View Full Version : doing the right thing....?
gEtyOpAPiOn
02-19-2011, 08:39 PM
Im about to minitub my 69 camaro rs ss and it has the original 12 bolt rear end ,the question is ,should I narrow it and add the quad link brackets ..or should I sell it to one of the camaros.net purist ,and fund for a new 12 bolt ? I tried looking at the dse website but i couldnt see an option for the brackets and the 12 bolt housing alone ,just a complete 12bolt housing.
LeighP
02-19-2011, 11:12 PM
Aftermarket 12 bolts are usually a lot better piece than the old factory parts.....I'd go with a complete new assembly.
Ron.in.SoCal
02-20-2011, 03:33 AM
I'd sell it for the resto value and get a new one. FYI - Frank can get you a housing w brackets welded if you need one...
davidk68
02-20-2011, 10:50 AM
I remember seeing a similar post a while back and I think it said 1st gen 12-bolts were bring about $1500 and you can get a set-up Moser for that. I know Frank did chime in. Bottom line, sell it to a purist and get a new aftermarket, just my .02
formula
02-20-2011, 10:56 AM
call DSE. I know we can do bare housings. That may help your decision.
BrianP
02-21-2011, 05:02 PM
Does the original one have the correct gearing and differential unit you want already?
ProdigyCustoms
02-22-2011, 06:16 PM
If that original rear has a desirable code, anything posi, it is worth $1200 to $2500 depending on exactly what the code is. Then we can set you up with a already narrowed, new heavier duty complete rear with all the good stuff for $3000. It will cost you at least a grand to anrrow the rear and do new axles.
Get the code of the front of the passenger tube half way between the center section and end. It will be
letter letter number number
