a lot in the last week. We did find that the last couple shops that had the car messed up quite a few things along the way, with incorrect bolts being installed in the suspension, parts installed in the wrong spots / backwards, and the rear axle adapter mounts weren't done properly or safely. As such, the rear axle is coming back out and we're having it all fixed the right way.
In addition to fixing the suspension installation and the rear axle mounts, they are wiring the car, installed the steering column and wheel, finished up the pedal install, hydroboost and brake installation / lines, making a driveshaft, getting the engine ready, installing the a/c system, dash, gauges, etc. The first focus is fixing what's wrong, then working mostly on the drivetrain and suspension issues, then tackling everything else.
I'm just glad to see progress, which is LONG overdue! Here are updated pictures:
https://static1.pt-content.com/images/pt/2015/05/052115a-1.jpg
https://static1.pt-content.com/images/pt/2015/05/052115c-1.jpg
https://static1.pt-content.com/images/pt/2015/05/052115d-1.jpg
https://static1.pt-content.com/images/pt/2015/05/052115e-1.jpg
https://static1.pt-content.com/images/pt/2015/05/052115f-1.jpg
https://static1.pt-content.com/images/pt/2015/05/052115g-1.jpg
https://static1.pt-content.com/images/pt/2015/05/052115h-1.jpg
SparkyRnD
05-22-2015, 05:20 AM
we have new window fuzzies, door handles, handle & lock gaskets and a bunch of other parts coming in this / next week. The shop is going to clean up the front and back stainless trim, smooth out any dents and then polish before installing. Hopefully we'll be able to also get new glass installed depending on budget / time.
SparkyRnD
05-30-2015, 04:52 AM
No pictures at the moment, but more parts have been ordered. Tobin at Kore3 supplied us with some brake hardware that is missing, and we also ordered a bunch of other missing parts, sensors, gaskets, etc. Also, and I'm pretty happy about this, I ordered new replacement tinted glass which the shop should have in a few days. We did find that the transmission rear tailhousing was heavily damaged by being dropped, and the rear holes won't align with the MGW shifter. The shop is trying to fix that now, but my guess is I'll have to get another tailhousing and have them swapped. Also, we found that the 'modified trans tunnel' wasn't done properly, and had to be massaged to fit the sensors & accessories on the trans. This also came up when we tried mocking up the explorer aluminum driveshaft, and we found that the rear of the tunnel was never touched. As such, I'll have to run a steel shaft for now with a smaller diameter. Eventually, I'd like to upgrade to a lighter weight shaft but at least this will get us rolling.
'71cutlasluvr
05-31-2015, 09:07 AM
Good to see you're back on track with Sabre Sparky. Geez, what's the deal with all the crappy shops you've been dealing with? But I guess you never really know if you're gonna get what's promised until the car is at the shop. Sounds like you have a reputable, reliable shop working on Sabre now. Hope to see more pics and lots more progress now.
ATB
gus
Mr.VENGEANCE
05-31-2015, 08:27 PM
why didnt you let David finish your car?.. I thought he was working on it.
protouring70
05-31-2015, 11:14 PM
Wow....I wondered what happened to you. I haven't seen you in quite a while. Glad to see progress......hopefully I'll see you around some this summer!
Revmax
06-01-2015, 07:34 AM
After reading this whole story, I'm glad you are back on track with the project. It's amazing what can happen and the quality of detail/craftsmanship between shops between doing what's right, and what will work (maybe). Looking forward to the finished build as I am considering the suspension setup you've used and I love the tire size choices for this beauty. Probably will be doing business with Rushforth myself. Keep up the good work though. Glad its coming together.
SparkyRnD
06-01-2015, 10:22 AM
ATB gus
Just luck of the draw. I spent more time trusting people and dealing with handshakes, and expect a man to keep his word (definition of a man imho). Sadly, either by circumstance or choice, several shops weren't able to keep their word or provide quality results. The shop working on it now seems to be doing everything they say they can, and in a timely manner for the agreed upon prices (amazing). They are also pointing out missing items, improperly installed parts, and incomplete work from previous places without me having to ask, which is nice.
David was contracted to do paint and body, which he did. He is working another full time job and worked on mine as much as he could, but we both knew it was temporary. I wanted him to do more, but he didn't have time which I completely understood. I was very happy with all of his work that he did do on my car.
Yep, been working like crazy and getting this project squared away. I hope to attend a few events coming up, just have to see how work / family time plays out (family time is the most important thing for me, with two young kids)
Thanks, it's been a bumpy road at times, but also made some great contacts and friends along the way. You will not be disappointed in dealing with Jason Rushforth, both from a wheel standpoint and also from a rendering / concept design standpoint. He is truly a master at his crafts, and I would highly recommend him.
SparkyRnD
06-15-2015, 06:22 AM
Minor update, but an update none the less. The shop got all the brake calipers and rotors install, all bearings packed, all Ridetech suspension pieces installed correctly. The window fuzzies have been installed, as well as the door latch hardware including the new handles, handle gaskets and door lock gaskets. The doors close like a new car and sound great when hitting the striker. The tinted glass has been ordered, but a week into the 'processing time' we found that the rear window was backordered. They should have that shipping in about 10 days time, so we should have glass installed within the next 2 or so weeks. The master has been installed and the hydroboost installation is done (they still have to finish up the brakelines, but the hardest part of that system is done). Getting much much closer, and very pleased with the work being done and the communication. Here are pics from this weekend:
https://static1.pt-content.com/images/pt/2015/06/061315a-1.jpg
https://static1.pt-content.com/images/pt/2015/06/061315b-1.jpg
https://static1.pt-content.com/images/pt/2015/06/061315c-1.jpg
https://static1.pt-content.com/images/pt/2015/06/061315d-1.jpg
https://static1.pt-content.com/images/pt/2015/06/061315e-1.jpg
https://static1.pt-content.com/images/pt/2015/06/061315f-1.jpg
https://static1.pt-content.com/images/pt/2015/06/061315g-1.jpg
csouth
06-15-2015, 01:10 PM
Sweet! How did you mount the clutch master bracket?
SparkyRnD
06-15-2015, 01:29 PM
it hasn't been hung yet
PPG TRIGGER MAN
06-19-2015, 02:20 AM
Great build Sparky, that color is eye catching. I am doing a 62 Buick LeSabre with a very similar color from a motorcycle. Is that a 3 stage?
SparkyRnD
06-19-2015, 05:04 AM
Thanks, and nope, it's a basic 2-stage paint
SparkyRnD
08-10-2015, 05:13 AM
Another update: went by the shop last week and they have all the side glass in, and the front / rear should be installed this week. They also got back the stainless steel trim that we had refurbished and polished, and that will go on with the front / rear glass. The brakes are finished and bled, and the clutch master / lines are done and they will bleed that this week. Driveshaft is done & installed, and rear axle is completed (just needs fluid). We discussed the fuel system and what all is needed, as well as what is needed for the remainder of the wiring / AC system to be installed.
All in all, its coming along well. We did, however, run into a sizable problem: the first shop that measured for wheels & tires forgot to account for the Corvette spindles pushing everything out about an inch. Because of this, with the front fenders on, the inner lip (that has already been rolled) makes contact with the tires in a bad way. We have the front end lifted as high as it will go and it still barely rubs. Due to this, I will have to have both front wheels rehooped to adjust the backspacing and pull them in about an inch on each side. Nothing like throwing away more money for someone else' mistake.
Here are a few progress pictures:
https://static1.pt-content.com/images/pt/2015/08/354-1.jpg
https://static1.pt-content.com/images/pt/2015/08/355-1.jpg
https://static1.pt-content.com/images/pt/2015/08/356-1.jpg
https://static1.pt-content.com/images/pt/2015/08/357-1.jpg
https://static1.pt-content.com/images/pt/2015/08/358-1.jpg
David Sloan
08-11-2015, 01:42 AM
Looking good , Ryan
can't wait to see it on the road.
'71cutlasluvr
08-11-2015, 03:43 PM
Looking good Sparky! Thanks for your explanation on the shops in response to my inquiry. Glad you're on the right track with a good shop now. Good Luck!!
PhillipM
08-11-2015, 03:57 PM
Glad to see your back on it. I like the wheels.
deejai35
08-11-2015, 04:48 PM
Looking good indeed!
protouring70
08-11-2015, 05:46 PM
Hey its getting closer!!!!
csouth
08-11-2015, 07:57 PM
Looks good Sparky! I wasn't aware that the Ridetech kit came with Corvette spindles? What width are those fronts, definitely not enough BS. I know most 9" wheels on A-bodies usually run 5-5.25" of BS
SparkyRnD
08-12-2015, 04:29 AM
The shop that is working on it now called them Corvette spindles, not sure what the original application is, other than GM. I know that we are using Corvette C6 Z51 rotors, so that may be why he was calling them vette spindles. The wheels are 19x10 in the front and 20x10 in the rear.
csouth
08-12-2015, 07:03 AM
I see, he was probably confused by the brakes and the slip hat rotor on an older Muscle Car... That's a wide wheel for the front of an A-Body without an aftermarket frame. Sorry you have the added expense. Just a small bump in the road of many.
Sasha
08-25-2015, 08:32 PM
Awesome project and thread! Spent pretty much the whole day reading all of it, LOL, and I must say that the car looks AMAZING. A friend of mine and I are about to start the loooooong journey of building his '71 442 W-30, which has been sitting in his yard for several years. You've inspired me, as well as I'm guessing quite a few people on here, so thank you for that. Good luck with the remainder of the build, hang in there, you're almost there!
SparkyRnD
08-27-2015, 07:43 AM
Front and rear glass are now in, and as soon as the trim shop finds the rear trim they lost, we'll be back in business. The gas pedal is being installed, and I'll be ordering a new harness and PCM tomorrow. Turns out the one we have is for a truck layout (which was what we were originally going to run), is longer than we need, and the PCM is for a drive-by-wire set-up (which we are not using). So with that said, I have a flashed / reprogrammed PCM for drive by wire and a fully reworked harness set up for a truck intake available for sale ;)
The shop will start on the wiring in the next week or two once I get the new harness & PCM to them.
Sasha
08-27-2015, 07:51 AM
Nice!!:bananna2:
Almost there!
I'm going to have soooo many questions for you when I get started on my project, Sparky, as well as all the other Cutlass-heads here, lol
mikidymac
08-28-2015, 09:46 AM
The wheels and tires look great. Sorry about the back spacing.
I see they are 19x10 front and 20/10 rear.
Could you give us the tire sizes and what the backspacing is and should be? The combo looks great.
SparkyRnD
09-16-2015, 01:34 PM
I'll have to dig that up and post it. Just ordered the harness and the PCM, so one more step forward
SparkyRnD
10-04-2015, 07:03 AM
Small update: got the PCM & initial programming ordered, and they should have that shipped in the next few days. The new PSI harness was delivered Friday to the shop, and the 5-pin MAF and 5-pin to 3-pin harness adapter should arrive Tuesday. I released the shop to finish up the wiring from nose to tail, and we'll be installing the PCM on the inside firewall so that it's hidden but accessible. I also released them to install the Vintage Air AC system as well as the dashboard and gauges. We did encounter yet another minor setback. The used racing Tilton Clutch Master Cylinder I supplied started leaking the other day. Thankfully it only leaked inside the cabin, and not on the firewall paint. I sent them a rebuilt kit and that should be rebuilt shortly. I may also have them measure for the front wheel backspacing change next week or the week after, and then send the wheels to Rushforth to be rehooped.
Sasha
10-04-2015, 04:41 PM
Absolutely love this thread... Just started working on a 1971 442, and I'll be picking up a lot of ideas from this build...
SparkyRnD
12-09-2015, 07:47 AM
Time for another update. The tilton master has been rebuilt, and all the wiring / pcm / harness came in. The shop is just about done with wiring the entire car, the a/c is 95% done, and the dash has been reinstalled. They are finishing up the wiring, gauges and a/c this week. The battery has been relocated to the trunk, and Optima battery should be here next week. The fuel system components have been ordered and will be installed in the next week or two, and we are modifying the fuel tank we originally built to accommodate the exhaust where we have it going through the frame. Bought the Lokar throttle cable and mounting kit, an EGR plug for the LS1 intake, and had to buy new coils and mounts for the LS1 intake (when I bought the intake, I never bothered to research if the truck coils and mounts would interfere with the fuel rail....which they did). We will also be building our radiator once we finish the fuel tank mods, and will get that installed as well. The front wheels were removed and tires dismounted, and those will be going to Rushforth to change the backspacing. Hopefully, within the next 3-5 weeks, we should be ready to take it to the exhaust shop.
msplichal
03-13-2016, 11:48 AM
It has been a couple months since you have posted any updates. How is the car coming along? Have you started it up yet? Please update us and more pictures would be great!
Matt
SparkyRnD
03-16-2016, 09:05 AM
Yes, more work has been completed and the shop is moving along quickly (they tend to be waiting for me, rather than the previous situation where I was waiting on other shops) :)
The re-hooped Rushforth wheels arrived, and I dropped those off at the shop. The wiring is all but completed, they only lack a few minor things like hooking up the radio / speakers / amps which they are getting from me. The A/C system is installed and only needs to be charged with freon. All glass is installed, fuel system is almost finished (I had to modify the custom tank we built to allow it to sit tighter). Along the way I have been adding tasks here and there, and recently gave them the go-ahead to install the sound deadening, carpet and headliner. It was at that point that we discovered that the headliner clips were shot, and we were missing all headliner channels / windlace, so I had to order all new for those. Overall, I am flat out satisfied with the quality of work they are doing, the time frames, and the communication.
Next steps are to finish the fuel system, for me to make our radiator & fan kit, hoses / miscellaneous odds & ends, install the exhaust kit, modify the rear bumper for the exhaust tips, and then it should be ready to test fire.
Here are some recent pictures. Disregard the temporary front wheels, as those were just some rollers while I was waiting for the Rushforth wheels to be rehooped with the modified backspacing.
https://static1.pt-content.com/images/pt/2016/03/022516a-1.jpg
https://static1.pt-content.com/images/pt/2016/03/022516b-1.jpg
https://static1.pt-content.com/images/pt/2016/03/022516c-1.jpg
https://static1.pt-content.com/images/pt/2016/03/022516d-1.jpg
https://static1.pt-content.com/images/pt/2016/03/022516e-1.jpg
https://static1.pt-content.com/images/pt/2016/03/022516f-1.jpg
SparkyRnD
03-18-2016, 04:48 PM
Went by today to bring the exhaust kit, fuel pump hanger, sound deadening, brake cooling ducts and a bucket of other items. We are getting CLOSE to firing her up. Tires will be re-mounted on the Rushforth wheels in the next week, and the exhaust should be done late next weeks as well. The balance of the sound deadening and carpet will happen in between the other items. Radio and speakers / amps should be installed around the same time. Only pic I took today was the headliner installed. Bad lighting and my camera on my phone has a crap flash, so it doesn't look as good as the installed product.
https://static1.pt-content.com/images/pt/2016/03/headliner-1.jpg
csouth
03-18-2016, 08:25 PM
its getting close!
SparkyRnD
05-18-2016, 07:30 AM
The fuel system is now completely installed, including the Finch Performance Dual Overflow Canister is installed, bleed line for the clutch installed, exhaust system finished, and carpet / sound deadening is done. Friday I will be dropping off the RnD Fabrication radiator with HD fan & shroud kit (dual spal 12" HD fans), as well as the PS Reservoir with AN fittings. All that is really left is fluids, radiator hoses, and a cold air intake and filter, then we'll be ready to fire it for the first time. It'll be a while before I can swing the door panels and seat upholstery, as well as the Redline Lumtronix (or similar) headlights, but for now at least the car is just about done.
Here are a few more progress pics:
https://static1.pt-content.com/images/pt/2016/05/AA0-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA1-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA2-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA3-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA4-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA5-1.jpg
Ben@SpeedTech
05-18-2016, 08:19 AM
Glad to hear you're getting super close!! Any goal date to have it on the road or just playing it as it goes along?
SparkyRnD
05-18-2016, 08:27 AM
playing it as it goes along. I'm hoping to have it started in the next 3-4 weeks, but every time I plan on a date, something hits the proverbial fan :)
gardnerme
05-18-2016, 10:10 AM
Can't wait to see it out and about!!
csouth
05-20-2016, 12:39 AM
Coming along nicely! I'm sure you can't wait to finally hear it fire up!
SparkyRnD
05-20-2016, 05:01 AM
yep, been a long time coming. nearing the finish line now
SparkyRnD
05-23-2016, 07:00 AM
More progress as of Friday. I dropped off the radiator with fans, the PS reservoir and a few other items. Got a short list of parts I need to find in the pile, and a few more minor items to buy, and we'll be just about ready to fire it for the first time. Got a chance to sit in the seat and it felt perfect. The seat is ugly as sin with the current worn upholstery, but I'll fix that after its running and driving. Probably another 1-2 weeks and we'll get to hear it run for the first time. Here are a few shots from Friday:
https://static1.pt-content.com/images/pt/2016/05/AA6-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA7-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA8-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA9-1.jpg
https://static1.pt-content.com/images/pt/2016/05/AA10-1.jpg
gardnerme
05-23-2016, 04:59 PM
I think saying that "seat is ugly as sin" gives sin a bad rap. The rest of the car, as I can personally attest, is gorgeous!!
SparkyRnD
05-24-2016, 05:35 AM
lol, yeah, it is a nasty old seat. But that shall be remedied soon! I still can't get over how the Ridetech suspension puts it at the absolute perfect height. And can't get enough of the Rushforths!
lawrenq
05-29-2016, 06:19 AM
I'm curious, what are the specs of your wheels and are you using a stock length rear end?
SparkyRnD
05-29-2016, 09:13 AM
19x10 Front
20x10 Rear
fronts have 6.5" BS and the rears are 4.625" BS. The rear axle is a Ford 8.8 from an Explorer, and is 1/4" wider on each end (1/2" overall). Mine also have a GM pattern up front and a Ford pattern in the back.
SparkyRnD
05-31-2016, 10:24 AM
it is the last little items that seem to nickle and dime a project to death!
SparkyRnD
06-02-2016, 09:36 AM
Just ordered the hedman exhaust tubing we will be using for the radiator hoses, should have those tomorrow.
SparkyRnD
06-10-2016, 01:00 PM
I dropped off the last of the parts today, and it will be ready to fire next week. Also, we ordered up Redline LumTronix Black Illusions with turn signal headlights (www.HaloHeadlights.co/). We will be running quad lights, and the inner two will serve as the turn signals as well as headlights. Here are a few updated pics:
https://static1.pt-content.com/images/pt/2016/06/AA11-1.jpg
https://static1.pt-content.com/images/pt/2016/06/AA12-1.jpg
https://static1.pt-content.com/images/pt/2016/06/AA13-1.jpg
https://static1.pt-content.com/images/pt/2016/06/AA14-1.jpg
I will get pics of the Redline LumTronix lights on and videos once it's all put together.
csouth
06-10-2016, 06:14 PM
Nice intake tube.... I spun mine over this weekend to find that VATS is still enabled. Getting a reflash in a few days to resolve that issue. You're almost there....
SparkyRnD
06-10-2016, 06:41 PM
Sucks about the VATS, but thankfully an easy fix
SparkyRnD
06-17-2016, 05:42 AM
Got a call yesterday that the shop fired up the engine! Said it idles and runs perfectly. They are sorting out a few minor issues that needed to be buttoned up, but it sounds like it'll be ready for me to go get it next week!!!
csouth
06-17-2016, 12:35 PM
Congrats!
Mr.VENGEANCE
06-17-2016, 03:32 PM
sweet!!
deejai35
06-17-2016, 05:23 PM
That's great!
David Sloan
06-17-2016, 05:43 PM
Sweet
I can't wait for you to drive it . Let me know when you get it home I will stop by check it out��
gardnerme
06-20-2016, 05:59 AM
In your own immortal words: if there is no video, it didn't happen.
SparkyRnD
07-01-2016, 08:00 AM
Finally, after 5 years, I got to drive my car! Of course, it only has a not-so-great base tune, but I did put about a mile on it driving through my neighborhood. Even with a bad tune, that thing has gobs of power! It will be going back to the shop in about 3-4 weeks to have the repaired temp and fuel gauges reinstalled, as well as to dial in a few items. As soon as that is done, it is off to the dyno tuner to get dialed in. Then, back to the buffer / polisher to get the hood knocked out and the rest of the body retouched. After that, it'll be time to get some miles on her.
https://static1.pt-content.com/images/pt/2016/07/070116a-1.jpg
https://static1.pt-content.com/images/pt/2016/07/070116b-1.jpg
https://static1.pt-content.com/images/pt/2016/07/070116c-1.jpg
godlemmy
07-01-2016, 12:18 PM
so Once it is assembled and on the road, I'll be more than happy to give out the color info :)[/QUOTE]
now that it runs, are you going to give up the name of the color?
Angelo
07-01-2016, 12:33 PM
Great looking ride. Glad you got it on the road after five long years. Enjoy!
SparkyRnD
07-23-2016, 01:03 PM
now that it runs, are you going to give up the name of the color?[/QUOTE]
It's not on the road yet :) It has a little ways to go before being done and roadworthy, but yes, I'd be happy to share the color once it has it's legs stretched :)
SparkyRnD
07-23-2016, 01:38 PM
Dropped it off at the Dyno Tuner yesterday. They have a few ahead of it, but it will be ready shortly. Then I'll get it back and fix a few minor issues and start getting it closer to being road ready. But I will say, it definitely has stance (sorry for the crappy pic)
https://static1.pt-content.com/images/pt/2016/07/AA15-1.jpg
Big Dawg
07-23-2016, 01:45 PM
Nice job....can't wait to get my 69 back on the road!!
What size are the wheels and tires.....sorry i don't want to click through 40+pages on this thread again.
KB Camaro
07-23-2016, 03:11 PM
wow what a car. subscribed for final numbers.
SparkyRnD
07-28-2016, 07:51 AM
From one page back ;)
19x10 Front
20x10 Rear
Ben@SpeedTech
07-29-2016, 09:42 AM
Amen to that. And minute and hour it to death too. Glad to see you're real close! You still owe me an autocross grudge match. ;)
SparkyRnD
07-29-2016, 10:02 AM
agreed. Would love to, but you have several years more seat time than I do :)
Mr.VENGEANCE
07-29-2016, 11:19 AM
Awesome!!!
Josh@Ridetech
07-29-2016, 11:51 AM
That's a killer stance!
SparkyRnD
08-01-2016, 02:30 PM
Thanks! Can't wait to plop this in a Ridetech booth somewhere :)
Dyno came back as 362 at the tires. Not bad for a truck engine with a mild cam! Should be ready to bring back on Friday, and then more work to be done getting it closer to road-ready. Have to check some wiring on the Halo's as I think it may be hooked up to the wrong spot and draining the battery.
SparkyRnD
08-08-2016, 08:17 AM
I picked up Sabre from LSXperts this past Friday, and got to drive it a couple miles. The power is incredible, and the short-throw T56 is awesome. We did find that there is an electrical drain somewhere, and I had an Optima that wouldn't hold a charge. I replaced the battery and still have the drain, so time to start chasing it down. The PS pump needs to be bled again as it was making some noise, and the rear end had some noise when turning (have to verify that the shop used LSD additive, as that may be the issue). Also having an issue where the throttle jumps to around 2,500-3k rpm and sticks for a few, and the tuner thought it may be the ported tbody or the TPS causing it, so have to look into those as well. But I will say I love this car and WOW the tune made it fun!
deejai35
08-08-2016, 06:58 PM
Awesome! Great to hear that you drove it. I've been watching this build for a while.
Ben@SpeedTech
08-09-2016, 06:37 AM
agreed. Would love to, but you have several years more seat time than I do :) Not really, I've only been able to race 2-3 times per year since leaving GA. Life is way too busy and the events are too far away once you add up entrance fees and travel expenses. You guys have the advantage, there are so many race venues within a few hours of you guys. In Utah it's pretty much drive 6 hours to SoCal for occasional big events and I can run to Vegas (2 hours away) to get a handful of SCCA laps in between watching a bunch of imports do their thing. I really need to move back to the eastern half of the country...
Good luck with the issues, it'll all be worked out in no time.
wadem
08-09-2016, 11:12 AM
Charlie at lsxperts is a good dude and pretty smart,glad everything worked out good for you and cant wait to see it at some local events around the area
Wade McGowan
Race Part Solutions
www.racepartsolutions.com
SparkyRnD
08-10-2016, 05:11 AM
Looks like we're still chasing electrical issues, as there is still a drain. We'll be tackling that in the next week or three, along with raising the front end up for a while (smacked the pan on my driveway and on a raised hump. I'm looking at one of the Holley pans with the separate baffle kit, as that should get me around 3-4" more clearance. Just don't want to pull the engine yet, may save that for sometime next year. This past weekend I picked up some black leather seats that were basically the same as the junky white ones, but they look better. Only real difference is the driver side has an airbag on the outside left of the upper (which I deployed at the bone yard using some wires and a power tool battery....that was fun), which I didn't want, but for $35 a seat, it will buy me time until I can find a manual black leather driver seat without airbag. I have to get a passenger side mount at another yard in the next week from a different model to fit the mounts on the floor so I can install them. Got a spot scheduled back at the shop to fix a few issues in about 2-3 weeks, and should get some seat time after that.
SparkyRnD
08-12-2016, 06:05 AM
Spent a little time on the seats yesterday. The seats are from a 6th gen (99-05) Monte Carlo, and the bases are manual sliders from a 91-92 Firebird. The floor was modified in that two straight pieces of steel were mounted to the floor with welded / captive nuts under the steel. That allows the Firebird mounts to be bolted directly, and then I can run the Monte Seats (had to drill 2 small holes in the front of the seat chassis), or any Firebird / Grand Prix / etc. I will eventually either have these recovered, or find some perfect condition Monte seats to install. They are damn comfortable seats with good padding, headrests, and in addition to having long sliders (great for tall guys like me) they also have a separate lever on the Firebird base that allows you to tilt the seat bottom up or down with several positions available.
csouth
08-13-2016, 11:11 AM
Good to hear you're out putting some miles on this thing. Hope you find the electrical gremlin....
SparkyRnD
08-15-2016, 02:37 PM
yeah, me too
SparkyRnD
09-07-2016, 07:02 AM
gone as far as I can with that electrical issue, it's going back to the shop. Also, found that the pan hits all the time and adjusting the front will give a little more clearance, but I don't like the stance as much. So I ordered the Holley low profile pan and baffle, and will have the shop install that as well while they have it. Plus, that'll be a good time to get the parking brake system finished, as well as a few other odds and ends.
DreKoushRanada
09-08-2016, 12:04 PM
https://static1.pt-content.com/images/pt/2013/03/E41A0103-1.jpg
https://static1.pt-content.com/images/pt/2013/03/E41A0104-1.jpg
https://static1.pt-content.com/images/pt/2013/03/E41A0105-1.jpg
Great build! Any tips on painting with the doors on? I am doing a 1970 Cutlass.
SparkyRnD
09-09-2016, 08:41 AM
They jambed it out (painted the jambs first) and let that dry, then they later went in an did the doors. Nothing fancy or special, pretty standard
CutLS442
09-30-2016, 04:26 AM
Incredible skills and a incredible machine!!
What is the plan with the hood louvers?
Morten
HectorM52
09-30-2016, 06:46 AM
My car is only a few days from being back on the road... When is yours going to be ready for that North Georgia cruise???
LemonTwisted
09-30-2016, 10:59 AM
Yeah, when are we gonna do that North Georgia cruise?
cdrod
09-30-2016, 12:58 PM
Morten
X2! Inquiring minds want to know!
SparkyRnD
10-02-2016, 05:58 PM
I have a custom piece designed, but not sure what direction I am taking yet to make it (might have it machined from billet, but would have to save up).
The car is back in the shop and they finally figured out what was causing my electrical drain, the alternator. We are fixing that, and the oil pan is being swapped out, and then a few other odds and ends are being finished so that it will be roadworthy. My guess is 3 or 4 weeks and I should have it back, hopefully sooner and then I can start getting a few miles on it and plan something.
I definitely want to plan it or sooner rather than later, but got to have a functioning car first.
cdrod
10-03-2016, 05:56 AM
Sparky:
Do you plan to make the louvers a functional air intake with an air box in the engine compartment? If so, I would be interested in a group buy for a 2nd pair of these, depending on the price of course. I'm not broke, but I'm not a rich man either. Thanks!
Rodney
SparkyRnD
10-25-2016, 06:29 AM
She's ALIVE! Picked the car up friday afternoon, and proceeded to beat the snot out of it for about 85 miles of gear slammin fun! The Ridetech suspension is absolutely amazing, and I could NOT be happier!!! The stance is perfect, it rides great, and handles like nothing else I've driven. Took it to a local show saturday morning, and after hanging out for a few hours I had to leave before the show was over. Turns out it was selected for Director's Choice as the winner, but since I wasn't there it went to another attendee (fine by me, I'm not much for trophies at car shows). I have a few small bugs to work out (couple rattles, idle issue, fuel fill issue, etc) but they are minor. Now just to start getting some serious seat time.
Sparky:
Rodney
No, they are going to be heat extractors only. My assumption is they will be in the $1k-2k range.
gardnerme
10-26-2016, 12:26 PM
It is not loud enough.
SparkyRnD
10-31-2016, 05:09 AM
agreed. Maybe 1 more decibel would do the trick!
David Sloan
11-07-2016, 04:40 PM
looking good buddy
SparkyRnD
11-08-2016, 06:22 AM
Thanks, and hopefully we'll see you on Saturday!
gardnerme
11-08-2016, 08:29 AM
Yeah, David - what he said!
SparkyRnD
03-28-2017, 05:33 PM
Just about time to brush off the dust and get it back outside!
jturkey69
04-23-2017, 05:39 AM
Wow, what absolutely awesome build..all the heartache, headache,loss, and finally success. Looks amazing! I am looking forward to seeing the lighting front and rear. The tails are on my list, and headlights I think I'm gonna go black housing. Where did you get, or modify the front turn signal lights, or are they not functional, or driving lights? Tears ago when we built our Olds Alero show car, we did 78 trans am fender vents dropped in on each side of a custom cowl hood, and we pondered on doing that to our 71 cutlass, but havent decided anything. Right now she's just a cruiser with dreams of being a budget pro touring car..lol
SparkyRnD
04-26-2017, 09:48 AM
Thanks, it's been quite a ride. On the signals, we used RedLine Lumtronix (http://haloheadlights.co/), and they have integrated signals built into the LED headlights. The original turn signal openings in the bumper are now fresh air ducts to the front brakes (with tubing and molded ducts).
beater65
04-28-2017, 01:41 PM
Just curious why not opt to re-drill rear axles and rotors to GM pattern to have set of wheels you could sell to someone later? ( you know, cause sometimes things change)
I assume purely to be able to change rotors without custom work?
Killer build by way, I just spent better part of 2hrs going thru it.
Shawn01754
04-29-2017, 01:09 PM
It's not on the road yet :) It has a little ways to go before being done and roadworthy, but yes, I'd be happy to share the color once it has it's legs stretched :)[/QUOTE]
Mustang lava red?
SparkyRnD
04-29-2017, 06:09 PM
Just curious why not opt to re-drill rear axles and rotors to GM pattern to have set of wheels you could sell to someone later? ( you know, cause sometimes things change). I assume purely to be able to change rotors without custom work? Killer build by way, I just spent better part of 2hrs going thru it.
It's more than that. I built the car to be able to drive to and from long events, autocross all day, run through the curvy mountain roads, and generally beat the snot out of. Knowing what I was going to use it for, I knew that there is the very likely possibility of breaking parts. Rather than spend 3k on an axle and have it break, then have to get a tow home that could be from several hundred miles away, I can now break an axle shaft and go to any local bone yard / pull-a-part / craigslist, and within a VERY short amount of time, find a used matching Ford Explorer 8.8 axle shaft that will slide right in, have no modifications required, and everything I have will bolt right up. Can't do that with a Moser / Strange / etc. axle. Now I do realize that each big-buck axle has it's own advantages, and those companies make some GREAT products. But it wasn't what I wanted on this build. I wanted something I could find easily anywhere I go, find it for cheap, and not have to do any mods to get me back on the road quickly. As for making it easier to sell the wheels.....with what those wheels cost, and how much I LOVE them, they will never be sold. Having two different lug patterns front to rear doesn't matter at all to me :)
Mustang lava red?
Dory Blue. Maybe Muppet Mauve ;) It's a factory brown from a mid-teen's Ford. 100% a factory color, no special mixing or codes. The yellow on the hood and the wheels is a early to mid 2000's Toyota Venza factory color as well. Again, very easy to fix / replicate if needed, and no funky color codes & mixture percentages to have to remember.
Shawn01754
05-05-2017, 06:38 PM
Very cool. I hired a guy that makes custom colors for House of Kolor. He did 5 spray outs for $150. I think it was worth it. I was suprised to learn they were all a simple 2 stage, base then clear. Yours Looks good!
SparkyRnD
05-06-2017, 12:50 PM
Thanks, I appreciate it. It's about time to blow off the dust and set up another ride in the mountains with it.
SparkyRnD
06-09-2017, 06:48 AM
Finally got her out of storage and hit a show & a cruise last weekend. As I drive off (and with a little spirited driving), I realized the temp was climbing up so I pulled over, and looks like the shop that finished up the install had a slight error on the wiring for the fans. They wired both the Spal HD 12" fans in series and used a common ground with a 16ga wire. Needless to say, two fans that pull 60a each at start up were more than that tiny single wire could handle. I nursed it home and installed two separate grounds temporarily with 12ga wire (all I had available) which is better, but will fix them correctly with dual 10ga or 8ga grounds with Weatherpak ends on them. Other than that little hiccup, just an absolute blast to drive!
Sasha
04-16-2018, 10:14 AM
Sparky, any pictures of the finished build? Also, all the previous pics in this thread are now gone! Bring them back, lol!!
SparkyRnD
10-11-2018, 05:44 AM
I just got it back from interior and have to do a little cleaning, then i'll post up some new pics. I think I have copies of all the previous pics, so I may create an album that can be shared (will take a bit to sort through and set it up, but shouldn't be a big issue).
Sasha
10-11-2018, 06:36 AM
Nice! Been waiting for updates to this thread. Reminds me to make a major update to mine as well... ))))
SparkyRnD
07-08-2019, 09:18 AM
Been a while since I've updated, and darn it, still need to get those pics taken and uploaded. I'll try to do that in the next week or so as the car is currently in storage.
David Sloan
07-09-2019, 02:34 AM
Storage you should be driving the wheels off of it!:}
SRD art
07-09-2019, 07:06 AM
Yep lets see it Sparky!!
SparkyRnD
07-12-2019, 04:42 PM
Ran out of the room at the house and have a bunch of other projects I'm trying to work on, so I had to store it elsewhere temporarily. As soon as the storms blow through in the next week or two I'll pull it back out for a couple days and do some driving
SparkyRnD
05-18-2020, 09:51 AM
finally got some pics to upload, and will be putting the car up for sale in the next few days. Just don't have the time to enjoy it like I had thought I would, and can't stand to see it sit.
https://static1.pt-content.com/images/pt/2020/05/1-1.jpg
https://static1.pt-content.com/images/pt/2020/05/2-1.jpg
https://static1.pt-content.com/images/pt/2020/05/3-1.jpg
https://static1.pt-content.com/images/pt/2020/05/4-1.jpg
https://static1.pt-content.com/images/pt/2020/05/5-1.jpg
https://static1.pt-content.com/images/pt/2020/05/6-1.jpg
https://static1.pt-content.com/images/pt/2020/05/7-1.jpg
https://static1.pt-content.com/images/pt/2020/05/8-1.jpg
https://static1.pt-content.com/images/pt/2020/05/9-1.jpg
https://static1.pt-content.com/images/pt/2020/05/10-1.jpg
- - - Updated - - -
http://www.projectsabre.com/Gallery/SabreForSale/11.jpg
http://www.projectsabre.com/Gallery/SabreForSale/12.jpg
http://www.projectsabre.com/Gallery/SabreForSale/13.jpg
http://www.projectsabre.com/Gallery/SabreForSale/14.jpg
http://www.projectsabre.com/Gallery/SabreForSale/15.jpg
http://www.projectsabre.com/Gallery/SabreForSale/16.jpg
http://www.projectsabre.com/Gallery/SabreForSale/17.jpg
http://www.projectsabre.com/Gallery/SabreForSale/18.jpg
http://www.projectsabre.com/Gallery/SabreForSale/19.jpg
http://www.projectsabre.com/Gallery/SabreForSale/20.jpg
- - - Updated - - -
http://www.projectsabre.com/Gallery/SabreForSale/21.jpg
http://www.projectsabre.com/Gallery/SabreForSale/22.jpg
http://www.projectsabre.com/Gallery/SabreForSale/23.jpg
http://www.projectsabre.com/Gallery/SabreForSale/24.jpg
http://www.projectsabre.com/Gallery/SabreForSale/25.jpg
http://www.projectsabre.com/Gallery/SabreForSale/26.jpg
http://www.projectsabre.com/Gallery/SabreForSale/27.jpg
http://www.projectsabre.com/Gallery/SabreForSale/28.jpg
http://www.projectsabre.com/Gallery/SabreForSale/29.jpg
http://www.projectsabre.com/Gallery/SabreForSale/30.jpg
- - - Updated - - -
http://www.projectsabre.com/Gallery/SabreForSale/31.jpg
http://www.projectsabre.com/Gallery/SabreForSale/32.jpg
http://www.projectsabre.com/Gallery/SabreForSale/33.jpg
http://www.projectsabre.com/Gallery/SabreForSale/34.jpg
tommycomfort
05-19-2020, 08:21 AM
Looks awesome Sparky, hate to see you sell it!
SparkyRnD
05-19-2020, 08:44 AM
thanks. Me too, but a car that just sits is a waste, and it looks like I won't have time for some time.
SparkyRnD
07-23-2020, 10:50 AM
back up
