View Full Version : Project TechnoStang 66 Mustang Coupe
Crestronwizard
01-07-2011, 01:10 PM
Well, this is what I have to start with. Named it project TechnoStang because I plan to incorporate a lot of technology into this buildcentered around an in dash touchscreen (automation control is my day job). This will be used purely as a street car and any ideas are welcome.
4348043481434824348343484434854348643487https://www.pro-touring.com/images/misc/pencil.png
Ratty 46
01-07-2011, 06:20 PM
I'll be watching .... your day job should lend to this build with some kewl upgrades.
Ratt 46
Bryce
01-07-2011, 08:02 PM
welcome!
CruizinKev
01-08-2011, 02:05 AM
nice project! good luck! :twothumbs
Crestronwizard
01-08-2011, 10:42 AM
I guess this is progress :-). Neighbors stopped by so I put em to work! My oldest son , Jake, helped a lot. Front end and all exterior chrome, etc is next.
72mach1
01-08-2011, 01:03 PM
Look forward to seeing where you decide to take it.
Crestronwizard
01-08-2011, 08:12 PM
Nothing earth shattering to show but the easy part is almost done.
http://albums.phanfare.com/isolated/eMFTdKxz/1/4972696
Crestronwizard
01-10-2011, 12:59 PM
Car is stripped. Need someone that does bead blasting in NC. Any suggestions?
Fast68back
01-10-2011, 01:12 PM
Cool project!
Crestronwizard
01-11-2011, 07:07 PM
Some updates today........I ran across a 2004 Aluminum block 4.6L and a set of 4V heads so looks like I will be going the modular route. I will need a rotating assembly for it and recommendations are welcome. I will most likely put a turbo on it. Also talked to a body shop so may get it in sooner than I thought.
chunger
01-11-2011, 08:53 PM
So I take it you're planning on something big for the front end of this car? Tube frame?
Wesley J
01-12-2011, 05:55 AM
Nice. I'm going the same route, 4.6L 4V. I've been wanting to add a turbo as well but have decided against it due to packaging. My car ('67) is significantly wider and I'm going with a tubular front end w/struts. I'll be interested to see what front end you go with and how you package the turbo.
I am leaving my options open though. I'm planning for a ~400 HP NA motor at about 10:1 so I'm still open for some pressurizing. These motors run cool and have such good heads that you can easily throw 15 psi at them at 10:1 with out issue.
I look forward to the build!
Cheers,
Wes
Wesley J
01-12-2011, 05:59 AM
Oh ya, rotating assembly: I went with used cobra stuff. The forged crank (96-98, 03-04) is supposed to be good to 900HP and 8500 rpm. The 03/04 cobra rods are Manley H beams good to similar power levels (96-98 cobra rods are junk). They can be had used for $200-300 each.
Not sure what you know about mod motors but stay away from the B heads if you can, you cant find intakes very easily.
Cheers,
Wes
Crestronwizard
01-12-2011, 06:19 AM
Yes, exploring options now but regardless the shock towers are coming out :-). Thanks for the tips on the crank and rods and heads.
cobraguy65
01-12-2011, 06:25 AM
Nice project! I am also a fan of the 4V engine. They are very efficient at making power. Mine has dynoed over 500 hp NA. As Chunger illuded to, Its a wide engine due to the double overhead cam design. This will require you to remove the shock towers. There are several manufactures on this board that can help. I would start by looking here www.totalcostinvolved.com/mustangf&r_intro.cfm
Crestronwizard
01-16-2011, 04:44 PM
Put Jake to work and did some de-greasing. Car smells less musty now :-). Picking up the 32V 4.6 tomorrow. I really need some suggestions for the front and rear suspension. Been browsing posts and the TCI looks pretty good......
4381843819
2blownstangs
01-16-2011, 05:46 PM
nice project there man. Kinda strange that I'm selling my 3V 4.6 on the cheap too. Keep us posted on the build. I would go AirRide on that baby!
racedaddy
01-16-2011, 06:17 PM
pm me with a price for the 4.6 and some more info on it
BulldawgMusclecars
01-16-2011, 07:48 PM
Nice project! I have 3 customer Mustangs in the shop right now (a '66 gt coupe, a '67 "Gt500E" convertible, and a '65 fastback that is getting the R-model treatment). None are getting mod motors unfortuantely...I've been itching to do one.
Crestronwizard
01-17-2011, 09:05 AM
I am looking at RideTech's system. Anyone done one on a Mustang? Pro's and Con's?
Crestronwizard
01-17-2011, 09:47 AM
Thanks! I emailed them for some info.
Crestronwizard
01-19-2011, 06:55 PM
Picked up the engine today
Crestronwizard
02-13-2011, 09:03 PM
Finally did something today. Yanked the fuelie 302 and AOD out. What a mess :-). Almost bodywork time. Dropping off 32valve mod motor at machine shop tomorrow. Should get interesting soon.
chunger
02-13-2011, 10:48 PM
You're not going to fab it up first? Just going straight into the rebuild?
Crestronwizard
02-14-2011, 06:01 AM
Lot's of work to do before I get into changing out the suspension and being ready for the engine. Might as well go ahead and have the machine work being done. Have to multi task to get these things done!
Wesley J
02-16-2011, 06:23 AM
Nice build. I'm working on a similar project and I hope to be placing my 4.6 4V/3650 in this weekend for mockup for mounts.
Crestronwizard
02-16-2011, 06:25 AM
Hi Wes..........I am following your build. I plan to check out your build when I am up in Calgary around May.
Wesley J
02-16-2011, 06:33 AM
I look foward to it. You mentioned a touchscreen early on and I'm guessing you're a wizard at programming Crestron gear, LOL. You're not actually integrating Crestron stuff into the car are you? I'm a Home Theatre guy, used to do some PC based control stuff, now I'm using my iPad for the HT control and whole house audio but I digress...
I'm looking at a mobile PC/touch screen for controlling the Megasquirt3 thats going in so I'm interested to hear your thoughts.
Cheers,
Wes
Crestronwizard
02-16-2011, 06:36 AM
I look foward to it. You mentioned a touchscreen early on and I'm guessing you're a wizard at programming Crestron gear, LOL. You're not actually integrating Crestron stuff into the car are you? I'm a Home Theatre guy, used to do some PC based control stuff, now I'm using my iPad for the HT and whole house audio but I digress...
Cheers,
Wes
I am going to be integrating Crestron into the car :-). I am leaning towards an iPad built in that controls the windows, AC, ignition, fuel system, etc. I am going to do some research and let you know what I find on the Megasquirt3
Wesley J
02-16-2011, 06:53 AM
So, can you expand on the hardware you'll be using for IO with the car?
Crestronwizard
02-16-2011, 09:01 AM
I will have more of a solid list soon but primarily will be based around the new Crestron 3 series processor along with relays that I can control. The EFI control will still be third party but I will have it on the touchscreen.
bingham72
02-17-2011, 07:25 AM
Sounds like cool stuff going on in the dash. I've been interested in creating a touch-screen dash for some time now. Just can't seem to get together all the pieces just yet.
Wesley J
02-17-2011, 11:24 AM
I'd love to see something wifi or BT based so one could use an iPad. Kinda like what Innovate Motorsports does for their obd2 reader.
I think I'll roll my own with a mobile pc and use the iPad as my display device.
Wes
Crestronwizard
02-20-2011, 07:01 PM
Crestronwizard
02-21-2011, 06:45 AM
Nothing special to see but helps me to look back and see that I actually have made some progress!
Crestronwizard
02-22-2011, 09:20 AM
I need a recommendation on a mini tub kit................
cobraguy65
02-22-2011, 12:26 PM
Not sure there is a kit for your application. Most likely have to splice a strip of metal into your existing wheel houses.
Wesley J
02-22-2011, 12:35 PM
I've been looking too.
http://www.autoworksparts.com/wheel_tub_kit.htm
https://static1.pt-content.com/images/pt/2011/02/wheel_26-1.jpg
Wesley J
02-22-2011, 12:38 PM
For what they are and the cost to get them here, I think I'm just going to build a copy. If my wife found out I have all of the tools to build them, then bought them, my you know what would be in a sling....
Crestronwizard
02-22-2011, 12:41 PM
I can ship to Calgary pretty cheap.
Jon Clough
02-22-2011, 08:12 PM
nice wheel tubs
Wesley J
02-22-2011, 08:49 PM
Thanks a bunch for the offer. When it comes time I may take you up on it. I'm still trying to decide where I'm going to stop this winter. I want to be back on the road by May/June so I have to pick my battles, and I've chosen a pretty big one....
Crestronwizard
02-23-2011, 05:10 AM
wow, yes you have! especially with the new addition to your family. Stay diligent :-)
Crestronwizard
03-05-2011, 03:35 PM
Well, I learned two things today. (1) A plasma cutter is the most awesome tool ever invented. (2) It has been way too long since I've done any welding. I cut out the rear floor pans and did a better job on the second one. Will attempt to weld in correctly next time that I can make it out to the garage.
Wesley J
03-08-2011, 12:06 AM
:postpics:
Crestronwizard
03-08-2011, 04:25 AM
Very funny Wes :-)
First time with a plasma cutter:
Crestronwizard
03-08-2011, 04:06 PM
Hi Guys......need some help making a decision. I will most likely need to do some frame repair (maybe just the extensions). I am already planning to do a coil over conversion and get rid of the shock towers to make room for my Cobra engine. So here is the question. Do I just go all in and get a Chris Alston chassis (I don't have Wes's skills to make one from scratch) or just put in the repair rails and move on. Thanks!
THE TECH
03-08-2011, 06:21 PM
Nice project. Can't wait to see the goodies.
chunger
03-08-2011, 08:44 PM
Since you ask - I vote for the whole new frame. One, you've already got it mostly torn down, so it's not like it's that much extra work, and (2) you're going to have to do something with the front end. To me, it doesn't make much sense to do all the work that the front end is going to require and then *not* do much to the rest of the car.
So, I'd say, why stop in Chicago when you really want to go to New York?
racedaddy
03-09-2011, 06:45 AM
If you're gonna be a bear be a grizzley, go all out
Crestronwizard
03-09-2011, 10:43 AM
Ok, going the full frame route.....Frank has something sic for me. Stay tuned
Wesley J
03-09-2011, 01:40 PM
Agreed, full frame for sure. That being said, you may be generating a lot of fab work in other areas.
Cant wait to see what you come up with.
Crestronwizard
03-09-2011, 01:41 PM
Yeah, I am going to be watching yours like a hawk! how to mount the fenders, etc,etc, etc
Crestronwizard
03-11-2011, 05:47 PM
A couple of friends and I carried the car outside today. It's a little heavier than it looks! Now I can clean the garage. Going to cut out the floor completely to make way for an Art Morrison Max G frame :-). If anyone needs a stock front frame rails/shocktowers and are near NC let me know and you can have it, otherwise I'm going to cut it up with the plasma cutter
blown9746
03-11-2011, 08:58 PM
where in nc are you?
Crestronwizard
03-12-2011, 07:52 AM
Mebane...........it's between Greensboro & Chapel Hill
Crestronwizard
03-12-2011, 12:48 PM
Front end cut off
Crestronwizard
03-21-2011, 05:22 PM
Did some cutting to get ready for the chassis. Will weld in braces and finish this week
Got the engine up on a stand.
ProTouringCuda
03-23-2011, 06:25 AM
Look at Art Morrison too. I bought their Max-G rolling kit for my Barracuda. You won't be disappointed with their work.
Crestronwizard
03-23-2011, 06:36 AM
That's what I am using. Have you installed it yet?
ProTouringCuda
03-24-2011, 05:34 AM
Sorry -- I missed your earlier post about using AME. Great choice.
For mine, see my build thread. I've updated my sig with the link.
Crestronwizard
04-18-2011, 02:48 PM
Finally rolling around.......sort of, lol
chunger
04-18-2011, 07:05 PM
Wow, are you going to add in any temp bracing since you cut away so much metal? Are you worried about the body shell warping out of shape?
Crestronwizard
04-18-2011, 07:43 PM
I already did. You just cant see it in this pic. Going to add in some more to the roof as I take out the rest
Nice! Glad to see it's torn apart!!
Crestronwizard
05-01-2011, 02:10 PM
Finished removing most of the little metal that I needed to. All that's left is taking out most of the firewall. My wife looked at it today and said " There's more you can actually take off?". Funniest was my oldest's comment " Dad, didn't we pick this car so we wouldn't have too much body work?" Well son, there's not much body left, does that count??? :-)
ProTouringCuda
05-01-2011, 05:14 PM
I posted under the wrong thread. Sigh... Sorry. Original post (quoted below) has been replaced with this.
Actually, to put a meaningful bit in here - it looks like you're at the same point in your project as I am. I'm getting ready to cut the firewall out in the Barracuda here shortly.
Crestronwizard
05-02-2011, 03:07 AM
OK - worked on the car a bit today. But first - a new addition to the garage/shop: A Miller Diversion 180 TIG welder. It's an awesome unit that runs off 120V or 220V - whatever it takes. Also, didn't really want to spend time building my own welding table - so I bought one of Millers.
Hmmmmmm.........you set all this up in my garage?? :-)
Wesley J
05-02-2011, 04:45 AM
You'll be happy with that welder. I've got last year's 165 and its great, I've burnt a lot of rod with that thing and its still running perfect. Not sure if you're a welder or not but I've moved to the 2% Lanthinated tungsten (NOT 1.5%) and its been great. I use it sharply pointed for everything, steel, aluminum and stainless and it works fantastic. If you're using the right diameter for the amperage then it holds a sharp tip, even on AC.
Crestronwizard
05-02-2011, 11:42 AM
No worries..........funny thing is I actually need to purchase a welder so this has all been great info :-). Counting down the days till the frame arrives.
ProTouringCuda
05-02-2011, 12:41 PM
Well, as it turned out, there was an update notification to your thread and one to mine as well that came one right after the other. I just clicked on the wrong one
Anyway, the Miller TIG is a great machine. I see you have some Lincoln stuff there (as do I), but for my first venture into TIG, this machine is as easy as they say it is. And, did I say it runs off 120V? Really slick. More expesive than MIG, but IMO, worth the extra $$$. I have a Millermatic 130 MIG that's on loan from my father-in-law if I need it, but since I didn't have a welder of my own, I went the TIG route.
I've posted a few pics of on my thread, as to not take away from yours.
Crestronwizard
05-11-2011, 04:01 PM
Anyone know where I can find the pics of this car being done? http://67mustangblog.com/2008/04/art-morrison-twin-turbo-1967-ford-mustang-fastback/art-morrison-twin-turbo-1967_ford_mustang_fastbackstripped_body/
The link on the site no longer works..........
Crestronwizard
05-18-2011, 09:10 AM
I need a set of cheap 18" wheels to roll my chassis around on. Any ideas? Thanks
rfalker1
05-18-2011, 11:05 AM
cool build... I see you are shedding alot off weight. Best of luck and craigs list or the junkyard
Crestronwizard
05-31-2011, 11:36 AM
Loaded up for the trip to Chemstrip
There she goes.......
drflex
05-31-2011, 04:37 PM
thats the bobby alloway mustang
http://www.streetfire.net/photo/bobby-alloway-mustang-build_1045177.htm
Crestronwizard
06-01-2011, 09:23 AM
Thanks!
chunger
06-07-2011, 07:47 PM
Any updates? Did you get the body back yet?
Crestronwizard
06-08-2011, 12:09 AM
It's a 6 week backlog :-(. Will be getting it back about the same time the chassis arrives. Went ahead and dropped the engine at the machine shop since there's downtime.
rfalker1
06-08-2011, 12:14 AM
So knows a good time too order parts!! because stuff will try to change or be late on you when you need it most!!!!!
Crestronwizard
06-13-2011, 02:22 PM
Scott @ AME called me today and the chassis is going to ship on or about the 20th.....whooooooohooooooooooo!!!
Now I have to decide which rear gear to run. Thoughts are a 3.55 with a 5 speed or 3:90 ish with a 6 speed. What are everyone's thoughts? Engine is the 4.6 DOHC with either a blower or twin turbos.
Wesley J
06-13-2011, 03:32 PM
I'm going to run 4.10's with a T-56. Top speed should be 203 mph by the numbers with my tire diameter....
Crestronwizard
06-13-2011, 04:33 PM
My concern is how much use I'll actually get with first gear.............what first gear ratio are you going to run?
Crestronwizard
07-07-2011, 03:59 PM
Finally!! Progress :-). Chassis arrived today. I will be in Canada all next week so plenty of fun when I get back!
Crestronwizard
07-07-2011, 04:00 PM
racedaddy
07-07-2011, 04:40 PM
Looks sweet even in the box
Crestronwizard
07-10-2011, 07:58 AM
What kind of paint is preferred on the frame?
ProTouringCuda
07-10-2011, 06:06 PM
Hey - that crate looks familiar! I shot mine with epoxy primer to keep the rust away while building. Will save a lot of time later.
rustomatic
07-10-2011, 07:39 PM
With that frame, even with your planned power adders, I'd be looking at what's lightest. One overdrive is plenty, and first gear is a joke, even with a stock motor...
Wesley J
07-11-2011, 05:18 AM
The reason for the high mph is a 7800 rpm redline, makes a big difference. First gear will be quite useful as this will be my daily driver.
Frame looks stellar!
My inbox is empty, shoot me an note when you get a chance.
Wes
Crestronwizard
07-11-2011, 04:08 PM
Wes
I'm in Calgary........sent you a PM before I left ( I thought). Will send another one now
number98
07-22-2011, 12:16 PM
Did I miss it or did you give us the specs of the chassis? I have been looking at an AME chassis for my 67 Mustang project.
Crestronwizard
07-22-2011, 12:29 PM
linkstar69
07-22-2011, 03:06 PM
Talk about going for it. Great stuff man
Crestronwizard
07-22-2011, 03:08 PM
I have the pdf of the specs if you want it
Crestronwizard
07-22-2011, 03:09 PM
Thanks for the info......how are you running your fuel and brake lines?
number98
07-22-2011, 06:40 PM
That would be great man, could you shoot it to me in an email? I will PM you my info!
Like I said this will be a sweet project!!
Crestronwizard
07-27-2011, 02:58 PM
Anyone need a fresh built 4.6 4V engine? All aluminum. Cobra Crank, Manley Rods, Ross flat top pistons. Cobra 98-00 cams. I am going to either go with the Coyote or I may have a line on an all aluminum 5.4. Thanks
devwil68
08-01-2011, 05:14 PM
its coming along!
Crestronwizard
08-14-2011, 06:02 AM
Back from Carolina Chem Strip
Crestronwizard
08-14-2011, 11:51 AM
I want a different front nose for the car but don't like the Eleanor kit..........any other suggestions?
Crestronwizard
08-27-2011, 05:00 PM
Frame is painted........
chunger
08-27-2011, 10:37 PM
Wow, judging from that pic - you have a LOT of room to work on cars!!! Sure makes my garage feel cramped! Nice!
HighOctane
08-28-2011, 11:52 AM
There is always the R model style nose?
Wesley J
08-29-2011, 05:26 AM
This is a perfect example of scope creep! I love it, the frame is looking great and judging by the shot of the crate, you have a cage as well.
irregal83
08-29-2011, 11:28 AM
awesome project.. ill be looking for updates!
jr4452
09-02-2011, 07:34 PM
This thing is going to be awesome! Keep posting, and I'll keep drooling!
JR
Crestronwizard
10-06-2011, 04:32 PM
Can't believe a month has gone by without doing much of anything :(. Started putting the front suspension together and laid out the rear end parts. I will be working on it this Saturday and will take pics of the (hopefully) completed front end :)
irregal83
10-07-2011, 02:12 PM
sweet! will be lookin for updates !
Crestronwizard
10-11-2011, 10:19 AM
Crestronwizard
10-11-2011, 10:20 AM
Put together the hubs..........I should be finished any day now, lol
Wesley J
10-11-2011, 10:49 AM
Man that looks fantastic!
Crestronwizard
10-11-2011, 10:58 AM
Thanks for the encouragement Wes................every time I start working on it 30 mins later I realize I need a part or more often, a tool!
ProTouringCuda
10-11-2011, 05:34 PM
Hey - that looks familar!
Crestronwizard
10-11-2011, 05:39 PM
How are things going on your project?
ProTouringCuda
10-11-2011, 05:45 PM
Project is temporarily on hold...
Wesley J
10-11-2011, 06:55 PM
See, there is something positive about me building every fusking part... LOL
linkstar69
10-12-2011, 12:50 AM
Frame certainly looks good
Crestronwizard
10-21-2011, 03:01 PM
Started putting the rear end together. Have I said I hate doing safety wire? I hate doing safety wire.........anyways. Should finish that part up and be under the frame Monday. Front brakes are together. Ordered my wheels from Jason @ Rushforth so will be rolling around the shop soon. :)
nacnac
10-21-2011, 08:46 PM
Im having frame envy. How much did the frame set you back if you don't mind?
Wesley J
10-22-2011, 02:00 PM
I dont mean to be rude but where the hell are the pics? ;-)
solarguy09
10-22-2011, 02:27 PM
Nice Mustang.....Congrats on the Rushforth Wheels....Great Choice... Mike V.
Crestronwizard
10-22-2011, 03:45 PM
I am making you wait.........I believe we had to wait a long time on somebody's ^^^^^^ project :)..........seriously, I will have some Monday. Thought I would work on it some today but the wife and I had some "alone" time as the boys were out of the house. And with her 7 months pregnant I take full advantage when at all possible :)
Crestronwizard
10-22-2011, 03:49 PM
The frame itself wasn't too bad (maybe $5k??) but I went all in on a total package and spent $17k including shipping. But that was the frame, full IFS front suspension, triangulated 4 link rear, complete Strange Engineering 9" rear (well, all the parts, I put it together), 13" Lightweight Wilwoods all the way around - 6 piston front and 4 rear, sway bars, I think that's about it.
nacnac
10-22-2011, 06:27 PM
that's how they get ya. I'm too far into my build to get a frame anyway and the price totally puts it out of the question. I'm still jealous though.
Crestronwizard
10-22-2011, 07:28 PM
Yeah. If I had skills like Wes or some of the other gifted builders on here I would have done it myself. Just ready to get through this stuff and into what I do well
Crestronwizard
10-24-2011, 05:05 PM
Mocked up some body panels today
Wesley J
10-25-2011, 05:42 AM
Sweet. This car is gonna be awesome, cant wait to see it on the chassis!
I plan to have mine on the ground this weekend, just need to finish machining my camber plates. No pics for you though ;-)
MSTSFabbed
10-25-2011, 06:02 AM
What, you don't just LOVE drilling Grade 8 bolts hahaha! Car is looking fantastic and that frame is amazing! AM does some incredible work. :yum:
Crestronwizard
10-25-2011, 06:05 AM
Luckily the bolts already have the holes for me :)...........
Crestronwizard
10-27-2011, 11:19 AM
Put the pumpkin, axles and parking brakes on and set the rear end back in the ca....er......frame :)
Good pic of the frame and body
Test fit a rotor
Crestronwizard
10-29-2011, 11:07 AM
Some pics with the rotors and calipers mocked up for clearance check
SRD art
10-29-2011, 11:21 AM
Looking great Geoff, keep it coming!
Crestronwizard
10-30-2011, 11:34 AM
Question for anyone that has done a body drop.............do you just weld the rockers right to the frame or use angle iron and weld that to the rockers first and set in on the chassis so you can bolt it or weld it .....or a third option? Thanks!
Crestronwizard
11-09-2011, 10:32 AM
https://sites.google.com/a/theconders.com/roadster/
This is who will be doing the metal work on the car. Should move along now. Get it to the point where I can do what I do best :)
85coupe50
11-10-2011, 08:45 AM
Can't wait to see some more progress on this. Great job so far.
ryeguy2006a
11-10-2011, 11:14 AM
nice project. Love the frame.
rjsjea
11-10-2011, 02:21 PM
Good looking project......I just acquired a 66 coupe and your thread is good motivation
Crestronwizard
11-11-2011, 05:11 AM
Thanks for the comments :)..........meeting with the body guy this morning...........may be off to paint prison soon............
Crestronwizard
01-03-2012, 06:40 AM
53282532835328453285532865328753288532895329053291 5329253293532945329553296
Crestronwizard
01-04-2012, 05:24 PM
ProTouringCuda
01-05-2012, 08:43 AM
Would really love to see the full size pics to see more of the detail. they available anywhere?
Crestronwizard
01-05-2012, 08:54 AM
I'm going to retrieve them tonight and upload. Been on the road so thats the best I could do.
Crestronwizard
01-06-2012, 05:56 PM
Crestronwizard
01-17-2012, 11:48 AM
I need a recommendation to source the new 5.0 engine and a 6 speed tranny for it. Thanks
Wesley J
01-17-2012, 12:21 PM
Do NOT use Sean Hyland Motorsports. I can elaborate via PM if you like, but trust me on this one.
Car's looking great!
Crestronwizard
01-17-2012, 12:26 PM
Understood...........I have some more pics I'll post tonight. I was dealing with American Powertrain but can't get them to get me a quote.......
ProTouringCuda
01-17-2012, 04:33 PM
I would not recommend Keisler either. They were clueless with my T56.
I'd look at Ford Racing for the Coyote.
69lsxamx
01-17-2012, 06:07 PM
here is a good deal on the coyote
http://www.lightningrodder.com/forum/showthread.php?t=82502
MSTSFabbed
01-18-2012, 07:11 AM
Well then what are you whining about ??? hahaha jk ;)
85coupe50
01-19-2012, 06:52 AM
Call this guy at Ford here in Houston for a crate 5.0 and 6spd...
Anthony Hoekstra (HECKSTRA)
Tell him Matt Buckmaster pointed you his direction.
www.TOMMIEVAUGHNPERFORMANCE.com (http://www.TOMMIEVAUGHNPERFORMANCE.com)
[email protected]
[email protected]
713 802 6600
Crestronwizard
01-19-2012, 10:37 AM
Thanks for the info guys.......wish me luck
Crestronwizard
01-19-2012, 10:38 AM
The floor is shaping up
I will have a pic of the wheel tucked in the wheelhouse soon.........
85coupe50
01-19-2012, 10:47 AM
Pics don't seem to show for me. I changes the header on them to make url links. Hope that's OK?
http://cdn-3-service.phanfare.com/images/external/1321186_5416866_148507580_Full_2/0_0_d6b04cac28f09ce40f72772ec4e628e7_1
http://cdn-3-service.phanfare.com/images/external/1321186_5416866_148507592_Full_2/0_0_a26049152e9fea75c5dfee9516a37d91_1
http://cdn-3-service.phanfare.com/images/external/1321186_5416866_148507598_Full_2/0_0_ec1367cff09ee107fcc831154d13630e_1
http://cdn-3-service.phanfare.com/images/external/1321186_5416866_148507617_Full_2/0_0_db3fab3b613923231f3586cc8e622d40_1
Looking Good by the way!
chunger
01-19-2012, 04:35 PM
Sweet. Looks like you also shaved the driprails?
Crestronwizard
01-19-2012, 05:46 PM
Thanks.......yeah......they're gone :)
Crestronwizard
01-27-2012, 06:44 AM
Bryce
01-27-2012, 07:12 AM
Awesome rendering!
xsuperjoex
01-27-2012, 07:16 AM
LOL your renderings' license plate made me perk up....I was like hmm that looks like NC. Then I checked your profile and it is! I'm in Charlotte. Great car and incredible work so far. I hope to see it in person one day on the road or at a show.
Joe
Crestronwizard
01-28-2012, 04:59 AM
Crestronwizard
01-28-2012, 05:09 AM
[email protected]
[email protected]
713 802 6600
Great guy to work with. Thanks for the contact!
85coupe50
01-30-2012, 06:57 PM
No problem... He's a little loud at times but is a great guy! Hope it all works out. I buy from him ALL THE TIME... Helps that he is local to me but he will make sure to get you what you want at a good price...
Crestronwizard
01-31-2012, 01:53 PM
***BUMP*** Cause I want some feedback................all this new work and just a couple of comments????? :)
1tuff68
01-31-2012, 02:23 PM
All I can say is you are doing phenomenal work, and I can't wait to see more progress!!
dusterbd13
01-31-2012, 07:26 PM
looks good, man.
im digging the sheetmetal and frame work.
renderings also pretty cool.
back to lurking on your thread now, but keep up the good work.
michael
78CobraII
02-01-2012, 08:10 AM
I noticed the bushings between the frame and the body. Will the body be removable? Is there a particlar reason for changing from unibody to body-on-frame? I understand that the car will will be stiffer with the dedicated frame, but I'm wondering if it would work just as well integrated with the body via welds.
Great work! I'm really enjoying your project.
Crestronwizard
02-01-2012, 03:21 PM
Thanks for the comments. Working on a really cool modification in the rear and hope to have pics up soon.
The body will be removable. Going to take the whole thing apart once all the fab work is done and send it to paint.
85coupe50
02-02-2012, 06:25 AM
***BUMP*** Cause I want some feedback................all this new work and just a couple of comments????? :) The car iscoming along nicely... Excellent work.
MSTSFabbed
02-02-2012, 10:22 AM
The floors are looking fantastic! Very nice bead rolling!
Crestronwizard
02-04-2012, 06:03 PM
Who is the best source for custom fuel cells?
kmdracer
02-04-2012, 07:43 PM
Can't help with the fuel cell, but I'm gonna be following this, and can personally recommend Tommie Vaughn Ford. Have done business with them off and on for years.
ProTouringCuda
02-06-2012, 07:20 AM
Well, I'm looking at two sources - not Fuel Cells per sey, but tanks. Ricks Tanks with the Vaporworx setup, and also another guy here who teamed up with a fellow Mopar guy hand building stainless tanks. I'm actually wanting a tank silimar to the stock 1st gen Mustang tank (top mounted, with top of tank = trunk floor). Looking to get a polished stainless tank made up, but still working on it.
ILLMATIC
02-06-2012, 07:38 AM
wow this one hell of a build
Crestronwizard
02-07-2012, 10:42 AM
Thanks..........have to get that coming soon. My Engine and tranny shipped today :) :) :)
Wesley J
02-07-2012, 10:56 AM
Man, that thing is coming along fantastically! She's gonna be a rocket ship when its done. Super impressive!
Wes
Crestronwizard
02-07-2012, 05:04 PM
Custom quarter extensions and bumper molded in
Crestronwizard
02-07-2012, 05:05 PM
Sorry about the pic quality.........iPhone
linkstar69
02-07-2012, 05:55 PM
That rear treatment will be cool when it's done.
1tuff68
02-07-2012, 07:27 PM
Super cool! Hope that bumper never gets dinged! :)
racedaddy
02-08-2012, 03:56 AM
really nice work
Crestronwizard
02-10-2012, 06:12 AM
Engine Arrived yesterday. Only just ordered it Monday. Anthony from Tommie Vaughn is the man!
ATOMonkey
02-10-2012, 06:20 AM
Very cool! Did it come with the ECM (or whatever they're calling it these days.)?
Crestronwizard
02-10-2012, 06:51 AM
Yes. :)
kmdracer
02-10-2012, 03:31 PM
Very cool!
Coasty
02-11-2012, 05:31 AM
WoW! That's a massive job. Well done so far. Love your work.
Crestronwizard
02-11-2012, 09:00 AM
Wish I could take all the credit. Kelly Murphy with www.murphyrodandcustom.com is fabricating the floors and rear and attaching to the frame.
Awesome!! Simply awesome.
85coupe50
02-11-2012, 08:01 PM
Glad you got the engine so quickly. Everything looks to be coming right along... The new custom 1/4 extensions look great.
Crestronwizard
02-13-2012, 05:26 PM
Thanks........figuring up the tank and fuel system now.....looking like I'll use Vaporworx and Ricks Tanks? Also need to figure out exhaust now and a 100 other things :)
ProTouringCuda
02-14-2012, 06:03 PM
What's the width between rear frame rails on your Chassis? I just designed a 1st gen Mustang tank for my Barracuda project - take a look at it on my thread. it's 33.5" x 19.5" x 7.5" - my rails are at 34"
Maybe Rick / Hector will cut us a deal if he makes two of them ;)
ProTouringCuda
02-14-2012, 06:04 PM
Crestronwizard
02-15-2012, 05:23 AM
Good question :). I will be out at the shop Friday and will measure it.
Crestronwizard
02-18-2012, 03:01 PM
stillridin
02-18-2012, 10:53 PM
Just went through the whole build so far and was sad to see that i caught up to the latest progress. Very nice! Love the rendering. Very big fan of the smoothed shaved look. In the rendering theres no front windshield molding. I'm almost to the point on mine where I'm going to do the same. love to see that when it comes time.
Crestronwizard
02-19-2012, 02:35 AM
Thanks.......there wont be any rear molding either. The rendering is being updated. The next 30 days should see a lot of progress.
ProTouringCuda
02-21-2012, 06:33 AM
Nice exhaust outlets, however, that's going to severely limit your fuel tank from being in the stock location. If you do, it's going to be quite narrow, or you'll have to shave the corners. On my 65 mustang - the exhaust comes out the rear GT valance and it's a VERY tight fit next to the tank.
What have you got planned for it? Are you going in the trunk - aka fuel cell?
Crestronwizard
02-21-2012, 06:35 AM
I'm splitting the difference..........coming up into the trunk some. I didn't want to do it but wanted the exhaust.............what's a crazy pro touring guy to do? :)
Dalamar
02-21-2012, 04:12 PM
Nice work! I just looked over the whole thread, great choice on parts/chassis. going to be sweet.
Crestronwizard
02-24-2012, 03:05 PM
That's awesome! About how far did you push the motor back ?
Crestronwizard
02-25-2012, 02:30 AM
We're still playing around with it. I'll post exact #'s soon. It's roughly 5 inches back from the original firewall in the pic :).
Sweet! I'm looking to push the exact same setup back in my 68 when the time comes and always love knowing what I'm up against. Thanks
Wesley J
02-25-2012, 01:00 PM
Wow, I thought mine was a ways back! Nice!
My dampner is directly above my rack, which is likely a fairly similar locaction to yours. You're engine appears to sit quite a bit higher than mine though. I'm basing my engine height on the T-56 bellhousing, not the oil pan. My oil pan in its current form would likely be < 3" from the ground but it well see heavy modification. My bellhousing will be about 5.5", with the crossmember just in front of it being the lowest point at about 5", with the option to lower the car to that ~4" ride height.
Looking awesome though.
Wes
Crestronwizard
02-25-2012, 01:47 PM
Thank Wes. I found the exact same thing to be true. 3" off the ground to the oil pan if I put it where I want it which is too close for me. Would be interested to see what your pan mod gets you. Go ahead guinea pig, I'm waiting! :) lol
Crestronwizard
02-25-2012, 01:48 PM
Oh, btw Wes, I am going to have alternator clearance issues. Are you running into the same thing? Thanks
Wesley J
02-25-2012, 01:58 PM
Absolutely. I wont be running it in the factory position. My frame and steering are in the way. I am running a remote oil filter as well.
55968
55969
stillridin
02-25-2012, 04:41 PM
Wow love the metal work. That is alot of welding. It seems you picked the right guy.
Crestronwizard
02-25-2012, 08:35 PM
Thanks for the pics Wes. Is yours body dropped like mine?
Crestronwizard
02-25-2012, 08:36 PM
Thanks. I have been very happy so far.
Crestronwizard
03-02-2012, 07:16 PM
Lots of new issues to deal with. Really regretting doing the narrow track front frame. I need more room! Lol. The engine is sitting way high currently. Anthony @ Tommie Vaughn hooked me up with a moroso pan and filter relocator kit. Once those are in I plan to sit the engine down 4" or more. The brackets for the top control arms are in the way so we'll see what happens. Stay tuned
Crestronwizard
03-05-2012, 06:29 PM
I'll be moving this more forward
Definitely too high.....you'll see in another pic what I have to contend with to go lower
You can see in this pic that I will start getting into the upper control arm mounts as I go lower....not to mention losing header clearance
Wesley J
03-06-2012, 08:18 AM
Sorry, not sure what you mean.
Crestronwizard
03-06-2012, 08:27 AM
:) The floor of the car was cut out and the bod "dropped" to lower the car without lowering the frame. So essentially the floor is now 3 - 4" higher than a stock one and everything else seems higher that is bolted to the frame .... Engine, Tranny, etc.
After some deliberation the engine is coming forward about 4 inches (roughly to where you have yours) and going down at least 2" , maybe more. Anthony @ Tommie Vaughn (I can't say enough good things about dealing with this guy) hooked me up with a trick Moroso pan and pickup that will get me the needed ground clearance. I have decided to go Twin Turbo, which was my original plan. I will have a lot of updates as all that comes into place. I really want to go to some events this year. Can anyone make some recommendations? Thanks!
Wesley J
03-06-2012, 11:54 AM
Man, my lisdexia tends to better the get of me....
My floor is not dropped up front. The floor of the mustang slopes from front to back so what I did was build my frame such that it protruded into the car starting at the front of the front seat pan. That way it wouldn't impede the ergonomics/floor of the driver. I'd hate to sit in the back though ;-) I'm tall enough that I need every inch of headroom for a helmet.
Can you send me a link for the oil pan/pickup? I'm at the point now time wise that I'm willing to spend a bit of cash to not have to fabricate absolutely everything...
Oh, and twin turbo?! #1 are you nuts and #2, where the hell are you gonna put them? LOL. Cant wait to see what you come up with!
Cheers,
Wes
Crestronwizard
03-06-2012, 11:58 AM
http://www.moroso.com/catalog/categorydisplay.asp?CatCode=12057&pt=20570
#1 Yes. #2 That's the fun part!
Wesley J
03-06-2012, 12:05 PM
Thanks for the info! I'm going to get it ordered right away!
Love the TT thing. I'm a turbo guy and have spent hours devouring all reference material pertaining to design that i could find. I've gone back an forth quite a bit on it but came to the realization that this will be my 4 wheeled daily driver and 510 hp should be enough to get me into trouble, especially on the autocross. I'd be doing the same as you if I was going as balls deep as you though.
Cheers,
Wes
Crestronwizard
03-06-2012, 12:09 PM
:) I will keep you in the loop. Working with Anthony and Bill Devine ( http://www.bullseyepower.com/home.asp ) to develop something.
Protour_Pinto
03-06-2012, 12:24 PM
Twin tailpipe turbos would give a nice look from the rear
Wesley J
03-06-2012, 12:30 PM
One big challenge on this motor is that it has a HUGE range of CFM that it makes power on. If you look at the range from max torque to max hp, its a pretty huge RPM range (4000+ rpm), and hence, CFM range. It'll be fun to size the turbos so that they give you the most drivable horsepower over that range.
Oh ya, checked the price locally for that pan and pickup... I'll be modding mine as originally intended...
Crestronwizard
03-06-2012, 08:14 PM
yeah, Bill & Anthony say this thing is going to have an awesome wide powerband. Should be fun.
You need me to pack an extra pan in my suitcase? lol
Crestronwizard
03-13-2012, 02:10 PM
I think it may be thin enough :)
Wesley J
03-13-2012, 02:29 PM
Can you pm me what you paid for it?
Crestronwizard
03-25-2012, 04:50 PM
Lots and lots of mods to get the engine where we really want it. Pics will be uploaded tomorrow.
Crestronwizard
03-28-2012, 06:09 PM
http://www.motorator.com/blog/ford/turn-key-engines-ford-road-runner-serpentine-system
I plan to use that. Anyone else have experience with them?
Crestronwizard
03-29-2012, 05:20 PM
Reverse Mounted the Alternator
Had to Pocket the Frame for Clearance
Had to Flip the Mounting Brackets from the Way Art Morrisson Does Them
Pic Looking Down the Firewall
Crestronwizard
03-29-2012, 05:26 PM
Transmission Mount is in
Nice Beefy Tranny
Crestronwizard
03-29-2012, 05:28 PM
linkstar69
03-29-2012, 06:50 PM
Love what you're doing, Great work.
Bryce
03-29-2012, 07:55 PM
nice progress.
wellis77
03-29-2012, 10:11 PM
Looks good Geoff.
LeighP
03-29-2012, 11:32 PM
Very cool stuff!
Bjkadron
03-30-2012, 09:25 AM
Question... do you have the engine solid mounted? Because otherwise the belt tension will be changed by the movement of the engine...
Dalamar
03-31-2012, 08:35 PM
Great work!
Crestronwizard
04-01-2012, 01:50 PM
No, The mounts have Poly Bushings. I will have a tensioner on the belt to keep that adjusted. Thanks for pointing it out.
Crestronwizard
04-01-2012, 01:51 PM
Thanks for the kind words. If anyone plans to do an IFS with the Coyote let me know.........I can give you a list of the issues you'll have to work around.
DJ Mabe
04-02-2012, 05:07 PM
Love what you've done with the rear of the car. Are the guys that are doing all of the metal work doing the painting as well?
Crestronwizard
04-02-2012, 05:10 PM
No.........considering paint shops now. Planning to be ready for paint by July. Fingers crossed.
Crestronwizard
04-06-2012, 07:23 AM
Starting on the custom stainless headers. Anyone know of a place that sells the stainless flanges to the block for the new 5.0? I can make em if not. Thanks
Crestronwizard
04-09-2012, 05:12 PM
Spent a ton of money on parts this week. Hopefully will have all the exhaust parts, steering, A/C, pedals, hinges and tank soon. Will give us lots to do. The welding around the windshield and rear glass is almost complete (making the glass look like it does on new cars). Pics soon.
Crestronwizard
04-22-2012, 12:20 PM
Crestronwizard
linkstar69
04-22-2012, 02:35 PM
Love the flush glass, I always think about how much I wish I'd done that with my dart, I guess it'll have to wait till next rebuild.
1tuff68
04-22-2012, 08:03 PM
Coming together nicely. Great work!
number98
04-23-2012, 09:11 AM
I agree, your car is really starting to take shape. Keep at it!
jr4452
04-23-2012, 05:36 PM
Lookin great! thanks for lighting a fire under me to get out and work on mine!
Crestronwizard
04-23-2012, 07:36 PM
Custom Stainless Headers Starting to Take Shape :)
ryeguy2006a
04-24-2012, 07:16 AM
The headers look great. Nice work.
Wesley J
04-24-2012, 08:25 AM
Sexy!
Crestronwizard
04-25-2012, 06:23 AM
Thanks Wes.....no matter how long I stay when I come to Canada there's never enough time. Thinking about coming up this summer for a few weeks and bring the family. I have a couple of huge projects coming up. Looking for helpers if you know anyone send them my way.
Crestronwizard
04-27-2012, 05:51 PM
