    Results 1 to 20 of 29
      Dec 2010
      Fredericksburg, VA.
      Aluminum or Urethene subframe bushings?
      I have my new DSE subframe assembled and ready to install in my 68 Camaro. But I'm trying to decide if I should use aluminum or urethene mount bushings. I would like to hear what some of pros and cons are of each. I'd appreciate any feedback and opinions.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Chicago suburbs
      Aluminum- no contest. Especially if you are using subframe connectors. I went from rubber to urethane to aluminum, and I can tell a difference. Urethane is nearly as soft as the rubber, and it makes the car feel flimsy. The AL subframe bushings made the car feel more solid. I made the mistake of using urethane suspension bushings too, and pulled them all out. Horrible for susp. bushings, rubber is much better. I have a box of misc urethane bushings that I would give away if someone wanted them- I really dislike them.
      Long Beach, Ca
      Quote Originally Posted by another69 View Post
      What he said.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Milwaukee, WI USA
      Solids all the way.
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
      Rustburg, Virginia
      Another vote for Ally.
      May 2002
      Northern California
      we stopped using body mounts with most of our current builds. straight to the body.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Sep 2004
      savannah,ga
      aluminum subframe bushings on 3 cars over the years, NO contest, aluminum or steel.
      Long Beach, Ca
      This is how I have my Nova.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Using solid for over 6 years.
      Mesa, AZ
      X3 subframe straight to body for me too.
      Rustburg, Virginia
      @ Guys with no body bushings at all(body sitting on subframe),
      Do you run into clearance problems?....ie my air cleaner stud is rubbing the underside of the hood now, if I took out the bushings, I would not be able to close the hood.....and what about tranny tunnel clearances?
      May 2002
      Northern California
      We did, but we dropped and moved the engine back to clear everything. LOL
      Not much room on the them 2nd gens as it is.
      Mesa, AZ
      I have a small block chevy with an edelbrock performer intake and a dropped base air cleaner, I have no clearance issues between the air cleaner and the hood (except for the time I broke a motor mount). Im running a th350 transmission and had no problems with clearance between it and the floor. I did have to replace the steering rag joint with a universal joint to keep the steering column from binding, other than that, no problems. I had previously bought aluminum mounts so i kept them and mounted them below the subframe as shown in the pictures below.
      Oct 2010
      Will bolting the sub frame direct to the body affect the mounting of the front core support?
      Jan 2010
      Elk River, MN
      Quote Originally Posted by SPADE View Post
      The core support has body mounts too, so you can just leave them out as well, provided they're the same height as the subframe body mounts, which they usually are.
      -matt
      Oct 2010
      Ok - so no nothing on the body or core support mounts? What will the metal to metal contact have as far a premature wear?
      Does any one have pics?
      Dec 2010
      Fredericksburg, VA.
      Do you have any trouble installing the transmission crossmember with no mounts?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Oct 2010
      Santa Ana, CA
      wow sounds like i need to swap out my rubbers for solid aluminum's, Thank guy's
      Quote Originally Posted by stilo View Post
      I don't think she's going to like that, especially if they're ribbed! That's going to be some nasty chaffing.
      Templeton, CA
      Quote Originally Posted by 68Formula View Post
      ^^^^^^ too funny!
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
