    Results 1 to 17 of 17
      Oct 2010
      Vancouver B.C Canada
      Honeycomb's with 285/40
      Just got these mounted,fit is great. They work well with the C6 caliper and Kore 3 hubs with the exception of the dust cap. Even with the small dust cap installed I needed a small(1/4") spacer in order to use the wheel centre cap. The centre caps need massaging to actually fit and stay in place.
      My old 17" Snowflake wheels are now for sale.
      72 firebird , SD performance 464" 455,KRE D ports, EZ EFI,Dougs 1 3/4,3.5" custom oval exhaust,TKO600,Kore 3 C5/C6,DSE subframes,Full cage by Radical Rides(Thanks Dave,Johnny,Campbell,Bill,Lee and Gabby!!)
      Oct 2010
      Slightly closer pic
      Jan 2010
      Delaware
      Is that 285's all the way around? Can you take a pic approaching the nose but still to one side enough to see the wheels? Looking good!
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      Oct 2010
Size:  328.8 KBName:  close.jpg
      They are 285/40 Nitto NT555 all the way around. There is still room for more tire, but I think any larger on a 9" wheel would compromise performance.
      Jul 2010
      Sacramento, CA
      Quote Originally Posted by SD455 View Post
      You spoiled Pontiac guys! Car looks great, those wheels really look awesome!
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Jan 2010
      Delaware
      Looks good. I'm not a huge fan of the SD formula look with the shaker and no spoilers......but its a pretty car. Definitely looks like you have some negative camber......what arms do you have?
      I'm putting 285's on my rear for now and 275's on the front. 9.5 inch rims. I'll probably go wider later on the front, and definitely on the rear.
      Jun 2009
      N.Nevada
      Looks like you snuck a cage in there too ! Congrats on the wheels and tires lookin sharp.
      462 Doug Nash 5 Speed Centerforce Clutch Quicktime Bellhousing Edelbrock Heads Solid Roller Holley HP Victor Intake Pump Gas 66 12 Bolt Poly Bushings Hotchkis Springs Metco Control Arms Big bar front Stock rear bar INTRO 20's & 19"s
      Sydney, Australia
      Country Flag: Australia
      Very nice....my Honeycombs should be arriving in a few days .... I hope.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      Mar 2011
      I love those wheels and that price is fantastic. I wish they came in a wider variation than the 9''.
      Oct 2010
      Quote Originally Posted by aronhk_md View Post
      Thanks for the props everyone!
      The arms are Speedtech uppers from Blake. They definitely allowed for more caster, and fit well. IMO one of the better offerings.
      Jan 2010
      Delaware
      One of our fellows that just purchased the new Honeycombs is the first to have the rears widened to 11.5" They look really good. Heres the link....just scroll down to the bottom.
      http://forums.performanceyears.com/f...=652593&page=2
      Feb 2011
      michigan
      Would like some info on your 17 snowflakes you have for sale
      Aug 2006
      austin
      SD455,
      Sweet looking ride. Do you still have stock A-arms on that beast? I put PTFBs upper a-arms on mine and have 0 problems with clearance, even lowered.
      You should put those snowflakes up for sale over at performanceyears.com Lots more '77-'81 T/As over there--but give 2timegoldtransam the first shot
      OOPS never mind.. Speedtech arms. I need to learn to read better.
      Greg
      1976 Trans Am SacrilEdge
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      https://www.pro-touring.com/showthre...ect&highlight=
      https://www.pro-touring.com/showthre...ilEdge-is-free!
      Oct 2010
      How about one from the rear too?
      Have you noticed any rubbing as you drive it around more?
      Jan 2010
      Delaware
      Quote Originally Posted by SLO_Z28 View Post
      Spoiled Pontiac guys.....now if THAT isnt funny.....lmao. And from a chevy owner......lol.
      Aug 2006
      austin
      My 275s are rubbing on my sway bar and frame rail behind at full lock (and my fender on full compression). How are you doing it with those 285s? I'm actually considering going to 255s or 265 up front.
      While cruising to the local Sat night hangout, my drivers front tire caught my inner fender on a hard left turn and bent it inward. Not sure how. (I was missing the two rear inner fender bolts that bolt the fender to that extension that comes out of the firewall.) The bent inner fender then proceeded to cut numerous deep grooves around the inside of the tire. I didn't find it until today when I pulled the wheel for brake inspection! I ruined a $200 tire, maybe 100miles on it.
      Greg
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      Oct 2010
      Quote Originally Posted by opnwide View Post
      Wow! That really sucks about your tire! I am not sure but it could be the fact that I am running about 2.75 degrees negative camber up front. I have never had a problem with the fronts rubbing at all. My toe is set to zero as well,and about 3.5 degrees caster. I love what you have done to your car especially the rear wheels. I have been thinking about ordering another pair and doing something similar,such a stealthy look from the rear,well done!
