    Results 1 to 5 of 5
      Feb 2006
      Tennessee
      What Style Lug Nuts for BMW wheels
      Since I needed new axles/hubs for my disc brake conversion, I had them drilled with both a 5x120 for use now and a 5x4.75 in case I change wheels in the future. I have also the proper sized hubcentric rings to center the wheels on the hub.
      I'll be using 12x1.5mm studs and I need help choosing what type of lug nuts I need for my BBS RS-GT wheels. From my research, I've read that conical lug nuts are recommended for these wheels.
      The only problem is I've found both 45deg conical and 60deg conical lugs, and I don't know which one I need. Any help is appreciated by those in the know.
      Kerry
      Feb 2006
      Tennessee
      Just in case anyone else needs to know, I called BBS today and found out 60 degree conical is what they say to use with there wheels.
      Kerry
      Jan 2010
      Elk River, MN
      Yup that's what I'm using on mine. I actually like using stock take-off lugnuts from ebay, they're not fancy, but they're zinc-plated, high-quality, and really cheap.
      -matt
      Oct 2006
      Corona, CA
      Yes, 60 degree conical is correct for a BBS wheel.
      Feb 2006
      Tennessee
      Thanks Jon!!
      How the little girl doing?
      Kerry
