Results 1 to 9 of 9
08-13-2011 #1
Residual Pressure Causing Disc Brake Engagement
I cannot figure this one out; everything works fine when first starting to drive, good movement on brake pedal and no restriction to vehicle movement. After a bit of driving the pedal hardens up and the brakes are not fully releasing causing them to heat up badly. Once this start occurring I have to give it a fair amount of gas to get the car moving it heats up to the point where the rims are hot (all four). I have the pedal rod adjusted to the point that it barely engages the brake switch, which acts as the rear travel limit leaving 3/16" extra space if it needs to retract further. With this extra space I cannot pull back the brake pedal any further, so the rod is fully retracted from the MC.
Here is the setup: LS1 brakes front and rear, 79 TA 4 wheel disc proportioning valve and Wilwood manual 1" tandem MC. Everything, including brake lines, is new except the calipers.
What am I missing? It would seem odd, but does that particular proportioning valve have an internal residual pressure valve? Could it be something internal to the calipers? Any help would be greatly appreciated.Brent
1971 Camaro, LT1, 4L60E
08-13-2011 #2Just got off the phone with Inline Tube, where I bought the proportioning valve. They suggested that I drive the car until the brake problem occurs and then crack a caliper bleeder to release the pressure, then try again and release the pressure by cracking a joint at the MC to try and narrow the problem. I will give this a try, but would be surprised if the issue is a caliper as all four are engaged.
Brent
08-13-2011 #3
