    Results 1 to 10 of 10
      Feb 2011
      Tight 10s TA(pics)
      here are some pics of the 10s I am putting on my 1979 trans am this a ws6 car so has rear disc brakes
      NO tubs all stock and its tight
      I have a mock up 245 40 in the pic I think I could squeeze a 255 in there but I am not sure.
      Name:  2011-04-23 11.40.00.jpg
Size:  118.9 KB I would lower the car to fill the wheel well BUT my super 44 mufflers are already about 3 inchs off the ground any lower and they would scrap the ground. so i am not sure how people get away with it unless theres scrap or they run glass packs.
      Name:  2011-04-23 11.40.19.jpg
Size:  117.8 KB I didnt roll no fender lip this is stock
      and I hear on here how guy can stuff a 275 under here but i dont see how cause its almost touching on the inside wheel well NO I didnt have to beat my seat belt bump in
      Hope this helps anyone who is trying to stuff a 10 under a 1979 Trans am
      NOTE all cars are not the same 1977 and 1978 could be different
      Ill post more as this build goes on maybe a 255 fits and doesnt Rub the inside will see and ill let you know
      like i said its STOCK and its TIGHT
      Jul 2010
      Sacramento, CA
      Id run the muffler in the OE location, provides more clearance. I guess the camaro and firebird wheel wells are different, my car wears 275's on a 9 inch wheel and has 1.5 inches of clearance.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Aug 2003
      Byhalia, MS
      The problem is the backspacing. What is the backspacking on that wheel?
      Feb 2011
      Quote Originally Posted by makoshark View Post
      I want to say they are 6" deep but ill head the shop and double check
      Orlando, Fl
      Running 275's on a 9.5" on my 73 Camaro. No issues there. PLENTY of clearance. Definitely has to be the backspacing.
      Nick DiPrenda
      Feb 2011
      well the rim and tire shop and the company I ordered the rims from set it up and they are pro when it comes to rims and tires
      so i trust them on the set up they sold me
      FRONT 3 1/4
      REAR 6" deep
      10 7/8 out side to out side
      I think a 255 will sit flush with the rim
      Snohomish, Washington
      All the 10" wheels I have ever boughten all measure 11 inches wide. Are you sure you dont have 9.5s?
      Matt
      Feb 2011
      Quote Originally Posted by muthstryker View Post
      yes they are 9.5s i just call them 10s
      any tips on a tire that will mount flush with the rim
      and doesnt balloon over the edge
      I dont want the rim edge to show like they do with the 245
      I would do a 265/275, I had run 255s on 8.5s and it was perfect
      Matt
      Feb 2011
      ya I am going to try and get a mock up 265 tire to do some test fits
      hope it works
