    Results 1 to 6 of 6
      Jul 2010
      Mooresville,NC
      2nd gen camaro.....17x9 fronts????
      Hey guys...I want run 17x9 front and 17x9.5 rear on 70-73 camaros....think i would be a nice stance....anybody running this combo?...or just the fronts and what tire size??
      Matt
      1971 Chevrolet Camaro RS-Detroit Speed Equipped
      1966 Chevrolet C-10-Driver/Project truck
      Monterey Peninsula
      Running a 9" front wheel may limit your turning radius inward Matt...I'm thinking a 17x8 (4.75" b/s) with a 255/45 tire would fill the wheelwells up quite nicely...
      www.buickfunnycar.com
      Didn't the Hotchkis camaro run 17x9 1/2 & 11's with a stock front sub and the factory wheel wells. If I remember correctly the Spectre Performance camaro the lime green 2nd gen that was previously built by Cam from optima also is running a 17x9 1/2 you could check into to those and see what you come up with.
      http://www.spectreperformance.com/#CARS
      http://chevyhighperformance.automoti...photos0-0.html
      Here's a pic of Cam's Camaro at Buttonwillow
      http://www.racehome.com/images/otd11...glasparked.jpg
      Jul 2010
      Sacramento, CA
      You can fit a 9 inch wheel no problem with the right backspacing, depending on how low your front it. The green car has a 9.5 and you can see where it ends up, if it was as low as my car it would come down on the fender. Like john said a 8 inch wheel with a 245 fits very nice and wont rub. You can easily fit a 17x10 on the back so a 9.5 is fine.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Jul 2010
      Mooresville,NC
      Quote Originally Posted by musclecarjohn View Post
      i thinking about that too john.......same specs...i think that be just right cause my lowered about 2 1/4 in the front....
