Results 1 to 20 of 61
Thread: Speedtech Subframe?
02-01-2011 #1
Speedtech Subframe?
I haven't seen many guys running the Speedtech sub-frame for the 69 Camaro. Mostly just the DSE units. Cost wise Speedtech has a big advantage and you can use different spindle and control arm set ups on their unit. Sub only weighs 125 lbs as well. Anyone have any feedback with the Speedtech unit as a comparison?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, QA'1's, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
02-02-2011 #2
Banned
- Join Date
- Aug 2003
- Location
- Orlando, FL
- Posts
- 8,745
It is a awesome piece and recent performance reports of the Speedtech test car Nova prove it. Out gunned by a few hundred horsepower they are within a couple ticks of the baddest cars on the planet at optima Challenge. 5th overall with 450HP to 500HP at that event is pretty damn impressive!
You being in Canada, even makes it more of a no brainer.
02-02-2011 #3
- Join Date
- Jan 2005
- Location
- Netherlands
- Posts
- 1,012
wat is the diferense in weight against the stok frame ,and will it house a pontiac engine!.
also can you run al the other stock stuf stearing box ecetera...and what is the price of a bare frame..thanks
02-02-2011 #4Subframes are for F-bodies and accept small block, big block and LS engines. Sub weighs 125 lbs and in bare steel, cost is $2195
http://www.speedtechperformance.com/...rod/prd145.htm69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, QA'1's, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
02-02-2011 #5
